P0717, C1201 help please
Discussion in '2nd Gen Tundras (2007-2013)' started by hank.forker, Oct 11, 2019.
  1. Mar 19, 2024 at 7:44 AM
    M_RED
    M_RED New Member
    I just want to say thanks for all the pics in this thread! its super helpful...
  2. May 7, 2025 at 2:38 PM
    KCTundra2011
    KCTundra2011 New Member
    Resurrecting from the dead!
    Details: 2011 Toyota Tundra 4.
    I'm needing some help in locating the input sensor, the output sensor was easily located and swapped. I have been scouring the forums and see the red and blue circled pictures in the thread but the configuration doesn't match what I'm seeing under the truck. I can locate the area where it should be (passenger side above the pan) but no holes/ wires/ sensors.
    does anyone know where I can find a diagram or alternate view to try and locate?
  3. May 7, 2025 at 3:27 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    What engine do you have? Do you have a transmission oil cooler? Might be behind it, but might depend on the engine.
  4. May 7, 2025 at 4:44 PM
    KCTundra2011
    Here is what the VIN decoder pulled. Looked up the engine code and couldn't see anything that would answer the question. Do a more experienced eye see anything I'm missing?
    Make TOYOTA
    Manufacturer Name TOYOTA MOTOR MANUFACTURING, TEXAS, INC.
    Model Tundra
    Year 2011
    Series GSK50L/UPK50L/USK50L/GSK51L/UPK51L/USK51L/UPK52L/USK52L/UPK55L/USK55LUPK56L/USK56L/UPK57L/USK57L
    Trim SR5
    Vehicle Type TRUCK
    Plant Country UNITED STATES (USA)
    Plant City SAN ANTONIO
    Plant Company Name Toyota Motor Manufacturing, Texas, Inc.
    Plant State TEXAS
    Active Safety System
    Tire Pressure Monitoring System (TPMS) Type Direct
    Passive Safety System
    Seat Belt Type Manual
    Passive Safety System / Air Bag Location
    Curtain Air Bag Locations All Rows
    Front Air Bag Locations 1st Row (Driver and Passenger)
    Knee Air Bag Locations 1st Row (Driver and Passenger)
    Side Air Bag Locations 1st Row (Driver and Passenger)
    Engine
    Engine Number of Cylinders 8
    Displacement (CC) 4600.0
    Displacement (CI) 280.70922283576
    Displacement (L) 4.6
    Engine Model 1UR-FE
    Fuel Type - Primary Gasoline
    Engine Configuration V-Shaped
    Engine Brake (hp) From 310
    Other Engine Info PORT
    Exterior / Body
    Body Class Pickup
    Wheel Base Type Long
    Exterior / Dimension
    Gross Vehicle Weight Rating From Class 2: 6,001 - 10,000 lb (2,722 - 4,536 kg)
    Exterior / Truck
    Cab Type Extra/Super/Quad/Double/King/Extended
    Mechanical / Drivetrain
    Drive Type 4WD/4-Wheel Drive/4x4
