Part number for oil filter tube
Discussion in 'General Tundra Discussion' started by Spvrtan, Jul 9, 2017.
  1. Jul 9, 2017 at 2:14 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    @Roman or anyone else know the part number for the tube in the pic attached? Mine somehow got bent and I noticed it when I did my oil change today.
  2. Jul 9, 2017 at 4:39 AM
    Ouch! how that happen? Sorry dont know # can you bend back with some needle nose pliers? are those TRD oil filters any better than stock oem ones?
  3. Jul 9, 2017 at 9:11 AM
    Spvrtan
    Kris
    San Diego, CA
    I have no idea.. it seems that maybe when I threaded the cap back on the tube was at an angle and didn't line up with the female end inside the filter housing itself.
    IIRC, I read somewhere (someone else did the comparison) that the TRD filter has thicker and more pleats. I mostly use them for peace of mind since I'd assume Toyota wouldn't make them separate from the regular filters for no reason.
  4. Jul 10, 2017 at 7:03 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  5. Jul 12, 2017 at 7:14 AM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
  6. Jul 12, 2017 at 7:49 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  7. Jul 12, 2017 at 8:01 AM
    Roman
    Roman
    Franklin, TN
    Yes, except to make that one work, you have to use the tube from your old filter housing. It's for a Venza and isn't quite the same length. Since your tube is damaged, you would have to buy the new Tundra housing AND the Venza housing to make it work.
  8. Jul 13, 2017 at 7:02 AM
    csuviper
    Broomfield, CO
  9. Jul 13, 2017 at 6:46 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Good deal but Dorman's not Toyota.
    Roman likes this.
  10. Jul 13, 2017 at 9:06 PM
    csuviper
    Broomfield, CO
    Correct, it is not.
  11. Jul 14, 2017 at 7:35 AM
    Roman
    Roman
    Franklin, TN
    Tis' true. But it would save from having to buy two canisters. It's up to you, OP. You could order the OEM Tundra can and use it, order the Venza and Tundra cans and swap to a metal one using OEM parts, or go with the aftermarket one. Let us know which route you take. :)
  12. Mar 20, 2018 at 8:18 AM
    blizz86
    blizz86 New Member
    Bringing this thread back since i have no more free oil changes.. if i swap the tube from my oem filter housing to the venza metal housing, it will be the correct length right roman?
  13. Mar 20, 2018 at 8:35 AM
    Roman
    Roman
    Franklin, TN
  14. Mar 20, 2018 at 8:40 AM
    blizz86
    blizz86 New Member
    lmao. thanks man!
    Roman[QUOTED] likes this.
