Part number for 2019 (Black tips) TRD EXhaust?
Discussion in '2.5 Gen Tundras (2014-2021)' started by tanabersx, Jun 6, 2019.
  1. Jun 11, 2019 at 12:14 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Dirty deeds exhaust tip is probably different than Toyota stock exhaust. I have a black tip I put over my single exhaust with no problem I then went to the TRD Duals. Your tip is not stock Toyota
  2. Jun 11, 2019 at 12:17 PM
    Ibanez6224
    Ibanez6224 New Member
    2019 TRD OR
    This is what I'm seeing.
  3. Jun 11, 2019 at 12:18 PM
    Black@Blue19
    Ken
    SE Texas
    If it won’t go on until it hits that’s little nub inside the black tip it is not going to work. You push the black tip on until it hits the nub and then in the back you put the shims underneath the end of the black tip then tighten clamp down. You might have to spread the flanges open to get the spacer pieces (2) in there but if you can not slip the tip over till it get to the skinny part of the exhaust it no worky??!! That’s my opinion without being there looking at it
  4. Jun 11, 2019 at 12:20 PM
    Black@Blue19
    Ken
    SE Texas
    That is what I’m talking about you don’t have stock Toyota Exhaust if you want make sur it will go over the skinny part the get a saws-all cut off the big part and you will be good to go,, but I don’t know where your exhaust will be coming out if you do that
  5. Jun 11, 2019 at 12:21 PM
    Ibanez6224
    2019 TRD OR
    This is most definitely stock. I bought the dirty deeds system, but the tail pipe section is stock. I bought the truck brand new with 12 miles on it.
  6. Jun 11, 2019 at 12:23 PM
    War Machine
    War Machine SSEM # 5 3MW
    Mine wasn’t flared out on the end.
  7. Jun 11, 2019 at 12:23 PM
    Black@Blue19
    Ken
    SE Texas
    Do not know how that can be, so you used the original tail pipe and put it on a different exhaust!??
  8. Jun 11, 2019 at 12:24 PM
    Ibanez6224
    2019 TRD OR
    Correct. That's how the standard systems from dirty deeds work. You reuse the stock tail pipe section.
  9. Jun 11, 2019 at 12:25 PM
    Black@Blue19
    Ken
    SE Texas
    Mine wasn’t flared like that neither.
  10. Jun 11, 2019 at 12:26 PM
    Ibanez6224
    2019 TRD OR
    See, this is weird. Looks like you have a '19 as well. Mine came with this flared end on the exhaust.
  11. Jun 11, 2019 at 12:30 PM
    Black@Blue19
    Ken
    SE Texas
    Yours is off road, mine is a Sport and above SR5, I suppose that’s the difference.
  12. Jun 11, 2019 at 2:09 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    All the tail pipes are the same. I just took a brand new exhaust tip out of the box and went to put it on a Tundra we have sitting on the lot.
  13. Jun 11, 2019 at 2:10 PM
    Roman
    Roman
    Franklin, TN
    I'm betting it was boxed wrong.
  14. Jun 11, 2019 at 2:11 PM
    Ibanez6224
    2019 TRD OR
    That must be the case. The correct part number is on the packaging and everything. But obviously, there's no way it would fit. I'll do a return I guess. Thanks for checking Roman. If you carry the part, I'll buy it off of you.
  15. Jun 11, 2019 at 2:15 PM
    Roman
    Roman
    Franklin, TN
  16. Jun 11, 2019 at 2:19 PM
    Ibanez6224
    2019 TRD OR
    Roman[QUOTED] likes this.
  17. Jun 11, 2019 at 2:33 PM
    Black@Blue19
    Ken
    SE Texas
    Cool Springs Toyota does it again!!!
    Roman likes this.
  18. Jun 14, 2019 at 5:02 PM
    Black@Blue19
    Ken
    SE Texas
    ^^^^^^^^TRD, but I’ll go double check because I told another person the same thing but it has been a couple days??:) Knew it was TRD but I was going to get picture. To dark in the garage. TRD right on the top outside for everyone to see!!!!!! :)
  19. Jun 14, 2019 at 5:19 PM
    #49
    Black@Blue19
    Ken
    SE Texas
    The TRD is on the TRD Dual Cat Back Exhaust. The tips are welded on in the Black chrome or the Bright/or polished Chrome and the tips are oblong more than circular.
  20. Jun 14, 2019 at 5:19 PM
    #50
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
  21. Jun 14, 2019 at 5:20 PM
    #51
    RLHULK
    Rich
    2022 Silverado LT.
    Black chrome with the trd on top.
    They look good but I kind of like the regular chrome better
  22. Jun 14, 2019 at 6:44 PM
    #52
    Black@Blue19
    Ken
    SE Texas
    Looks just fine, was the flat black one on there? Either was it’s fine.
  23. Jun 14, 2019 at 6:47 PM
    #53
    Black@Blue19
    Ken
    SE Texas
    ^^^ those are welded on like the Tundra ones you are correct.
  24. Aug 29, 2019 at 3:18 AM
    #54
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    @Roman or @Reveler00 or anyone have a pic of the black OEM on a silver Tundra maybe zoomed out a little? Probably going to buy this one, just wanted to make a final decision on black or chrome.
  25. Aug 29, 2019 at 7:44 AM
    #55
    Roman
    Roman
    Franklin, TN
    I do not. I just did a Google image search and couldn't find anything there either.
  26. Aug 29, 2019 at 8:47 AM
    #56
    TNTundra7
    TN
    2016 SR5 4WD 5.7L
    @Roman No worries. Thanks for checking. I've heard conflicting reviews on whether or not these alter the sound. Is there any difference at all? I just have the OEM exhaust. Thanks.
    I live about an hour away from Franklin, may come pick one up this weekend.
  27. Aug 29, 2019 at 8:57 AM
    #57
    Roman
    Roman
    Franklin, TN
    I have not heard any difference in the sound when just adding a tip to the exhaust.
    Sounds good. Make sure to place your order ahead of time through the online store, so we can hold one aside for you.
  28. Aug 29, 2019 at 9:12 AM
    #58
    TNTundra7
    TN
    2016 SR5 4WD 5.7L
    Outstanding. Thanks again.
    Roman likes this.
  29. Feb 26, 2020 at 12:24 PM
    #59
    ATXHusker
    ATXHusker New Member
    Chad
    Austin TX
    2016 TRD Pro CM Quicksand
    Ranch Hand brush guard, TRD rear sway bar, TRD air filter, Husky front mats, Weathertech rear mat, LED interior lights, tow mirrors, Salex console organizer, key ring light mod, AJT key fob, Gator bed cover
    @Roman I have a 2016 TRD Pro w/ the chrome exhaust tips, am I able to get the black "TRD" tips or would it have to be the black logo tips? Thanks!
  30. Feb 26, 2020 at 2:14 PM
    #60
    Roman
    Roman
    Franklin, TN
    With the TRD exhaust, Toyota does not sell the tips separately. They only come with the tailpipe section of the TRD exhaust system.
