P3 brake controller
Discussion in 'General Tundra Discussion' started by Adriver71x, Dec 20, 2018.
  1. Dec 20, 2018 at 4:39 AM
    Adriver71x
    Adriver71x [OP] New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    I installed a P3 brake controller in my 15 Tundra. They say 30 minutes install. I spent 1 1/2 hour. 1 hour just looking for a place to put the ground. I found a hole on the column mount. When putting everything back together i found the ground post they tell you to look for. If you are installing one of these the ground post is on the left side of the column not the right. Thats way the ground wire is so long. Hope this saves you time.
  2. Dec 20, 2018 at 5:28 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    thought there was an adaptor that would let it be "plug and play" - might have to extend the wires some to fit for your needs...but there should be a harness that plugs in to the factory harness...
  3. Dec 20, 2018 at 6:28 AM
    Cfincke
    San Antonio
    Does your truck not have the tow package?
    If it does there is a $10 cable you buy for your year and make to plug right into a factory plug behind the driver quarter panel.
    I installed a P3 in my 14 tundra in 15 minutes using the cable
  4. Dec 20, 2018 at 9:04 AM
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    The plug and play has a ground wire
