Passenger seat mechanism upgrade
Discussion in '2.5 Gen Tundras (2014-2021)' started by rr3311, Aug 16, 2015.
  1. Aug 16, 2015 at 8:06 AM
    rr3311
    rr3311 [OP] Tundra Magic
    Ohio
    2015 Bronze Tundra Limited Dbl cab 4x4
    Added Extang Solid fold tonneau cover Replaced backup lights with projector LEDs Cab LEDs Taconsha P3 brake controller mounted in dash
    Does anyone know if it is possible to replace the existing mechanical passenger seat frame with the motorized fully adjustable as a retrofit? My wife loved the Tacoma seats that weren't as tall and more adjustable. She is uncomfortable with the 2015 tundra Limited seat. The truck that was available did not have the upgraded passenger seat option.
  2. Aug 16, 2015 at 10:02 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Look under the seat and see if there are any unused electrical connectors. Toyota tends to use the same harness regardless of final options. If the seat adjustment connectors are there, it should be an easy upgrade. Otherwise you'll be needing to break out the wiring tools and electrical diagrams.
  3. Aug 16, 2015 at 11:02 AM
    rr3311
    Ohio
    The connectors are there.
  4. Aug 16, 2015 at 8:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks like you are good to go. Let us know how the swap goes.
  5. Aug 17, 2015 at 7:23 PM
    rr3311
    Ohio
    Any suggestions on a source or should this Come directly from Toyota?
  6. Aug 17, 2015 at 9:01 PM
    Mr.Green
    Mr.Green New Member
    It should be cheapest to find a totaled vehicle and purchase the seat. You can then find someone to change the upholstery and put the one from your original seat. I don't know if the seats for the leather and fabric trim are exactly the same or if they use different padding.
  7. Aug 17, 2015 at 9:43 PM
    Problem is finding one totaled. I haven't been able to find a 2nd gen Tundra at a pull your part, let a lone a 3rd gen here in Metro Denver area. Good idea though.
  8. Aug 17, 2015 at 10:15 PM
    Mr.Green
    Mr.Green New Member
