Papasmurf's not a tundra off-road "budget" build
Discussion in 'Other Builds' started by papasmurf, Sep 20, 2019.
  1. Sep 20, 2019 at 7:30 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Mountun Goat, 831Tun, 15whtrd and 6 others like this.
  2. Sep 20, 2019 at 8:08 PM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Don’t be a pussy. Put 40’s on that bad boy and do all the double black diamond trails.
    831Tun, 15whtrd, Rica25 and 3 others like this.
  3. Sep 21, 2019 at 7:43 AM
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Yeah I don’t foresee that being an issue w this one, is the 7.3l and hopefully because it’s the 2500 the CV’s are a little more stout. Yeah the rock sliders I think will be key to help get in and out of the truck... plus I’m taking a bunch of weight out of it by ditching all 4 doors. The truck has tons of power even running like shit. I easily did 85 on the freeway driving it home.
  4. Sep 21, 2019 at 7:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    :fistbump:
    Yeah buddy!
    Rica25, Casper421 and jewsNbrews like this.
  5. Sep 21, 2019 at 8:22 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The 4l80e is a really strong trans. The front diff and CV’s on the 2500 models are very strong. 1/2 ton models were iffy with 35’s but many many people ran big tires for year on the 2500’s. I used to have a 2500 truck with a 6 inch lift and 35s on that body style.
    papasmurf[OP] likes this.
  6. Sep 21, 2019 at 4:21 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    All the parts laid out...
    Moving the truck into position now and time for a power washing!!! Then stripping the interior
  7. Sep 21, 2019 at 4:29 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    We hit the Parker 425 every year. Love offroading in Parker. Tho.. I'm just an hour from there.. so boating in the summer and offroading in the winter is a no brainer
  8. Sep 22, 2019 at 2:29 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    So yesterday I degreased and power washed the motor and engine bay... I guess you can polish a turd!
    Then today I stripped the entire interior... next step is prep for the bed liner on the inside...
    So much room for activities!
  9. Sep 22, 2019 at 3:37 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    outstanding!
    Rica25, papasmurf[OP] and jewsNbrews like this.
  10. Sep 22, 2019 at 5:52 PM
    KevinK
    Tundras to Sedona
    Will you offer shoe rentals when you open the bowling alley? I need a 15.
  11. Sep 22, 2019 at 6:53 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    How many seats are going to be in there when you're done?
    Rica25 likes this.
  12. Sep 22, 2019 at 7:19 PM
    Flatzby
    Flatzby New Member
    '18 Crewmax Limited MGM TRD OR
    That thing is going to be a blast! I wish I had the room and time for something like this.
    Rica25 and papasmurf[OP] like this.
  13. Sep 22, 2019 at 7:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Which bed liner do you have in mind?
    Sunnier likes this.
  14. Sep 22, 2019 at 8:15 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Lol not mine. Reading some if the replies was funny though
    papasmurf[OP] and KevinK[QUOTED] like this.
  15. Sep 23, 2019 at 3:56 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    In. Looks like fun!
  16. Sep 23, 2019 at 6:57 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    So as of right now, it will have two pro suspension seats for driver and passenger then a 3 row pro bench seat, then a 2 row pro bench seat... if I can ram more in I will... but we also wanted room to put a cooler in the back, so we will see how it all plays out 7-8 people will be the goal
    :rofl::rofl::rofl:
    Of course!!! Would you like the stinky spray in them too, or do you prefer the sweaty shoe?
    831Tun, 15whtrd and KevinK[QUOTED] like this.
  17. Sep 23, 2019 at 6:59 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Not sure yet. One that is self applied spray or roll on don’t really care not trying to spend a ton just create some sound deadening and easy cleanup.. any thoughts or suggestions are appreciated
  18. Sep 25, 2019 at 4:11 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Ok so here’s the slow progress update... the further I dug the more I found I needed to fix, so aside from normal tuneup stuff, the following is being done
    just pulled valve covers, gaskets were bad, I cleaned them and painted them...
    New gaskets back on then it all goes back together along w replacing the hoses for PCV valve, evap, a/c vacuum lines , and a few egr vacuum lines, they were all dry rot and literally falling apart...
    As well as new knock sensor, pcv valve, throttle position sensor, serpentine belt, k&n air filter, transmission filter and pan gasket,
    Then I’ll take it for a oil change (I hate doing them w a passion)
    Should be starting on the lift Sunday, and my new rear seats were ordered today 3 weeks to have them made. PRP bench seats to match the fronts!!
