Payload Stickers?
Discussion in '3rd Gen Tundras (2022+)' started by AnalysisParalysis, Dec 10, 2021.
  1. Sep 13, 2022 at 9:29 PM
    #451
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    Anyone have this sticker inside their driver door? Not sure what modification would reduce the payload by 6lbs??
  2. Sep 14, 2022 at 5:14 AM
    #452
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Floor mats?
  3. Sep 19, 2022 at 11:19 AM
    #453
    Ccarlson
    Ccarlson New Member
    Future owner
    My payload stickers including the yellow modification sticker comes out to 1435 lb. Cat scale curb weight is 5660 lb with full tank of fuel. GVWR is 7310 lb so real payload is 1650 lb. I'm a happy camper! Truck is a double cab limited with TRD off-road package, Mats, limited power package.
  4. Sep 19, 2022 at 8:44 PM
    #454
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    lolol! The sticker lowered it by another 0.5 oz = they should add another sticker for that!
  5. Sep 24, 2022 at 8:54 AM
    #455
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You need to just get your hands on a Hilux somehow.
    https://youtu.be/pUWMc92W1wQ
  6. Nov 23, 2022 at 5:27 AM
    #456
    Insulator
    Insulator New Member
    2023 CMLB Lim TRD / 03 Tundra Lim AC
    Dual Battery
    2023 Limited CrewMax 6.5’ bed with JBL, Pano roof, limited power package, TRD OR, TRD skid Plate, floor mats…all the heavy things.
    Took it to the scale on a test drive (2 miles on the odometer) so I knew the answer before driving away.
    Payload Sticker 1390 lb
    Yellow sticker 13 lb
    No one in it with a full tank 5840 lb
    GVWR 7365 lb
    GVWR minus scale weight = 1525
    Very happy to have an extra 135, as I may have declined the pano roof or JBL or maybe even lower option had I been able to spec the exact build.
  7. Nov 23, 2022 at 5:55 AM
    #457
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I always make sure to a take a deuce every time I drive to get that 6 lbs back.
  8. Nov 23, 2022 at 6:57 AM
    #458
    OnThaLake
    OnThaLake New Member
    6 pounds!?! Impressive!
    That's gotta be several flushes.....
  9. Nov 23, 2022 at 7:05 AM
    #459
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    Deuces don’t count as payload unless you leave it in the truck.
    omgboost and OnThaLake like this.
  10. Nov 23, 2022 at 7:07 AM
    #460
    OnThaLake
    Be strategic..... balance the load.....
    omgboost likes this.
  11. Nov 23, 2022 at 7:38 AM
    #461
    Kanadakid
    Kanadakid New Member
    Donald
    2023 Tundra 1794
    Nothing yet
    Ahhhh I'm going to exceed 1500 lbs when I go camping.....always
  12. Nov 23, 2022 at 11:30 AM
    #462
    mass-hole
    mass-hole New Member
    Wow, thats 20.64 Courics. Impressive.
    omgboost[QUOTED] likes this.
  13. Nov 23, 2022 at 11:35 AM
    #463
    mass-hole
    1525 is decent for that truck, you certainly can't complain and I don't think you could get much better in an F150 Lariat or similar trim GM. My 2014 F150 Lariat Supercrew 6.5' bed with virtually every option except the offroad package came in at 1560 on the cat scale and 1539 on the door sticker. The newer Lariats that I have looked at were pretty much identical to mine.
    But then you wonder, if you didnt have the pano or JBL, would the GVWR be the same? It seems like Toyota might offer multiple GVWR's for the same configuration instead of just setting them all to the highest one and maximizing the payload of the lighter weight trucks.
    Cpl_Punishment likes this.
  14. Nov 23, 2022 at 2:01 PM
    #464
    Dakota3645
    Dakota3645 New Member
    Dakota
    2022 Tundra SR5 - Army Green
    Just weighed my truck on the local CAT scale. 2023 loaded SR5 crewmax 5.5 bed. GVWR on sticker shows 7,210 lbs. Payload on sticker says 1,395 lbs then yellow sticker says minus 48 lbs for add ons. Additions from completely stock are OEM all weather mats & OEM bed mat. Added a Bakflip MX4 as well. CAT scale weight total was 5,660 lbs so my correct payload is 1,550! Not bad at all considering it would probably be 1,650 without the MX4 cover, bed mat and floor mats!
  15. Nov 23, 2022 at 5:38 PM
    #465
    TrimTab
    TrimTab Old man with a beard
    Trim
    i just went to Cat scale w/ 1794 hybrid and it showed :
  16. Nov 23, 2022 at 5:39 PM
    #466
    TrimTab
    Trim
    weighed with a full tank of gas
    this gives a payload of 1460lb
    but then do need to subtract the yellow sticker ??
    however the sticker on door shows only 1305
    Terndrerrr likes this.
  17. Nov 24, 2022 at 7:19 AM
    #467
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    This is the key. You’re looking for actual payload which is the difference between gross and curb weight. It is defined on the door jamb as weight of occupants and cargo (this does not include fuel). If you want the actual number, you need to weigh your truck with a full tank. I’m wondering how many people are making sure their tank is topped off before driving onto the CAT scale.
