Passenger front door rattle
Discussion in '3rd Gen Tundras (2022+)' started by jfletch133, Jun 18, 2022.
  1. Nov 30, 2022 at 8:57 AM
    #61
    TunBruh22
    TunBruh22 New Member
    Charles
    22 Tundra Limited
    I’m with you guys on this issue. I should have just kept my Laramie. This Tundra is just a plastic rattle trap for $60+k shouldn’t be the case.
    Kagisexton likes this.
  2. Nov 30, 2022 at 9:49 AM
    #62
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    I've noticed it's worse when when I've left my truck outside rather than in the garage (i.e., when it's cold). I've come to the conclusion it's the velcro that holds the headliner to the roof. I'm not aware of a solution yet.
  3. Nov 30, 2022 at 10:45 AM
    #63
    Kagisexton
    Kagisexton New Member
    Christopher
    2022 Tundra Platinum
    I am right there with you, should have never bought a Toyota. I was sold on the Toyota reputation and turns out I bought the shittiest one they have ever built.
  4. Nov 30, 2022 at 10:49 AM
    #64
    22platitundy
    I'm guessing you haven't had any serious issues with your truck? I agree, the interior noises are annoying but small issues that eventually will have a solution. Rather have the small issues than the big ones.
    TundraWorkHorse likes this.
  5. Nov 30, 2022 at 10:52 AM
    #65
    Kagisexton
    Christopher
    Im not sure why you would you guess that. I’ve had two wiring harnesses go bad, one in drivers door and one in the dash. My entire interior has basically already been apart by the dealer, within the first month of ownership.
    The platinum trim on the sides of the truck has fallen off and been replaced twice now.
    I’ve also been driving around with the camera missing from my passenger mirror and a big dent on the door from it for a month now.
  6. Nov 30, 2022 at 10:55 AM
    #66
    22platitundy
    trade it in
    Eurodriver likes this.
  7. Nov 30, 2022 at 10:56 AM
    #67
    Kagisexton
    Christopher
    I wish there was a dislike button
  8. Nov 30, 2022 at 11:18 AM
    #68
    22platitundy
    I hear you though.. frustrating for a brand new truck. I hope the dealership can/will fix those issues for you.
  9. Nov 30, 2022 at 11:22 AM
    #69
    Kagisexton
    Christopher
    Thanks. Not necessarily brand new though. I’ve had it for almost 8 months now, 28k miles. I’ve been trying to be patient as I know there are not many better options out there as far as half ton pick-ups go. It seems like something is constantly going wrong with this truck.
  10. Nov 30, 2022 at 11:28 AM
    #70
    22platitundy
    You having the headliner noise too? Did the dealer have anything to say about that one?
  11. Nov 30, 2022 at 11:30 AM
    #71
    Kagisexton
    Christopher
    I did and the dealer said there was a headliner clip that was not pressed in all the way and it was sagging low. Not sure what they did exactly, I think they just pressed it back in. All good now. Just battling rear passenger side door rattle now.
    22platitundy[QUOTED] likes this.
  12. Nov 30, 2022 at 11:31 AM
    #72
    Breathing Borla
    Northern Illinois
    what build date do you guys have?
    Im wondering if some of this stuff has been cleaned up with the newer 2023s
  13. Nov 30, 2022 at 11:38 AM
    #73
    22platitundy
    I had a build date in the latter part of 2022. I haven't had any issues outside of some interior rattles/noises. Knock on wood
  14. Nov 30, 2022 at 11:39 AM
    #74
    22platitundy
    Good to know. I will tell my dealer to do the same!
  15. Nov 30, 2022 at 11:58 AM
    #75
    Twinlakes
    Twinlakes New Member
    Burlington Ontario Canada
    2022 Toyota Tundra 1794
    None
    They replaced the weather stripping on the passenger side and it seems to have gone away for now.
  16. Dec 1, 2022 at 11:05 AM
    #76
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    I got my 23 SR5 about 3 weeks ago and both my driver and passenger front doors rattle from time to time. I had to turn the bass down to almost a minimum because it rattles so bad. Plus the driver side center consul release button rattles like an SOB. Have an appointment to have the dealership look at it next week. Hopefully its an easy fix.
  17. Dec 1, 2022 at 11:37 AM
    #77
    Breathing Borla
    Northern Illinois
    do you have the dreaded wind noise at highway speeds?
  18. Dec 1, 2022 at 11:53 AM
    #78
    22platitundy
    I do, but compared to the other interior noises, it's at the bottom of my priority list.
