Passenger headlight issue - 1 side not working
Discussion in 'Lighting' started by B’sTundraTRDPro, Apr 14, 2019.
  1. Apr 14, 2019 at 1:52 PM
    B’sTundraTRDPro
    B’sTundraTRDPro [OP] New Member
    16 Tundra Trd Pro
    Wheels, grill, starter, headlights,tail light, 3rd light, bed cover.
    Has anyone run into an issue with one headlight not working? My passenger side has not been working, and yes tried about 10 different bulbs. My multimeter shows it is not getting power, i know the relay is working as it is turning over. (Will check with multi meter soon, but don’t think it is the relay). Also tried tracing the wire back to the fuse box, and tested it with still no power. (It’s the brown wire) at a loss, and have taken it apart like 10 time. Curious if anyone else had this issue? I have a 16 tundra try pro.
  2. Apr 14, 2019 at 2:37 PM
    B’sTundraTRDPro
    16 Tundra Trd Pro
    Yes, switched the drivers side that was working for the passenger side and still didn’t work then put it back in the drivers side and it turned back on, so not the fuse.
  3. Apr 30, 2019 at 5:28 AM
    Bumper10
    Bumper10 New Member
    Try turning the housing that bulb sits in. It sometimes get loose. I had that problem with my 07.
  4. Feb 14, 2020 at 4:41 AM
    SweetBabyRay
    SweetBabyRay New Member
    Did you ever find the issue this just happened to me?
  5. Feb 14, 2020 at 5:29 AM
    SweetBabyRay
    I checked the fuses, and replaced both bulbs still nothing. Passenger side is the only one out. Just no low beam. Got highs on both sides but no low on passenger
  6. Feb 14, 2020 at 5:54 AM
    SweetBabyRay
    I will do that let you know thank you
    NewImprovedRon likes this.
  7. Feb 14, 2020 at 4:51 PM
    SweetBabyRay
    Ok just changed all the fuses in the box, mini fuses, and still same issue...thoughts?
  8. Feb 14, 2020 at 6:09 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Any voltage at the faulty light's plug?
  9. Feb 15, 2020 at 2:53 PM
    SweetBabyRay
    Well shit after running tester i ended up swapping DIM relay with HEAD relay and there it was. All better. Thanks guys
    BrandonL812 likes this.
  10. Feb 29, 2020 at 7:54 PM
    Handsmagee
    Handsmagee New Member
    08 tundra
    3/1 level Vplow
    I have the same issue but it's not a fuse or relay... any one have the scheme for the lights :monocle:
  11. Dec 12, 2021 at 3:09 PM
    Jb_4x4
    Jb_4x4 New Member
    Juan
    2011 4x4 Tundra t-force
    Anyone have any other suggestions to remedy this issue? I changed the bulbs, checked the fuses, switched the relays and one of my headlights is not working.
    Any help would be appreciated.
  12. Mar 27, 2022 at 8:28 AM
    Lineman
    Lineman New Member
    White tundra
    Same here
  13. Mar 27, 2022 at 8:35 AM
    Lineman
    Lineman New Member
    White tundra
    Any help with passengers side head light
  14. Mar 27, 2022 at 8:54 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    What year is your truck?
    Taco-Spike likes this.
  15. Mar 27, 2022 at 10:26 AM
    Jb_4x4
    Jb_4x4 New Member
    Juan
    I ended up having to take my truck to an Auto electrician. They “said” they had to reprogram/relearn my computer low beam head light function. Not sure if it was legit or not but my headlights are working again. Cost me $230. Sorry could not be more help and wish I could have figured it out myself.
  16. Mar 27, 2022 at 9:04 PM
    Rjn9724
    Rjn9724 New Member
    Robert
    2012 tundra trd limited
    Bully dog Hid
    So I just discovered this is also happening to my 2012 tundra also. After messing with the bulb and fuses my passenger high still wouldn’t come on.
    I then started messing with the headlight switch turning the highs on and off and the passenger high beam came on. I’m going to verify by test lighting everything.
    my theory is the switch is bad. But I’m going to try the pcm relearn by uninstalling my tuner.
    any thoughts or has anyone else figured out something else?
