Paranoid - Did my mechanic fill my ATF correctly?
Discussion in '2.5 Gen Tundras (2014-2021)' started by telemeister62, Jan 2, 2025.
  1. Jan 7, 2025 at 5:56 AM
    lr172
    lr172 New Member
    07 DC
    WHEN your trans shifts up or down is controlled by the ECU electronically. Has NOTHING to do with fluid. HOW it performs the shift or how well it hangs on to the gear can be influenced by fluid.
    dondino likes this.
  2. Jan 7, 2025 at 8:24 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Once you've confirmed the correct amount of fluid is in there from the start, you can absolutely just drain and add back exactly what you drained. I probably wouldn't do it on a warm transmission.
    For me, to bother with measuring out everything and getting it "exact", it is about the same amount of effort as just draining it, filling it and then doing the check plug procedure.
    AZBoatHauler likes this.
  3. Jan 7, 2025 at 9:37 AM
    telemeister62
    telemeister62 [OP] New Member
    Since mine is a 2019 with no cooler - I assume the only part is checking the overfill after it reaches temp? No pinning?
    koditten likes this.
  4. Jan 7, 2025 at 10:17 AM
    AZBoatHauler
    So.Arizona
    Right - and the temp is when the ATF is 99 degrees in the pan so you need a way to monitor that from the sensor.
    ghott86 likes this.
  5. Jan 7, 2025 at 11:38 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Correct no pinning if you have no thermostat to pin. I l myself did the add back what drains out because at first the check procedure sounded complicated. Then I decided to try it and realized its actually easier to do the check procedure than to measure out the fluid. Once you do it once you'll only get faster at it.
    ghott86 and WILLINH like this.
  6. Jan 7, 2025 at 5:08 PM
    koditten
    Kirk
    Midland of the Mitten
    You do not have a thermostat to pin. So you are correct.
    ghott86 likes this.
  7. Jan 8, 2025 at 7:08 AM
    telemeister62
    He had the truck for 2 hours. Would that have even been enough time to get it lowered to temp?
  8. Jan 8, 2025 at 9:16 AM
    AZBoatHauler
    So.Arizona
    Doubt it. He probably measured and replaced same volume.
  9. Jan 8, 2025 at 9:24 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    When I did mine on the 30th, my temps were still in the lower 110's after 3 hours of sitting. I don't know the temp when I parked it but I had come home from work, ~30 min highway drive. So, likely around 180-190 degrees.
    After 4 hours it was at low 90's and I was able to drain and fill. You do lose a small amount of heat with drain and fill since you will be adding ambient temp fluid to the pan.
    Now, he could have thrown a fan on it. Not sure if it would really drop the temp that fast though.
  10. Jan 8, 2025 at 10:27 AM
    koditten
    Kirk
    This is one of the reasons I'm skeptical about a shop drain and fill. I just do not see any tech waiting very long for the temp to stable. Drain and fill what exactly what comes out.
    The only ones that will follow the procedure exactly are those of in this thread that want to do it that way. ( Not me)
  11. Jan 8, 2025 at 11:33 AM
    telemeister62
    I’m bringing it to a dealer tonight to do another drain and fill. They said they need to let it sit overnight to do the full process and check temps, etc. and seemed very familiar with the process for checking it.
    I’ll be out another $200 but it’s a lesson learned and I guess it won’t hurt to get some more of the old fluid changed out. I should have pressed the other shop more about it.
  12. Jan 8, 2025 at 12:41 PM
    telemeister62
    that’s no good right?
  13. Jan 8, 2025 at 12:45 PM
    AZBoatHauler
    So.Arizona
    In theory - the fluid expands when hot. So if you go by volume you could over fill using room temp fluid off the shelf as equal volume. Is it enough to make any difference - I highly doubt it.
    I think it would be more of a problem if you pull the check plug while the trans is at full temp - you’d end up draining more fluid than you should and could make it low.
  14. Jan 8, 2025 at 12:51 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’ve always been curious how much this fluid expands. I can’t imagine it increasing by more than an ounce or so.
    I’m no expert though.
    AZBoatHauler[QUOTED] likes this.
  15. Jan 8, 2025 at 1:39 PM
    telemeister62
    I’m so torn if I should bring it to the dealer for another drain and fill so I can have some peace of mind it’s been leveled according to Toyotas way
  16. Jan 8, 2025 at 2:37 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    If it was me, I would just check your fluid at the right temp (or close) and see where it’s at. Or the truck me smooth itself out too with the new fluid.
    If you do go and have another D/F done, at least you’ll get more of the old fluid out.
    There’s plenty of DIY tutorials on how to do it though if you wanted to save the money and do it at home.
  17. Jan 8, 2025 at 6:48 PM
    telemeister62
    Just dropped it off at the dealer. They need it overnight to cool off so they can do it right and check the temp. I called my independent and asked why they were able to do it in an hour while hot, and he said “that’s just how we do it”. Not sure who’s right but I feel comfortable with the dealer stating it needs to be cool so it can be checked at a specific temp.
    Jaypown[QUOTED] likes this.
  18. Jan 8, 2025 at 7:48 PM
    lr172
    lr172 New Member
    07 DC
    Thats just how we do it translates to we really don’t give a sh!t about the right way, just the fast way. Shows a total lack of competence and ethics and should be your cue to find a better shop. Its ok if a shop doesn’t follow procedures as long as they tell you that along with a rationale for their different approaches. Often factory procedures are overly conservative and short cuts are acceptable. In this case, it is no good. They mAy be over filling it a bit which is fine, but they may be just measuring what came out and match, assuming the previous person was more competent and did it correctly.what if the last shop was even more incompetent and under filled it by 2 quarts? You can see what the chain of laziness and incompetence can lead to.
    ghott86 likes this.
  19. Jan 9, 2025 at 7:03 AM
    #49
    fallen0
    fallen0 New Member
    Minnesota
    It's that and a few other reasons that I, like many others here, have decided to take the ownership of maintenance for our vehicles/equipment.
    It is not glorious work and most days, I would rather not do it at all. But, I know that if I do it, following the documentation from the manufacturer, I can get it done and done right!
    ghott86 likes this.
  20. Jan 9, 2025 at 9:34 AM
    #50
    telemeister62
    I do wish I was a bit more mechanically inclined. It’s tough to find the time to do it!
  21. Jan 9, 2025 at 10:26 AM
    #51
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    Is an ATF exchange (which my Toyota dealer does for me and I believe is a good price considering it’s all new fluid) the same as a flush? If not, how is a flush different?
  22. Jan 9, 2025 at 10:52 AM
    #52
    telemeister62
    Drain and fill, taking out what’s in the pan
