Park indicator light stays on
Discussion in '1st Gen Tundras (2000-2006)' started by Curtisc, May 20, 2023.
  1. May 20, 2023 at 11:23 AM
    Curtisc
    Curtisc [OP] New Member
    Curtis
    05 tundra 4.7 DC 2 wheel dr.
    New water pump & timing belt & 175K
    Need help,
  2. May 20, 2023 at 11:25 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    So when you shift the column shifter, the light for park is the only one lit?
  3. May 20, 2023 at 12:12 PM
    Curtisc
    Curtis
    No, even when the truck is off and key removed the light stays on
  4. May 20, 2023 at 12:25 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    There are a few things we've seen come thru here with this problem....
    By chance is your clock or any other items staying on ?
    Trailer Harness
    Tail Light Relay, behind driver side fuse panel
    and in some cases with water penetration on drivers side, the Integration Relay itself has corrosion
  5. May 20, 2023 at 12:39 PM
    Curtisc
    Curtis
    Yes, the radio stays on as well
  6. May 20, 2023 at 12:50 PM
    shifty` All my rowdy friends have settled down
    I'm suspecting this may be another case of windshield or a-pillar leaking into the interior fusebox, which we've seen plenty of times... (pics and more pics).
    NickB_01TRD and w666 like this.
  7. May 20, 2023 at 3:59 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah seems like it's staying in "accessory" mode. Could also be a keyswitch issue but water intrusion definitely shouldn't be ruled out.
    Mr.bee likes this.
  8. May 20, 2023 at 4:16 PM
    Curtisc
    Curtis
    Thanks everyone, I’ll be back on it tomorrow. I’ve checked every fuse inside and under the hood, every fuse test good. The only way I’ve been able to make it go off is to pull either the DC “short” fuse or radio fuse
  9. May 20, 2023 at 6:31 PM
    Well, if you looked at the pics I linked, it's what's inside the box you probably need to be worried about.
    But that said, did you inspect carefully under the hood and inside the driver's side kick panel for any splicing someone has done? T-taps, other bullshit like that? Any signs of an aftermarket alarm?
    This stinks of the kind of stuff you see in one of those two cases: Water got inside the cabin fusebox, or an alarm or other aftermarket component is shorting because someone used scotch-lok style taps.
