Parts seeker
Discussion in '1st Gen Tundras (2000-2006)' started by MaineFarmGirl, Jan 1, 2024.
  1. Jan 1, 2024 at 11:44 AM
    MaineFarmGirl
    MaineFarmGirl [OP] New Member
    I have a 2001 Tundra 4x4 sr5 6 cyl that run's like a top. I recently blew out the rear end. Can anyone give me any lead's on a complete rear end axles and all?
  2. Jan 1, 2024 at 12:25 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Junk yard, eBay, craigslist.
    Make sure the gearing on the new differential matches the one you're replacing, or you'll have to regear the front differential to match the new rear one.
    Jack McCarthy likes this.
  3. Jan 1, 2024 at 12:29 PM
    shifty` Animals and insects don't do drugs
    What part of the rear end is blown? i.e. what specific symptoms are you seeing? Maybe you don't need the entire housing with axles, diff?
    www.car-part.com will help you find used parts, since new will cost you a pretty penny. But if you really want new, here's how to look up the parts yourself: https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
    With 4WD what gear ratio is inside the donor vehicle is important, I don't know what's inside your V6/4WD (I assume it has sticks on the floor?), but it's an important thing to consider. Rear diff gearing needs to match the ratio of your front diff gearing.
  4. Jan 1, 2024 at 1:04 PM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    Probably cheaper to get a junkyard rear end than a new ring & pinion.
    shifty`[QUOTED] likes this.
  5. Jan 1, 2024 at 1:20 PM
    ZPMAN
    Minnesota
  6. Jan 1, 2024 at 6:13 PM
    MaineFarmGirl
    Thank you all for the info.
  7. Jan 1, 2024 at 8:33 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    So do the early (2000-2003) ABS and non-ABS trucks use the same speedo sensor? I know the later 2004-2006 trucks get their speedo readings from the rear ABS sensors. This only might make a difference if the OP uses the whole axle assembly (and not just the 3rd member).
    Seems like it’s not too uncommon for our 8.4 3rd members to grenade. Before i bought my 2000 tundra from my BIL, the spiders in his 3rd melted down. I got lucky and found him a complete 8.4 rear end (that already had fresh brakes installed). I swapped the axle back under his truck and sold the blown axle to a random guy in craigslist.
    2000-2003
    3.91 - V8, 4x4, auto trans
    3.92 - V8, 4x2, auto trans
    4.08 - V6, 4x2, auto trans or manual trans
    4.10 - V6, 4x4, manual trans
    4.30 - V6, 4x4, auto trans
    2004, Regular Cab or Access Cab
    2004, Double Cab
    4.08 - V8, 4x2, auto trans
    4.10 - V8, 4x4, auto trans
    2005-2006
    3.77 - V6, 4x2, auto trans
    4.08 - V6, 4x2, manual trans
    shifty` likes this.
