Parking sensor screaming non-stop
Discussion in '2.5 Gen Tundras (2014-2021)' started by SD Surfer, Dec 28, 2022.
  1. Dec 28, 2022 at 8:15 AM
    SD Surfer
    SD Surfer [OP] Globe Trotting Bon Vivant
    Bruce
    So Cal
    So it's been lightly raining/drizzling overnight, and when I got in the truck this morning the parking sensor won't go off. Constant tone, not beeping.
    I park close enough to my garage door that it beeps but stops as soon as I back away.
    Anybody had this happen, and did it fix itself when it dried out?
    '19 CM SR5/TRD 4X4
    Thanks in advance!
    bulldog93 likes this.
  2. Dec 28, 2022 at 8:17 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White Tundra TRD Pro
    Something might be on the sensor. Like mud or such.
    SD Surfer[OP] likes this.
  3. Dec 28, 2022 at 8:27 AM
    SD Surfer
    Bruce
    So Cal
    Yeah, that was my thought as well. I got out and gave them a quick wipe but didn't see anything.
    bulldog93[QUOTED] likes this.
  4. Dec 28, 2022 at 4:12 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    My front sensors started doing this in the rain but only when the truck is stopped. When moving there's no issue. Mine seemed more like the right side. I wiped it a few times to try to adjust the sensor position and it seemed to help. If it gets bad enough I'll pull the fog light and see if i can reach the sensor from inside.
  5. Dec 28, 2022 at 4:59 PM
    SD Surfer
    Bruce
    So Cal
    Mine did it stopped, moving, turned it off then back on when I was in the street nowhere near anything, still screaming.
    Now that it's dried a bit, it has stopped. Apparently, the fix is to turn it off until the sun comes out. :rolleyes: We shall see, I just get nervous about electronics and water.
  6. Dec 28, 2022 at 5:21 PM
    Rocko9999
    Rocko9999 New Member
    Maybe seal on sensor is compromised and moisture is getting in?
  7. Dec 28, 2022 at 5:59 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Mine did start after I had the dealership adjust the front bumper fitment when I deleted chrome and went to plastic bumper caps. Something probably got tweaked then.
  8. Dec 28, 2022 at 6:01 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    the front passenger side does the same thing after a light rain. I would have to take the sensor off the bumper to wipe it clean, disconnect it and use a compressor to clean the connection. annoying as hell
  9. Jan 17, 2023 at 5:37 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    That happened to me the other day. Front left. When I stopped at a light I just turned it off and back on and it stopped.
