P0430
Discussion in '1st Gen Tundras (2000-2006)' started by shaw0531, Jul 5, 2017.
  1. Jul 5, 2017 at 8:15 PM
    shaw0531
    shaw0531 [OP] New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    This code has been intermittent since I got the truck a year and a half ago. Within the last month or so it is throwing a CEL every time I drive it now. I have an ultragauge so I'm able to clear the CEL and check the codes and all, but is there anyway to cure this once and for all? I get tired every time I drive it to have to clear the engine light. I've read it could be gas leak from exhaust, manifold, etc. Any surefire things I need to check before I start crawling around underneath it
    Thanks in advance
    Kappa82 likes this.
  2. Jul 5, 2017 at 8:37 PM
    Those are codes related to the O2 sensors and Catalaytic converter.
  3. Jul 5, 2017 at 9:29 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    If the truck is not running poorly, I would guess that the 02 sensor has gone bad. Also I have seen this come up when a vehicle burns too much oil, it gets carbon build-up on the 02 sensor.
    Or
    I mean, it could just be that the catalytic converter is going out. How many miles are on the truck?
  4. Jul 10, 2017 at 5:54 PM
    shaw0531
    Jake
    Sorry I'm just getting back on here.
    It burns very little oil.
    It's got just over 160k on it. Its just annoying now every time I drive I have to clear the CEL. Hasn't affected performance yet
  5. Aug 14, 2017 at 10:46 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    x2 on the O2 sensors. I replaced my O2 sensors when I had that code and never saw it again. My next option was the catalytic converters = much more $$
  6. Jan 23, 2019 at 5:55 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    Any updates on this?
  7. May 14, 2019 at 7:27 PM
    ronfrohock
    ronfrohock New Member
    Ron
    2004 Tundra
    I had the same problem. I discovered a few pinhole leaks and plugged them up with high temp putty and it fixed the problem.
