Payload overload for 1 mile
Discussion in '1st Gen Tundras (2000-2006)' started by ColumbiaGorge, Nov 7, 2019.
  1. Nov 8, 2019 at 8:15 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Can you drive the truck around back and use this thing? Snag a google 20% off coupon and this thing will save you a half day work for under $30. I’ve used it for over two years now on full yards with an extremely rough Line-x.
    EDIT: never mind. Just saw you said pallet.
    Darkness likes this.
  2. Nov 8, 2019 at 8:33 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    The “competitors” aren’t abiding by the same towing standards that Toyota is.
    Brb going to find the specs...
    Edit: I don’t believe ford and GM are following these same standards.. especially on their half tons but Toyota is.
    http://www.trucktrend.com/how-to/towing/1502-sae-j2807-tow-tests-the-standard
    I saw the new Chevy 1500 commercial which states something like 13,100 towing cap and rolled my eyes.
    kenomouth64[QUOTED] likes this.
  3. Nov 8, 2019 at 8:36 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It's a mile, it'll be fine. My dad buys a pallet of pellets every winter and it's a 5 mile drive and he's done it for 15 years with no issue in his 1st gen.
    tvpierce and ColumbiaGorge[OP] like this.
  4. Nov 8, 2019 at 8:41 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I got an extended warranty so I won't wait that long lol..
  5. Nov 8, 2019 at 8:51 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    I don't understand all the controversy. Payload is not a magic number where if you go over by a few pounds the springs are going to bend or break, the axle tubes are going to bend and the wheel studs will shear.
    You bought a truck use it like a truck. Make sure your tires are aired up go get the pellets. I buy mine by the pallet also.
    7.62Tundra and ColumbiaGorge[OP] like this.
  6. Nov 8, 2019 at 8:54 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I usually have my pellets delivered, but on occasion have had to get them myself. My last truck, a GMC Sierra was a real turd, and things broke without even pushing it to the limit, so i broke down the pallet at the store, and took a 1/2 ton at a time. Like you, i was only about a mile away, and it only took an extra hour or so without major breakage. :thumbsup:
  7. Nov 8, 2019 at 8:59 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I overloaded my 02' AC with a ridiculous amount of bluestone from a salvage house. The rear springs were pinned to the frame, it was a terrifying drive and I said never again. I rented a Home Depot trailer and went back and packed even more stone on the trailer and towed it like butter. Absolutely, recommend this for long term, but it is worth doing the first load with the truck and you can decide the pain you want to put your truck through. 1 mile is the only reason I would even consider saying yes to loading the truck once. If your springs are pinned... Rent for multiple runs.
    TILLY likes this.
  8. Nov 8, 2019 at 9:10 PM
    TILLY
    Massachusetts
    PCJ, its not just a few extra lbs. 50 bags @ 40 lbs. a piece equals 1 Ton. If you feel comfortable with this, be my guest, but i think its bad advice.
  9. Nov 8, 2019 at 9:12 PM
    Melikeymy beer
    Muscogee Nation
    Shhhhh! Testosterone. It's a thing.
  10. Nov 8, 2019 at 9:22 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Yeah, but your truck isn't rated to carry only 40 lbs. You might be 200-500 lbs. over depending on your options. You can do whatever you think is right, but I own a truck and know how to use it.
    snivilous likes this.
  11. Nov 8, 2019 at 9:26 PM
    Melikeymy beer
    Muscogee Nation
    I'm going to quit now lol.
  12. Nov 8, 2019 at 9:38 PM
    TILLY
    Massachusetts
    I have no idea what that means, but who am i to judge mathematics. best of luck to you though.
  13. Nov 8, 2019 at 9:47 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    The Tundra is a 1/2 ton rated truck. We know it will do way more than that.
    Yet your trks no spring chicken, so rent a trailer or borrow your friends trk and smoke a ham or turkey for him. :) 2000lbs = 1 Ton
    Maximum payload 2005 Tundra
    4dr Dbl Cab Limited 4wd 1580 lbs.
    4dr Dbl Cab SR5 4wd SB 1635 lbs.
    4dr Dbl Cab SR5 Rwd SB 1875 lbs.
    source, edmunds
    Melikeymy beer likes this.
  14. Nov 9, 2019 at 9:04 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So many 2nd/3rd gens! Go back to your shantytown!
  15. Nov 9, 2019 at 1:41 PM
    02goes
    02goes New Member
    Lol, it took ya long enough
    bmf4069[QUOTED] likes this.
  16. Nov 9, 2019 at 11:29 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I filled my bed with sand and drove half a mile off road (rotted fire road) and 3 miles on streets to my brothers house. Factoring the wheel wells and tool box I think by cubic feet it was 2000 lbs or more. Dug it by hand and unloaded by hand when I had stock leafs.
    bmf4069 likes this.
  17. Nov 10, 2019 at 4:01 PM
    Professional Hand Model
    Hand Protectors
    Good rule of thumb on the early 1st Gens is when you are loading your bed with weight to keep an eye on your bump stop to frame distance. When the distance closes to about an inch gap is then your weight is at the 1600lb mark (which happens to be max payload). I know this from mucho experience. Trust me on this.
    Please pay someone to deliver your goods if you need to go over your max payload on your truck. Its not worth taking a chance.
    FirstGenTundra, des2mtn and GODZILLA like this.
  18. Jan 19, 2021 at 7:57 AM
    2mchfun
    2k on a Tundra will be fine and if you want to save the springs just throw on some sumo springs and roll on.
  19. Jan 19, 2021 at 8:20 AM
    #49
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Uhaul trailers start at $14 for 24 hours... the Tundra should have a hitch already... why overload???
    The big open top utility trailers they have have a 3400 pound weight cap, those are 29 a day.
    Cpl_Punishment likes this.
  20. Jan 19, 2021 at 8:28 AM
    #50
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  21. Jan 19, 2021 at 10:55 AM
    #51
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    What exactly are you worried about happening though?
  22. Jan 19, 2021 at 11:31 AM
    #52
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm stealing... I mean strategically reemploying this pic... LOL
  23. Jan 19, 2021 at 11:41 AM
    #53
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I'd mainly worry about damaging my suspension (shocks and leaf springs) and differeial. But also the transmission and possibly engine if you drive hard.
    I do actually haul a 1 ton pallet of pellet in my 2014 Tundra 2 or 3 times a winter now that I have 10 ply tires. I only have a few miles to travel from the store back to my house and I just go slow. The tires have greatly improved the stability of the truck under heavy loads.
