Paying extra for OFF-ROAD edition and then changing everything?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SteviJ, May 21, 2019.
  1. May 23, 2019 at 12:26 PM
    #91
    Ibanez6224
    Ibanez6224 New Member
    2019 TRD OR
    Of course you can, but again... resale value. You're essentially saying what's the difference between a "clone" and the real thing. Well, one is real and the other is a clone. Not that these trucks are collector's items by any stretch, but the TRD packages are more "desired" at resale.
  2. May 23, 2019 at 6:46 PM
    #92
    FLMallCrawlr
    FLMallCrawlr New Member
    2019 Tundra limited
    20x9 pro comp wheels Custom built exhaust w/magnaflo S&b intake 6112 front Fox back Rigid ditch lights Infinity speakers with kenwood amp 2 10” mtx subs
    I did this same thing with my Tacoma. Bought the OR and then changed out wheels and suspension. But my main reason was the rear locker. This time around I just bought the Limited
  3. May 23, 2019 at 7:43 PM
    #93
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Same here on 2 Tacomas. Wish Tundra had locker. Every other full size does.
  4. May 23, 2019 at 8:44 PM
    #94
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    I just love to do mods and change it all
    SteviJ[OP] likes this.
  5. May 24, 2019 at 4:01 AM
    #95
    SteviJ
    SteviJ [OP] New Member
    Jared
    2003 Tundra Access cab
    Do you not need to balance them and then get an alignment after?
  6. May 24, 2019 at 9:12 AM
    #96
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Nope... The wheels are already balanced. When you get your tires rotated (every 5k I guess), they don't have to re-balance them. The balancing is all about the tires... Tires might be slightly heavier on one side than the other. Adding a weight to the rim counteracts the tire imperfections. Once the tire is balanced to the rim, it is in-balance regardless of where they are mounted. Heck, even just rolling it down a hill it would be nice n smooth.
    And for alignments, that is only an issue with the suspension changes, not wheel changes. Again, you don't get an alignment every time you rotate your tires. Same for swapping in a new set. Alignments ensure that your HUBS (maybe not the proper term here.. Whatever you would call the thing you mount your wheel to) are in the right position. Once that alignment is correct, doesn't matter what wheel/tire you have on it.
  7. May 29, 2019 at 4:49 AM
    #97
    oh_really
    oh_really New Member
    NoVa
    2019 Tundra CrewMax Limited Cement
    Hello. First post here. I just picked up a 2019 Limited Crewmax with Premium package in cement grey. I opted to go without the TRD off-road package because I do plan to modify the suspension and I liked the 20" wheels (even though those will get replaced). Mine came with the LED head and fog lights. I don't mind not having the side TRD stickers on the bed but I plan to let my wife custom make me something anyway.
  8. May 29, 2019 at 4:51 AM
    #98
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I have TRD OR on my 1794 and I think it was zero cost or cheaper on that trim
