Parking brake cable rubs leaf spring
Discussion in 'Suspension' started by dspilot, Mar 5, 2020.
  1. Mar 5, 2020 at 10:26 AM
    dspilot
    dspilot [OP] Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    I promise y’all that I keep searching before starting a new thread, but keep coming up short.
    Finishing up getting my lift installed and noticed that with the 1.5 inch blocks in the rear, that now the parking brake cable is mashed against the leaf spring. Same on both sides. It’s more than just a rub, its mashed against it pretty hard. Can’t be good long term. Any solutions?
    98D302EF-9276-477E-A3F3-4E82660BE751.jpg AAC9E0D7-071A-4DF0-B96B-A58891D705E0.jpg
  2. Mar 5, 2020 at 10:37 AM
    coTony
    Tony
    Montrose, CO
    Is that Tundra lowered? That is really close to the frame
  3. Mar 5, 2020 at 10:40 AM
    dspilot
    North Mississippi
    I think that’s just the camera angle.
  4. Mar 5, 2020 at 10:46 AM
    ZPMAN
    Minnesota
    They should have given you cable mount extensions. And also check your break lines in center with axle hanging, they might also be a little tight.
    dspilot[OP] likes this.
  5. Mar 5, 2020 at 10:54 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    This was my mitigation for this issue. Works well still.
    NewImprovedRon and dspilot[OP] like this.
  6. Mar 5, 2020 at 11:53 AM
    ZPMAN
    Minnesota
    Picture of the cable bracket extension.
  7. Mar 6, 2020 at 4:58 AM
    dspilot
    North Mississippi
    I was able to bend the bracket a little. It got the cable off the spring by about half an inch. Forgot to take a pic.
    NewImprovedRon likes this.
  8. Aug 16, 2023 at 4:50 PM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Does anyone here know how to take the e brake cable off of the truck, I’m doing an axle swap and need this axle off now, but am being held up because I cannot find anything on how to remove it. Thanks.
