Payload Stickers?
Discussion in '3rd Gen Tundras (2022+)' started by AnalysisParalysis, Dec 10, 2021.
  1. Mar 18, 2023 at 4:49 PM
    #511
    Pttundra23
    Pttundra23 New Member
    Paul
    Base tundraSR
    Actually, after I typed wife, I did take a 5 minute LMAO break and then I continued to type. There’s no chance my wife will be seeing these posts. I’m safe. Lol
  2. Mar 18, 2023 at 4:54 PM
    #512
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Seems that your payload is probably around 1500 lb. So that would put you 300 lb over.
    I'm around that much over sometimes. Pretty rarely. I just make sure it's properly distributed so that neither axle is overloaded. When towing, that means using a WDH.
  3. Mar 18, 2023 at 4:54 PM
    #513
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Still over your payload, though not as much. I think the 3rd Gen axle ratings are a little lower than the 2nd Gen so have to watch that too.
  4. Mar 18, 2023 at 5:01 PM
    #514
    Pttundra23
    Paul
    Base tundraSR
    Always a WDH. Yes, sometimes I’m over a couple of hundred without loading all my stuff on. I think I’m going to have to go to a 2500 though, because in a couple of years I’ll be retiring and I’m gonna need all my toys with me on long runs. I can’t be that much overweight permanently. It might look silly towing such a small camper with a huge truck. The bed will be loaded up though. I still have some time to think this out. Thanks for your replies y’all.
  5. Mar 18, 2023 at 5:35 PM
    #515
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Keep in mind that a WDH will transfer some weight to the trailer axle(s) and reduce some weight on the truck rear axle. But using air bags will negate some of that truck load weight reduction as it will bring some trailer axle weight back to the truck rear axle. It's not obvious to think about it that way and I had to see the explanation of how WDH works to get this myself.
    Terndrerrr likes this.
  6. Mar 18, 2023 at 5:52 PM
    #516
    Pttundra23
    Paul
    Base tundraSR
    I heard about that with the airbags. That’s why I ordered a portable scale from Germany. The Reigh weight control, so I can go crazy weighing every possible configuration of my rig. I can’t wait till it gets here. I’ll post pics of this thing, sounds pretty sweet. Also, I don’t have airbags. I’ll probably keep away from them in the future as well. Thank you for the reply dude.
    Henry1jg likes this.
  7. Mar 18, 2023 at 5:58 PM
    #517
    Breathing Borla
    AZ
    Bigger truck
  8. Mar 18, 2023 at 8:45 PM
    #518
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    2023 Tundra CM Limited TRD OR Midnight Black
    Figured I would try a CAT scale while we were out for a drive today.
    2023 Limited CM (Pano roof) 5.5 TRD OR. I switched factory tires to KO2s at the same size (265/70R18) and added TRD running boards, that’s it. Full tank of gas (32 gal).
    No one in truck: 5920 lbs
    Me, wife, two teenagers: 6600 lbs
    The difference in weight between empty truck and the four of us checks out, but I feel both readings are a few hundred pounds high. I’ve read through this entire thread and 5920 lbs feels too high for my trim even with the marginal changes I’ve made. The registration paper says the shipping/curb weight was 5490 lbs, so a difference over 400 lbs??? Apparently my tires are 55 lbs and the factory ones are 37 lbs. That’s just an increase of 72 lbs. I can’t imagine the cast aluminum running boards are hundreds of pounds..?
    Are CAT scales ever off? Maybe I should try the other one in the city and compare.
    At 5920 lbs my payload is 1311 lbs! Heck my door sticker says 1400 lbs… This thread was giving me hope I would see the number get bigger, not smaller! o_O
  9. Mar 18, 2023 at 9:25 PM
    #519
    Paul Moll
    Paul
    Idaho
    I found a nearby CAT scale that was off by some 2000 pounds, yes, 2k pounds. Obviously it needed repair. Don't know what they typically run. I do have a local garbage dump that has a scale on the way in and another on the way out so they can measure how much you dropped off. I went through empty both ways and they were identical. It read out to the nearest 20 pounds. Hope this helps some :)
    Mattedfred likes this.
  10. Mar 19, 2023 at 5:59 AM
    #520
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Heavier tires and whatever stuff you have in the truck seems to account for the 89 lb difference from your sticker. You would have the only 3rd Gen with an accurate sticker so far if those numbers are all correct, though.
  11. Mar 29, 2023 at 12:14 AM
    #521
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    5920 is exactly what a CrewMax Limited w/ pano roof (heavy) and running boards should weigh. See post 409 and 449
    There's only a ~30-40lb difference between CM 5.5ft and 6.5ft bed
  12. Mar 29, 2023 at 5:04 AM
    #522
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was glad to find out my wife's Pilot has less payload than my truck.
    TRD-JP and Mattedfred like this.
  13. Apr 27, 2023 at 7:36 PM
    #523
    Paul Moll
    Paul
    Idaho
    I predict it will weigh about 100 pounds under GVW minus Payload (less your accessories). Many people are finding the truck is about 100 pounds lighter than expected, mine was too.
    Mattedfred[QUOTED] likes this.
  14. Apr 28, 2023 at 1:39 PM
    #524
    mass-hole
    mass-hole New Member
    nailed it
  15. Apr 28, 2023 at 6:33 PM
    #525
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My guess is that those black badge stickers are too heavy and need to go! ;)
    Looks like a great setup! Pics coming?
  16. Apr 28, 2023 at 6:45 PM
    #526
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Looks fantastic!
    The wheels really look so much better than the TRD offroad ones!
    I didn’t know that you could get a TRD Sport in Canada! What sort of things are different with that configuration.
    I guess you don’t get all the cameras for 360 view? How about the rear locker and the MTS button?
  17. Apr 28, 2023 at 7:41 PM
    #527
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    That’s different!
    How did you configure this to order it? I thought that there were no options other than a check box for TRD package or not.
    However, you managed, it seemed to work out. And bonus on the payload number!
  18. Jun 22, 2023 at 6:55 PM
    #528
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    So I went to the landfill and weighed the truck today. 2023 Limited TRD 6.5' bed.
    It weighed 2750kg / 6063lbs
    I have Go Rhino D6 side steps installed (45kg / 100lbs), different tires (42kg / 92lbs difference between set of OEMs and Coopers), I was in the truck (70kg / 155lbs) with some loose items (nothing big). I also had about 90l / 24gal of gas.
    157kg / 347lbs extra weight
    GVWR from the sticker is 3340kg / 7363lbs
    Payload from the sticker is 630kg / 1390lbs
    Actual payload with everything mentioned above is 590kg / 1300lbs
  19. Jun 24, 2023 at 9:44 AM
    #529
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm hoping to get back down to 145 but I'm not having much luck. :(
  20. Jun 24, 2023 at 10:55 AM
    #530
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    LOL :rofl:
    Nice catch though
  21. Jun 24, 2023 at 11:03 AM
    #531
    Breathing Borla
    AZ
    Geez I need to lose some lbs
  22. Sep 23, 2023 at 5:44 PM
    #532
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Nice write up @Mattedfred !
    Pics of your set up.
    Thanks
  23. Sep 23, 2023 at 7:27 PM
    #533
    pwpblue
    Greensburg,PA
    That's a good setup and
    Thanks for the share!!!
