P0453
Discussion in '2nd Gen Tundras (2007-2013)' started by 4fingercarpenter, Sep 27, 2021.
  1. Sep 27, 2021 at 5:14 PM
    4fingercarpenter
    4fingercarpenter [OP] New Member
    Ryan
    Tampa
    2020 Cavalry Blue Tundra
    Exhaust AFE modified intake BDS 8 inch lift Ironman 4x4 880lbs upgraded leaf spring 37x12.5x20 -24 D3 tune
    Truck is throwing code P0453 evaporative emissions control system pressure sensor. Doesn't seem to be affecting anything other then the cel being on. Is this even needed or a way to bypass it? Also couldn't locate part to order a new one. Any help is greatly appreciated. Thanks
  2. Sep 27, 2021 at 7:01 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You haven't really diagnosed the problem. Your car sees high pressure in the evap system, that's it.
    A high level scan tool can be used to run through the functions of the evap system to see what is or isn't working to properly diagnose what actually needs to be done. A scan tool can be used to dramatically change the pressure inside the fuel tank to the point where the truck will run roughly, and a technician can do that while looking at the live data for the pressure sensor to see if the pressure sensor is reading the attempted change in pressure, or another possibility is that the attempt to dramatically change the fuel tank pressure will result in no rough running and no change in pressure, in which case you'd want to see if the charcoal canister vent valve is actuating properly.
    You could probably run the truck like this indefinitely without addressing it provided your area doesn't have very stringent inspection requirements.
  3. Oct 7, 2021 at 5:54 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Is your gas cap on tight?
  4. Jan 30, 2024 at 5:33 PM
    Bostondra
    Bostondra New Member
    Did you ever get this problem fixed? My 2019 just started throwing this code and CEL comes on. I have been unplugging the negative terminal to reset the code. Truck drives fine otherwise.
  5. Jan 31, 2024 at 3:16 AM
    4fingercarpenter
    Ryan
    Tampa
    It was my old 2011 that was having the issue. But no I never did get that light to turn off despite replacing the entire evap container, inspecting every wire (that I could see) and a few other tests. But it never hurt Drive ability.
  6. Aug 20, 2024 at 8:01 AM
    lfav2004
    lfav2004 New Member
    Leo
    I have P0453 code, already changed leak detection pump, checked connector voltage, made maintenance to canister (not plugged), purge valve working fine but still code remains after one month driving… any advices?
  7. Aug 20, 2024 at 8:03 AM
    Did you clear the code?
  8. Aug 20, 2024 at 9:09 AM
    lfav2004
    lfav2004 New Member
    Leo
    Not yet, replaced leak detection pump, performed maintenance on canister not plugged, measured voltage and resistances on connector all Ok…
  9. Oct 5, 2024 at 9:47 AM
    shifty` In South Dakota Trouble ain't hard to find
    What year and engine is your truck? Your username suggests it's a 1st gen (2004) but you've posted this thread in the 2.5 Gen forum (2014-2021)
  10. Oct 5, 2024 at 2:22 PM
    lfav2004
    lfav2004 New Member
    Leo
    It’s a 2015 V8 Cmax SR5 4x4, in this one pressure sensor is integrated to evap leak detection pump, so I started doing the basics, checked purge valve voltage and resistance OK, no lines plugged, canister not plugged, all voltages and resistances on connector of leak detection pump ok specially pin 6, 7, 8… so I get another truck and swap leak detection pump and sudently same code went to other car but when I put the other car in mine it didn’t go off del check engine light… anyways I purchased one new leak detection pump and thrusted than in time code would disappear but no…
  11. Oct 5, 2024 at 2:24 PM
    lfav2004
    lfav2004 New Member
    Leo
    Not yet It’s a 2015 V8 Cmax SR5 4x4, in this one pressure sensor is integrated to evap leak detection pump, so I started doing the basics, checked purge valve voltage and resistance OK, no lines plugged, canister not plugged, all voltages and resistances on connector of leak detection pump ok specially pin 6, 7, 8… so I get another truck and swap leak detection pump and sudently same code went to other car but when I put the other car in mine it didn’t go off del check engine light… anyways I purchased one new leak detection pump and thrusted than in time code would disappear but no…
  12. Oct 5, 2024 at 9:04 PM
    lr172
    lr172 New Member
    07 DC
    The code wont clear until the next time that the ecu runs the evap test which is no every drive. It is a permanent code, so cannot be cleared by uesr.
  13. Oct 5, 2024 at 9:14 PM
    lfav2004
    lfav2004 New Member
    Leo
    I have been driving with new evap pump for 2 months now… I am out of ideas…
  14. Oct 5, 2024 at 9:16 PM
    lfav2004
    lfav2004 New Member
    Leo
    Issue is that is affecting smog test and a lot of IM readiness for vehicle other than that vehicle runs fine not even one single mechanic problem…
