Paint vs. Powdercoat
Discussion in 'General Tundra Discussion' started by SullyMoto19, Oct 24, 2017.
  1. Oct 24, 2017 at 6:52 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    I was trying to get a quote yesterday on paint matching my endcaps. My guy told me I should paint them, other than powdercoat. He said paint would be spot on and the powdercoat has a chance to not be correct....
    can anyone verify?
    or explain the difference between the two?
    Jsena likes this.
  2. Oct 24, 2017 at 7:56 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well, I believe the paint is more likely to match but not nearly as durable as PC. I don't know much about PC but, depending on the color you want, they should be able to get pretty close.
  3. Oct 24, 2017 at 7:58 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I mean, I know a lot of people get them powdercoated, and they seem to look pretty spot on to me. but I guess I don't really understand the difference
  4. Oct 24, 2017 at 8:04 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is typically applied electrostatically and is then cured under heat to allow it to flow and form a "skin".
  5. Oct 24, 2017 at 8:07 AM
    SullyMoto19
    Tyler
    Houston, Texas
    so its thinner and chips easy and PC is a little more durable? that's what I'm getting outta that haha
    Jsena likes this.
  6. Oct 24, 2017 at 8:49 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    powder coat won't match the level of gloss of clear coat but it is more durable
    Desert Dawg and Jsena like this.
  7. Oct 24, 2017 at 9:25 AM
    Borgs
    Borgs New Member
    PA
    I pc'ed mine matte black and think they look pretty friggin awesome.
    Jsena likes this.
  8. Oct 24, 2017 at 9:36 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Picking my bumper ends up today from powder coat shop.. I’m 100% sure that paint is gonna be spot on, as opposed to powder coat. I know powder coat is going to be a lot more durable.. plus I’m sure it’s going to be cheaper. The white is almost the same for mine. Doesn’t really bother me. Nobody will notice unless you tell them and make the look..
    I don’t think the matching grill/hood bulge stuff sent from Toyota really match.. they look diff to me but ¯\_(ツ)_/¯
    TheBeast, Flyinryank and Prostar 190 like this.
  9. Oct 24, 2017 at 9:37 AM
    If you paint them and need to touch one up you can but if you powder coated them that's it can't touch up unless it's sandblasted and completely redone.
    Jsena likes this.
  10. Oct 24, 2017 at 9:51 AM
    Borgs
    Borgs New Member
    PA
    I touched up my powdercoated front passenger end. While it doesn't look totally unbelievably awesome, it looks fine and unnoticeable unless you mention it.
    Jsena likes this.
  11. Oct 24, 2017 at 11:43 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Well just got them back.. gonna slap me on 3EDAF02F-6814-41CB-9F5D-1222EF7E2DFF.jpg
  12. Oct 24, 2017 at 11:45 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Just curious, if you don't mind me asking, about how much did that run ya? Been thinking about doing the same
    Jsena[QUOTED] likes this.
  13. Oct 24, 2017 at 11:47 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I called about 5 shops here in Vegas. Going rate looks like $80-150. I paid $100
    AlexWV[QUOTED] likes this.
  14. Oct 24, 2017 at 11:50 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I PC'd mine and I can tell a slight difference. Not sure if due to powder coat vs paint of if wrong white was picked. Unless you're looking for it you won't notice, but I did because I see my truck daily.
    Prostar 190 and Jsena like this.
  15. Oct 24, 2017 at 11:54 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Dang! I wanna see em on! Who’d you go through?
  16. Oct 24, 2017 at 11:55 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    This shop on sunset and Gibson. I told them if they turned out good, I’d send them some business .. I’m gonna put them on now and post pics on build page.. bbs :thumbsup:
  17. Oct 24, 2017 at 12:00 PM
    SullyMoto19
    Tyler
    Houston, Texas
    that's my problem.. im very picky and a slight difference would drive me insane. even if its just a slight difference, I would tear my hair out
    Saltyhero13, Mscott2 and Prostar 190 like this.
  18. Oct 24, 2017 at 12:17 PM
    Borgs
    Borgs New Member
    PA
    My truck is black. So the matte contrast looks good because it picks up the matte plastic middle bumper, more door handles, matte wheels and matte badges. White may be a different story.
  19. Oct 24, 2017 at 12:21 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    It’s ok to be picky
    BUT
    not very picky......
  20. Oct 24, 2017 at 12:42 PM
    tomsinamerica
    Tom
    Wilmington, NC
    If you have a white truck, and you look hard enough, you'll probably see a difference between painted plastic and painted sheet metal, white is a mf'er to match, far far less forgiving than any other color. I'd be willing to bet, even with 040 Toyota paint, you'd see a difference in whites if you look hard enough.
    SuperSilverTundra likes this.
  21. Oct 24, 2017 at 1:24 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    I tried powder coat on the front ends MGM and it ended up not matching. Got them painted over the powder. Costly mistake.
    SullyMoto19[OP] likes this.
  22. Oct 24, 2017 at 1:28 PM
    SullyMoto19
    Tyler
    Houston, Texas
    what is the price difference in paint an powder?? substantial or about the same
  23. Oct 24, 2017 at 1:35 PM
    WatTundra
    WatTundra New Member
    Kenny
    FTW, TX
    2016 MGM Tundra
    Stock as a rock minus tint
    I went with PC and regret it. The color on the swatch was perfect but the outcome...not so much. I have MGM and my caps are a bluish gray.
    Very costly, I need to have mine painted but don't want to spend the money again with Christmas around the corner.
  24. Oct 24, 2017 at 1:38 PM
    SullyMoto19
    Tyler
    Houston, Texas
    yeah, I cant do that... and id feel like an ass if I called them out for their work in their own shop. that would drive me crazy
    Prostar 190 likes this.
  25. Oct 24, 2017 at 2:11 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    Trust me I did call them out but I "chose the color". Still doesn't sit well with me but unfortunately lesson learned
  26. Oct 24, 2017 at 2:17 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    You can see the difference in this picture. Huge difference
  27. Oct 24, 2017 at 2:21 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Well I spent $240 on powder coat then another $350 to paint them. So all in $590.
    It sucks the powder coat shops cant put your color in a computer and come out with the right color powder. I had to pick also and it was a lot closer than @WatTundra truck but I couldn't deal with it.
  28. Oct 24, 2017 at 4:53 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Yeah sorry to hear that.. honestly has me thinking that I don't even wanna chance it.. I'm not an angry person by any means and I'm super calm, but I would explode.. I'm very peculiar about what I spend money on, and I wouldn't have that
  29. Oct 24, 2017 at 6:48 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    Yeah I hate it, I'll have to spend another 350 to fix it. Not exited about it but it will get done next year
