Paint protection when using Fender Flares
Discussion in 'General Tundra Discussion' started by fatalkhaos, Oct 23, 2018.
  1. Oct 23, 2018 at 9:51 AM
    fatalkhaos
    fatalkhaos [OP] New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    If you are using fender flares then you probably understand that it is probably rubbing through the paint.
    After 2 years of having my 2016 Limited CM, I decided to trade in the truck. I was pissed when I saw that the after removal the fender flares had created a distinct rub line in the paint.
    I wouldnt have been as mad if Bushwacker hadn't claimed "No Rub"
    The line was so bad it could not be blended without serious wet sanding by a professional.
    Anyone that watches Gear Runner can see what they do to the paint after just 6 months.
    I enjoy the look of them but refused to reinstall them on the new TRD PRO till i found a solution.
    I looked into 3M Paint Protection but that is around $400 as the amount of 3M used is rather large for 4 fenders.
    The guy at the 3M/XPEL Paint Pro offered up to use between 1/2in and 1in clear Door edge guard.
    I also found this which is similar to the idea above...
    https://www.sharptruck.com/pdm-dura-strip-protective-fender-flare-tape-kit
    I will be trying it out here within next week or 2 and will take some pics of the install.
    NewImprovedRon and GNTundra like this.
  2. Oct 23, 2018 at 9:56 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    My bushwackers have a new rubber edge. I never plan on removal. They look too bad ass to even think about removal. Good luck. DE251CBB6-9C75-4EBD-A2AE-7305BD32BB49.jpg
    GNTundra likes this.
  3. Oct 23, 2018 at 10:01 AM
    fatalkhaos
    I never thought I would pull them off either until I liked them so much I wanted to keep them and put them on my new truck. When the dealership was not going to add money to my trade for leaving them on I quickly pulled them off.
    This is more for those that want a way to protect the truck regardless if they pull them off or not.
    NewImprovedRon likes this.
  4. Oct 23, 2018 at 10:02 AM
    fatalkhaos
    Mine also had a rubber edging but that edge is what vibrates against the paint and wears into the paint
  5. Oct 23, 2018 at 10:59 AM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Use the 1 inch clear door guard you should be gtg
  6. Oct 23, 2018 at 6:16 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    x-pel door edge is a great solution for this, I have mine waiting to go on. IMG_0030.jpg
    InTheRough likes this.
  7. Oct 23, 2018 at 6:22 PM
    fatalkhaos
    What size is that?
    My guy that put the XPEL on my truck gave me some of the same that he suggested I try.
    He gave me 1/2 inch and suggested double it top and bottom for 1 inch of coverage. We will see how it works.
    Post pics if you get to it before I do and any tips.. Ill do the same
  8. Oct 23, 2018 at 6:30 PM
    Omohundro
    Jody
    McMinnville TN
    It is 3/4. Im going to put the flares on and mark where they sit, then remove flares and install the Xpel. I had the flares on my black Tundra for maybe 6 months and they were already rubbing pretty bad. Im not making the same mistakes with the new truck.
    fatalkhaos[OP] likes this.
  9. Oct 23, 2018 at 6:31 PM
    fatalkhaos
    Exactly what happened with me on my old Tundra