  19. Dec 1, 2022 at 12:27 PM
    #79
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    So far I have been lucky with exterior issues. My main issues so far are the door and center consul rattles and the HVAC is very weak. Very little air blows out of the face vents.
  20. Dec 1, 2022 at 1:53 PM
    #80
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I fixed my front passenger door rattle myself. I pulled the door panel and found that there was a wiring harness between the outer and inner skin of the door (had to pull off the plastic access panel on the inner skin secured in place with the blue twist clips). The wiring harness had two plastic clips that weren't snapped into place on the inner skin. It is easy enough to identify because the clips line up perfectly with the holes in the inner skin.
    My issue was when the audio had certain bass frequencies in it, the door would rattle and was annoying as hell. I have always made it a habit of replacing the door clips with new ones on the panel to avoid any new rattles. They are cheap, and it is good peace of mind. It is an amazing feeling (I know that is a bit dramatic) to be rid of that rattle!!!!
    Mattedfred and RayRay27 like this.
  21. Dec 1, 2022 at 1:55 PM
    #81
    22platitundy
    I've got a new rattle on some frequencies of bass that sounds like it's coming from the weatherstripping near the rear portion of my driver window but I can't pinpoint it exactly. Anyone else experience this?
  22. Dec 9, 2022 at 12:38 PM
    #82
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    Took my truck in today to have the dealership look at the rattle in the doors and the loose driver side center console button. Just text me that that both are totally normal because the two other Tundras on the lot do the same thing. They provided no fix or help. I filed a case with Toyota. Should hear back on Monday from a case manager.
  23. Dec 12, 2022 at 11:14 AM
    #83
    22platitundy
    Keep us updated please!
    RayRay27[QUOTED] likes this.
  24. Dec 25, 2022 at 7:19 AM
    #84
    TunBruh22
    Charles
    22 Tundra Limited
    Yeah,
    I’ve had mine in 4 more times since. New headliner has been ordered, all new seals, they can’t figure out what’s rattling under the bed of the truck, finally got my new front emblem on that blew off the truck while driving, New spare tire assembly has been ordered because that just broke and fell off. Said there is no fix for the sunroof holding water. Every time it is opened water pours into the interior it’s a pretty nice waterfall feature. And my driver door now opens on its own while driving, so that’s a cool new feature as well, for quick and easy exits.
  25. Dec 27, 2022 at 3:37 AM
    #85
    dowdydl
    dowdydl New Member
    I have noticed my front passenger door rattling on several occasions and it does seem to be with songs that have more bass. I pulled over, got out and went to sit in the passenger seat, but I couldn't tell where it was coming from. I rolled the window down and then back up, and that did not correct it. Please share once a solution has been found.
  26. Dec 27, 2022 at 5:26 AM
    #86
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Did you get a response? I called them and got a guy I think was in Nigeria. Took my issue (not your issue) down, gave me a case number, and never heard from Toyo again. Rotten customer service. At least GM or Chrysler would eventually call me back and say tough sh*t here is a free oil change or a couple of months of OnStar. I guess with 1-800 Toyo you just assume your own tough sh*t
  27. Apr 6, 2023 at 5:13 AM
    #87
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Any updates? Dealer has attempted to fix my rattles twice with no luck.
  28. Apr 6, 2023 at 5:21 AM
    #88
    TunBruh22
    Charles
    22 Tundra Limited
    Nope nothing I sold it. I had turbos have blow by oil, the pano roof was leaking into the truck, all the doors rattled to hell, my spare tire assembly came off truck while driving, emblems fell off truck while driving, driver door actually pushed open after the “new” seals were installed. Nothing was ever corrected and they never knew when parts were going to come in.
  29. Apr 6, 2023 at 6:57 AM
    #89
    Breathing Borla
    Northern Illinois
    build date? was this an early build, sure sounds like it
    sorry for that amount of trouble, geez
  30. Dec 4, 2023 at 6:43 PM
    #90
    Satxbrewguy
    Satxbrewguy New Member
    Guy
    San Antonio
    2022 Black Tundra Platinum iForce Max 4x4
    Came with all weather mats, spray in bed liner, front window tint, dash cam, bed extender, power running boards, Avs (advanced package) 4x4
    How did they adjust the latch I loosened screws and it did not move at all. Maybe I have to take the door apart. At first I thought is was the window moving but it is actually door moving against main body of the truck, if you push on all the door windows the doors make the sound, but for some reason only passenger front does it while driving.