  17. Mar 28, 2022 at 3:23 AM
    TXTundra2722
    2015 Black Tundra
    This question is being asked by several people and only one person has responded with their experience. It would be nice if the ones that asked, would return to say what they did or found out was the fix.
  18. Mar 28, 2022 at 2:01 PM
    Lineman
    Lineman New Member
    White tundra
    2013 tundra
  19. Mar 28, 2022 at 2:21 PM
    Lineman
    Lineman New Member
    White tundra
    My truck is a 2013
  20. Apr 15, 2022 at 2:42 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Experiencing the same issue on my driver side low beam.. just took the whole headlight out to mess with it: checked different bulbs, and then just checked voltage and confirmed nothing was there. Just this one side randomly went completely dark. Any help would be much appreciated.
    Lineman likes this.
  21. Apr 17, 2022 at 1:20 PM
    Lineman
    Lineman New Member
    White tundra
    Same here please
  22. Apr 17, 2022 at 3:30 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    For everyone with this issue, I would start here. Assuming you have checked and made sure the bulb is good.
    This is for a 2014-2017 non LED headlight truck.
    Each side, Driver and Passenger has a dedicated power wire for High and Low Beam.
    Green - Low Beam Left Side
    Light Green - High Beam Left Side
    White - Low Beam Right Side
    Brown- High Beam Right Side
    Each side also has a Low and High Beam fuse. If any of these are burned out none of the lights will work.
    15A HEAD LL Left Low
    15A HEAD LH Left High
    15A HEAD RL Right Low
    15A HEAD RH Right High
    The Dim Relay flips back and forth to send power for Low Beams (Pink Wires) or High Beams (Purple Wire) depending on the state of the headlight switch/lever. You can generally assume if one side, say low beam is working, then the DIM relay is working and sending power down both Low Beam wires (Pink)
    If your Low beam is out make sure the truck headlights are on and set to low, if high make sure the high beams are turned on. Low beam and High beam fuses will only have power when each is activated. The DIM relay handles this.
    Check for voltage at the bulb connector, then move up and check for voltage on each side of the corresponding fuse.
    If you still have no power on both side of the fuse you could potentially have a bad DIM relay, or bad HEAD relay.
    Additionally you could have a broken or chaffed wire between the relays and the bulb socket or worst case scenario a faulty headlight switch in the dash that the body ecu is not recognizing inputs from.
    Winston81 likes this.
  23. Jan 15, 2024 at 12:55 PM
    cgilbertson
    cgilbertson New Member
    2019 Tundra TSS
    Hi @Jeff_5_7 . My problem is a left high beam inop. The 2019 Tundra is a single bulb unit (not sure if that's the same for earlier models). I've determined that it's not bulbs, fuses, or relays. I did find that, when switching to high beams, the voltage at the bulb socket seems be a circuit in parallel, i.e. the voltage drop is ~6v at both the high beam and low beam pins. Whereas, the full voltage is read at the low beam pin when low beams are selected. I haven't pulled the RH headlight to do a comparison yet.... Have you seen this before? Thanks. - Chris
  24. Jul 19, 2024 at 5:19 PM
    ShelbyGT1967
    ShelbyGT1967 New Member
    I'm having the same issue, passenger headlamp not working anymore. I was using halogen bulbs. I went to replace the "burnt out" bulb, no luck. Checked the fuse, not it. So I tried the stock bulb, it works. So then I tried installing the new halogen bulbs and blew a fuse. Now I need to figure out why. If I find out why, I'll come back and post.
  25. Dec 7, 2024 at 5:50 PM
    Cooper1
    Cooper1 New Member
    2012 Sequoia
    Passenger side low beam out. Bulb good, fuse good. No voltage on wires behind plug at bulb. ?????
  26. Dec 7, 2024 at 6:16 PM
    Cooper1
    Cooper1 New Member
    2012 Sequoia
    Going to run new wires from working side to non working side.
  27. Jan 5, 2025 at 6:12 PM
    Winston81
    Winston81 New Member
    Jon
    2013 Platinum
  28. Jan 5, 2025 at 6:13 PM
    Winston81
    Jon
    2013 Platinum
    Thanks for this reply. Kinda new on here, I have this problem with Left Side low beam. not bulb, not fuse. When you say check the DIM relay, is that fuse or switch?
