Part # for 2006 DC Foglight Relay
Discussion in '1st Gen Tundras (2000-2006)' started by HBTundra, Jan 10, 2021.
  1. Jan 10, 2021 at 2:40 PM
    HBTundra
    HBTundra [OP] New Member
    2006 DC 2wd
    I think I purchased the wrong relay for my foglights.
    I purchased the Denso part #567-0003 which worked on my friends 2003 AC Tundra under the hood fuse/relay box.
    But from my reading here, mine is located in the cab, up/under the backside of the fuse panel.
    I was hoping someone here could steer me in the right direction for the correct foglight relay part # for a 2006 DC.
    These are plug-and-play foglights, not LED/HID or any 'mods' etc.
    Thanks in advance.
  2. Jan 10, 2021 at 3:35 PM
    Professional Hand Model
    Hand Protectors
    Try this. Double check first.
    tunyota likes this.
  3. Jan 10, 2021 at 3:38 PM
    HBTundra
    2006 DC 2wd
    Thank You . . . I'll call the local 'stealer' in the am.
  4. Jan 10, 2021 at 7:13 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Enter your VIN into this site to search for and identify compatible parts: https://www.toyotapartsdeal.com
    Here is another sites I use to find OEM parts: https://densoautoparts.com/find-my-part.aspx
    I have a 2006 Regular Cab that did not come equipped with fog lights from the factory for which I installed. The relay I needed was located in fuse box within the engine bay.
    https://www.amazon.com/gp/product/B002Y39J9O/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    HBTundra[OP] likes this.
  5. Jan 11, 2021 at 7:16 AM
    HBTundra
    2006 DC 2wd
    Thank You very much !
    That site is great! Appreciate it!
    tunyota[QUOTED] likes this.
  6. Jan 11, 2021 at 6:46 PM
    tunyota
    @HBTundra happy to share! :thumbsup: many of us have made mistake of ordering the wrong part in our excitement before confirming with 100% certainty. In my case I ordered the fog light switch that mounts into the dash to the lefthand side of the steering wheel only later to realize the switch for my model year was in fact located on the headlamp switch assembly/lever.
    That Denso part number should be the equivalent to the OEM part# @Professional Hand Model previously shared.
    Let us know what you discover!
    :cheers:
  7. Jan 12, 2021 at 4:36 PM
    HBTundra
    2006 DC 2wd
    Just got them all hooked up and working. The part number for the relay was 90080-87026. $17.00 at stealership.
    On my 2006 DC the slot for the relay was located on the backside of the fuse panel in the cab. Weird location.
    Releasing the parking brake and putting a small mirror on the floor and a flashlight pointing up, I was able to get in the general area.
    My friend texted me the schematic after that identified 'R5' as the fog lamp relay.
    Then by 'feel' I was able to find the relay slot. Fortunately it's at the bottom and in the middle, so it was pretty easy.
    No need to take off the dash panel etc.
    Thanks again for all the help.