    That’s odd; the yellow sticker doesn’t show a number to reduce the payload by. What is your gross weight on the other door jamb sticker?
  18. Nov 24, 2022 at 9:47 AM
    #468
    TrimTab
    Trim
    7668
  19. Nov 24, 2022 at 9:48 AM
    #469
    TrimTab
    Trim
    i don’t understand that yellow sticker, yes weighed right after filling gas so full tank.
    GVWR 7668
    CAT 6200
    payload 1468
    toyota sticker shows payload of 1305
    a difference of 163lbs
  20. Nov 24, 2022 at 11:52 AM
    #470
    Terndrerrr
    Music City
    6UR-FE
    Nice! Man I wish my truck had that same gross weight. I’d have 1700lb of payload.
  21. Nov 24, 2022 at 12:01 PM
    #471
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Got a sharpie? :D
  22. Nov 24, 2022 at 4:52 PM
    #472
    TrimTab
    Trim
    honestly, I agree with the above posters i wish Toyota offered ,in the higher trims, payload in the range of 1500 - 1580 , why in the heck didn’t they allow us to opt out of pano roof is beyond me , i will probably never ever open the thing unless maybe for the 4th of July an that is doubtful
    Malinois38 likes this.
  23. Nov 25, 2022 at 11:03 AM
    #473
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    Looking through this thread got me curious. My door label is listed at 7165 lbs gvwr. 22 crewmax limited 2WD, weighed with a full tank, black armor bedmat and bakflip mx4, drawbar, and miscellaneous gear under the rear seat and in the console. My door sticker says max payload is 1445. Based off the name plate and my weight today, I have a calculated payload capacity of 1365 lbs. If, however, I use the individual axle ratings at 100% of their rating, my available payload goes up to 2140 lbs. By the time I load up the travel trailer(750lbs tongue weight), The wife, kids and dog(650lbs), and all the crap that rides in the bed of the truck, I will be 150-250 lbs over the 1365 number easy. My 2000 tundra had payload of around 1900 lbs back then and I know it could handle much more than that. Surely theses newer, bigger trucks can handle a couple hundred over what the door label states.
  24. Nov 25, 2022 at 4:34 PM
    #474
    Insulator
    Dual Battery
    For the limited, per Canadian Owner's manual, removing Pano and JBL should not effect GVWR. But deleting those wasn't really something I wanted to wait for. Besides, do you think GVWR is actually based on a different frame, brakes, drivetrain?
    You do! ;) Despite my truck saying 7365, I may just treat it as the 7780 which is max for the hybrid of the same size.
    You have to take the least capability as they are all MAX ratings - you can't add axle capability to develop a new max rating. If you look above, I think GVWR is scaled by truck model, which means they really care how and where you put in the weight - if you put olympic plates over each axle, you could handle way over GVWR, but if you put in a giant slide-in camper, you're going to throw off vehicle dynamics.
    :benchpress:
  25. Nov 26, 2022 at 11:10 AM
    #475
    LimitedLuck
    LimitedLuck New Member
    Rich
    2023 Limited
    2023 Tundra Limited Crew Max 4x4, (NOT hybrid). Yellow payload reduction sticker 19 lbs (includes ball hitch mount, first aid kit, all weather floor mats.)
    GVWR 7230 lbs / Payload 1400 lbs
  26. Nov 26, 2022 at 11:56 AM
    #476
    Terndrerrr
    Music City
    6UR-FE
    I’m over by a few hundred pounds on a somewhat regular basis. Did Imogene Pass like that. Truck does not care at all. OEM leafs and RAS. No accelerated wear on brakes, either.
  27. Nov 27, 2022 at 8:03 AM
    #477
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    My tank was full, truck weighed 5560, gvwr 7210, payload came in at 1650. I have a sr5 cm 4wd, no
    Terndrerrr[QUOTED] likes this.
  28. Jan 25, 2023 at 9:34 PM
    #478
    HighroadTRD
    HighroadTRD New Member
    Bay Area
    23 Tundra Pro Magnetic Grey
    Retrax Bed Cover, RCI SKIDS, RCI Sliders
    The pro model has no options to change the payload, so how does toyota get away with stating 1600lbs???? My payload sticker says 1355. There are no other configurations on the pro.
  29. Jan 25, 2023 at 9:40 PM
    #479
    mass-hole
    Because the stickers are BS. Go weigh the truck at a cat scale empty with a full tank of fuel and you’ll probably find the payload sticker is low.
    Toyota is only putting one of around 15 possible payloads on any given truck. The 15 are in the owners manual. Your sticker will match one of them because they are nit accounting for specific options
    LimitedLuck likes this.
  30. Feb 4, 2023 at 1:18 PM
    #480
    Pttundra23
    Pttundra23 New Member
    Paul
    Base tundraSR
    I had lots of questions about tundra payload which all have been answered reading through this thread. My only question is, has anyone taken a base SR or SR5 model to the scale? And what was the actual curb weight of? Thanks.