    So that’s the update for now, just waiting for paint to dry on valve covers and a part to arrive.
    Should have some big progress pics soon!
    Oh and I’ll be starting on the tube doors next week as well once my door latches arrive.
  19. Sep 26, 2019 at 10:25 AM
    #49
    KevinK
    Tundras to Sedona
  20. Sep 26, 2019 at 10:42 AM
    #50
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    bwhahahahahahahahahaha :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    yup exactly!!
    Mountun Goat, Rica25, Sunnier and 6 others like this.
  21. Sep 30, 2019 at 11:38 AM
    #51
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    OK so weekend update!
    Made some good progress, got stuck on a few things...
    the damn new ball joints were not going in, so going to have to take lower control arms to have them pressed in. very annoying. Also still working on pressing out and in the new bushings for the front end. lots of parts getting replaced in the process so it's slower than we hoped. We did get the rear done and rear wheels and tires on.. and it is epic! LOL and really tall, so gonna have to install some sliders / steps to help get into this tall bad mamma jamma
    so here are the pics!
    So the front is almost done being torn down, just have a few steering components to tear off and replace.
    Other than that its going well!
    Also got the motor put back together so tune-up is all done, just have to replace the serp belt, and put the intake back on, but waiting on a part to put my erg tubes back on. that's a 30 min deal but not important till I get the front end back together. Gonna start on the tube doors this week as well. I'll post pics as I go
    oh,and the new seats are sooo awesome!
  22. Sep 30, 2019 at 11:51 AM
    #52
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I thought you were putting 37's on??? Why did you put this 32" on? :rofl:
    Mountun Goat, Rica25, KevinK and 4 others like this.
  23. Sep 30, 2019 at 11:53 AM
    #53
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yeah. Looks like it needs 44 inch super swampers to really fit the era
  24. Sep 30, 2019 at 12:04 PM
    #54
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I know right!! they look small LOL but they work , military humvee tires FTW!!
  25. Sep 30, 2019 at 12:05 PM
    #55
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah these were so cheap though, 200 for a full set of wheels and tires... cant beat that
  26. Sep 30, 2019 at 12:19 PM
    #56
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    How I read it :boink:
    That's a lot of fixing so far, gonna be awesome when it's done. You really need a rolling work bench or something to get parts off the ground to work on.
    papasmurf[QUOTED][OP] likes this.
  27. Sep 30, 2019 at 12:24 PM
    #57
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    hahahahaha you are not wrong... i will say this poor truck was not "well taken care of" so fixing a lot of small things that were neglected. Yeah you are not wrong... not too far in the future, ill have a 40x40 shop with lift and everything so at that point ill be off the ground. ugh cant wait maybe 4-6 mounts out and the shop should be done. i hope>....
  28. Sep 30, 2019 at 12:40 PM
    #58
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hope so, that would be sweet. I hate working on parts on the ground. Last few years working on cars in parking lots really made me appreciate garages and work benches.
    aperezsh and papasmurf[OP] like this.
  29. Sep 30, 2019 at 12:43 PM
    #59
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah some stuff i take into the garage and work on my big welding table, but for leafs easier to do next to the truck in this case. But for sure working on the ground sucks, cant wait to get my shop done.
    Rica25 and Darkness[QUOTED] like this.
  30. Oct 8, 2019 at 8:03 AM
    #60
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Weekend Update....
    Made great progress, got the front end done. Ran into a little issue with the 4th wheel and tire, so im sourcing some new wheels for the 16.5" military tires. Ill have that sorted in the next few days so it still has one jack stand under it, but where it sits right now is full ride height.
    Also, this is my godson, hes 6 1/2 and a little over 4ft tall to give you some perspective of overall vehicle height.
    next up is tube doors and seats... started working on the seat mounts yesterday... made some progress, need to get some pictures, basically for the fronts im using the factory seat mounts and modifying them to work with the PRP seats. The rears will be full custom mounts.
    and for the tube doors im going with this style design, ignore the measurements, those are for a jeep door. But the shape and style is what ill be doing with 2" dom .065 wall steel, decided to go thinner wall so the doors are not too heavy, but they will have offroad slam latches.
    https://www.4xinnovations.com/Tube-Door-Slam-Latch-Kit-Included-with-all-door-sets_p_96.html
    That's it for now...I'll update you all in a few days.
    Mountun Goat, Vizsla, BestGen and 4 others like this.
