Peragon bed cover
Discussion in 'Tonneau Covers, Caps and Shells' started by Theshark, Jan 31, 2018.
  1. Oct 25, 2020 at 2:37 PM
    Behind enemy lines in CA
    Behind enemy lines in CA New Member
    Danjo
    2016 Tundra 4x4 TRD
    Peragon bed cover, custom push bar, rough country off road lights, under bed LED lights, CB, bed rails, Plastidip vintage Toyota stripes, driver's side A pillar handle, red painted calipers, locking gas cover, ejection passenger seat.
    I have a Paragon as well, after two years the black paint is easily stained by trees and bird droppings, more than have of the wheels have seized up, and it’s annoying when something blocks it in the bed, when I’m trying to open it. BUT its better that run plastic or Vinyl hands down..
    Skew12 likes this.
  2. Nov 9, 2020 at 6:59 AM
    browniemix33
    browniemix33 New Member
    New Hampshire
    2017 Metallic Grey Tundra Limited 4WD
    Wanted to weigh in myself for whats its worth. I currently have had one for ~6 months now and so far so good. I have the quick clamps attachments and a Few drawbacks are sometimes the clamps need re-adjustments/tightening. The other thing is the cover is certainly not waterproof (and Peragon does NOT claim to be so) and around the edges of the bed after a rainstorm can get somewhat wet. For the most part its not a big deal but certainly something to note
  3. Nov 9, 2020 at 7:35 AM
    dynamite08
    dynamite08 New Member
    2020 Army Green TRD Pro
    285/70/18 Nitto Ridge Grapplers Bakflip Mx4 cover WeBoost cell booster All windows ceramic tint
    I had one of these for a couple years and will give my two cents on it:
    Pros:
    - Beautiful finish and fit. Probably one of the best looking covers out there.
    - Seals well. None are waterPROOF, but it did well for me.
    - Excellent customer service (called them during install).
    - Cover is very easy to remove and set aside for extra space.
    Cons:
    - Makes about 1/4 of your bed useless. I had to end up putting a 2x4 across the back so stuff wouldn't slide to the cab and cause it to not open. Yes, you can remove it, but if you want to fill up your whole truck bed and have it covered, prepare to do some wiggling under the cover to retrieve stuff at the back.
    - Can't put anything on top of it. It scratches easily (tree limbs, setting a box on top, etc.). For me (a hunter), i like being able to tie horns and other gear on top of the cover as well. Tried that with the peragon and scratched pretty bad.
    So, if you want something that finishes your truck well and gives you a little extra storage space to throw a couple bags in your bed for a road trip, than yes. It's great. If you're looking for a completely covered and accessible bed AND want to tie down/transport stuff on top of it, look at something else.
  4. Nov 9, 2020 at 8:52 AM
    Faffie
    Faffie New Member
    2021 Cavalry Blue Double Cab 6.5' bed
    I really like the Peragon, but am concerned with what happens if you need to open it after a heavy rain storm--wouldn't the "accordion" action dump any rain collected on the top right into your bed? At least the folding tops open away from the bed. I have been researching tops that I can use with stake hole racks for my kayaks, and I really want to like this one. I have read some really negative reviews on Amazon, but since Peragon doesn't sell directly through Amazon I realized the ones offered on there are more likely to be defective or used.
  5. Jul 30, 2022 at 8:36 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So you just cut the clamps that came with it to fit in the bed rails? How did it work?
    I was thinking of finding some t-nuts that would fit in rail to mount it. I’m considering a peragon but not sure if I want to give up the bed rail.
  6. Jul 31, 2022 at 5:05 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Yes I cut the clamps, safer just to buy T nuts thou. I love mine
    Doxiedad likes this.
  7. Jul 31, 2022 at 5:10 AM
    Doxiedad
    James
    Charleston, SC
    Any issues with fitment putting it on the rail versus clamping to bedside ?
  8. Jul 31, 2022 at 5:31 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    No not at all
  9. Sep 22, 2022 at 6:56 PM
    MidwestTundra81
    MidwestTundra81 New Member
    Rob
    2020 Tundra TRD Pro
    None
    Has anyone here tried using a cargo divider with their peragon? I’m having trouble finding something that will fit under the rails of the cover, ideally I’d like to get the Toyota oem bed divider that works with the deck system but I don’t want to spend the money unless I know it’ll fit under the peragon
