Parking lights not working
Discussion in 'Lighting' started by cosmichippo, Jun 23, 2018.
  1. Jun 23, 2018 at 11:48 AM
    cosmichippo
    cosmichippo [OP] New Member
    Cincinnati
    2014 Tundra 1794 Silver Sky Metallic
    In search of tonneau and bed liner ...
    2014 Tundra 1794 Ed.
    Parking lights are not working but same bulbs work as turn signals and hazard lights.
    I checked the "TAIL" fuse under the instrument panel but it looked OK.
    What else could it be?
  2. Jun 23, 2018 at 12:05 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    1794 and Platinum don’t use the Amber bulb as Parking lights only LED DRL and ambers in side corners
    The ambers in center only works as hazards and turn signal
  3. Jun 23, 2018 at 12:13 PM
    cosmichippo
    Cincinnati
    Thanks for the information. But now I'm confused about why there is a "parking lights" setting on my headlight control switch.
    Is there a modification to make the lights work as parking lights?
  4. Jun 23, 2018 at 2:30 PM
    iHacker
    iHacker SW TRD PRO
    Sure there’s a modification to make them work as parking lights same as SR5 and others trims with Amber DRL,
    Your parking lights are only the LED strip dimmed and Amber side corners nothing in the center only for turn signal and hazards.
    BlueBottle likes this.
  5. Jun 23, 2018 at 2:31 PM
    iHacker
    iHacker SW TRD PRO
    The mod consists in creating a Jumper wire between side maker violet wire and the MT spot in turn signal plug
  6. Jun 23, 2018 at 2:34 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    The man is right. If you want it on get an sr5. #1794problems
    iHacker likes this.
  7. Jun 23, 2018 at 2:34 PM
    iHacker
    iHacker SW TRD PRO
    The jumper is something like this, one for each side
    Erichudgins likes this.
