P0430 code
Discussion in 'General Tundra Discussion' started by Hartfield23, Apr 7, 2024.
  1. Apr 7, 2024 at 12:46 PM
    Hartfield23
    Hartfield23 [OP] 2016 Toyota Tundra SR5 4.6L v8
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    Ok guys I got a 2016 toyota tundra sr5 4.6L v8. At first I was throwing 3 codes P0137, P0157 and P0430 catalyst system efficiency below threshold bank 2. I bought bank1 sensor 2 and bank 2 sensor sensors hoping it would fix the problem. I got codes p0137 and p0157 cleared. But now I'm still throwing p0430. Which tells me I have a bad Catalytic converter in bank 2. But what I'm confused about is would that make me throw white smoke? and what catalytic converter is bad on bank 2? bc there is 2 on bank 2 and 2 on bank.
  2. Apr 7, 2024 at 1:06 PM
    Hartfield23
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    Also I've read somewhere that my up stream 02 sensors could throw that code as well. So I don't know I need help on what to do.
  3. Apr 7, 2024 at 1:20 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Top ones are the ones that go bad 1st and throw a code. Once those are replaced, but you still have a code after clearing them then the cat or cats are bad.
    White smoke on cold start is vapor most of the time. Depending on weather, if it's cold enough it may be consistant, fair day may be gone after a few minutes.
    If you're losing coolant and have white smoke, I'd have the intake valley checked 1st before dreading a blown head gasket, which are rare unless you've over heated.
  4. Apr 7, 2024 at 1:36 PM
    Hartfield23
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    I've learned that too. I'm not over heating so I don't think it's a blown gasket. But white smoke only happens when I throw the code p0430. I replaced the 2 downstream sensors. I'm thinking now it's my bank 2 sensor 1. But you think I should check my intake valley? I'm no mechanic and hope this isn't a stupid question but how would I go about doing that?
  5. Apr 7, 2024 at 2:35 PM
    Hartfield23
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    I'm about to check my radiator pressure test with dye. So I'll be able Eliminate that
  6. Apr 7, 2024 at 3:18 PM
    Hartfield23
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    Not a blown head gasket
  7. Apr 7, 2024 at 5:31 PM
    Hartfield23
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    Update: I found a small leak around the Catalytic converter weld. Could that be causing me to throw white smoke?
  8. Apr 7, 2024 at 6:09 PM
    blackdemon_tt
    That could be causing the code as what's beeing pushed out is not matching both O2 sensors.
  9. Apr 7, 2024 at 6:57 PM
    Hartfield23
    Kyle
    Hattiesburg, MS
    Silver Tundra SR5
    Yeah that's why I'm so confused.
  10. Apr 8, 2024 at 5:44 AM
    blackdemon_tt
    Well, before you throw more parts at it, I'd get that crack repaired. Once repaired, clear the codes and see if they come back. If, they come back then reassess and see what sensors you will need, or just swap the sensors you replaced with the front ones and see if the codes come back.
