P0171 P0174: Those pesky lean codes!!!
Discussion in 'Performance and Tuning' started by Broken_Taco, Sep 25, 2018.
  1. Apr 12, 2021 at 6:28 AM
    RaptorBronco
    RaptorBronco New Member
    Drew
    2015 Platinum
    Wheels/Tires and a B.S. "lift" as of 3/5/21. More to come because I can't not F with nice things
    i bet it comes back at 300miles. on a positive note, i did gain 2mpg after the new fuel pump...
  2. Apr 13, 2021 at 5:53 AM
    Scutterborn
    Scutterborn New Member
    Ben
    '14 Tundra Platinum
    RC Vertex 7" Camburg 1.5” UCA’s Icon RTX rear leafs on option 2 Firestone bags with daystar cradles 20” Fuel Kranks w/ 5.75 bs. 295 Toyo AT3
    Yesterday the codes came back on and i checked as soon as they did. My LTFT was 34.9 on both banks but dropped on acceleration. I ordered a new MAF in response to what I saw. Its not too expensive and it's super easy to swap. I'm only doing this because I can't find any parameters for the acceptable ranges for the MAF. At idle, I'm sitting at 6.26 gr/s at703 rpm and jumping to 28.46 gr/s at 3000 rpm. Part comes in today. I will update shortly.
  3. Apr 13, 2021 at 5:55 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Any MPG improvement is worth a shout out!! I love my truck almost as much as my company fuel card!! I'm averaging 9.4 mpg.... I also cover 500-800 miles a week.
  4. Apr 14, 2021 at 6:49 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    New MAF, same situation...
  5. Apr 14, 2021 at 10:56 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  6. Apr 14, 2021 at 12:43 PM
    RaptorBronco
    Drew
    2015 Platinum
    Fuel pump man...!
  7. Apr 14, 2021 at 3:08 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Yeah. Did you go with oem or aftermarket?
  8. Apr 14, 2021 at 3:10 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    I tend to go with OEM. The dealer wants $525 for the fuel pump when I can get it after market for about half of that.
  9. Apr 22, 2021 at 6:43 AM
    RaptorBronco
    Drew
    2015 Platinum
    it was all warranty work at Toyota so it was OEM. i would go with OEM for sure and make sure it is the upgraded part number as well. not the old part number that just failed on you.
  10. Apr 25, 2021 at 9:05 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Fuel pump is ordered and will be here tomorrow. I will update every one as soon as I know that this solved the problem.
    HulkSmurf14 likes this.
  11. Apr 26, 2021 at 6:21 AM
    RaptorBronco
    Drew
    2015 Platinum
    Sweet! good luck and i hope all goes well
  12. Apr 26, 2021 at 6:40 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    So, I felt it was necessary to update this with my findings for future diagnostics. I tested the fuel pressure and got 38 psi on start and within 5 seconds, it dropped to 25-27 psi. I also did a volume test and got very little. This is what I used to confirm the fuel pump was failing.
  13. May 5, 2021 at 11:23 AM
    xround
    xround New Member
    2015 CM Limited OR
    @RaptorBronco do you have any details on the fuel pump replacement? I am also in a 2015 5.7L and just got the same error codes... Just looking for a recall number or bulletin number or something. Thank you!
  14. May 5, 2021 at 12:13 PM
    RaptorBronco
    Drew
    2015 Platinum
    i don't know that it's a "recall" at all. Toyota just told me it is an "extended warranty part that Toyota recognizes has a short life and replaces/upgrades it at no cost, up to 100,000miles". I was shocked not to find more details on it here. that is why bumped this one with more info. sorry I don't have a ton of info. all i can say is don't waste your time. Take it in for diag and get it replaced if it is the same codes and same situation as mine. and sounds like @Scutterborn as well...
    Keep us posted on what they say. Seems to be a good bit of value from this thread and this common problem.
  15. May 5, 2021 at 12:18 PM
    xround
    xround New Member
    2015 CM Limited OR
    @RaptorBronco word, thank you. Mine is at 120k miles... I'll go ahead and get it diagnosed & just swap it myself if it's bad.
  16. May 6, 2021 at 7:32 AM
    RaptorBronco
    Drew
    2015 Platinum
    The following info is from my Toyota invoice 3/4/2021. @xround had a good point about listing part numbers.
    1 --Cause/Action to Take
    CEL -CUSTOMER STATES CHECK ENGINE LIGHT IS ON. CHECK AND ADVISE. lean codes on bank 1 and bank 2 found p0171 p0174. found tsb related to these codes. parts ordered.
    1 --Correction/Action Taken
    followed procedures for T-SB-0166-19, recalibrated ecu, installed fuel pump, reset learning, reset alchol fuel density learning, added 3 gallons. test drove. vehilce has no codes and is working properly.
    op code EG1904
    1-07 t2-74
    Part numbers:
    770200C120 Tube Assy, Fuel Suct
    771690C010 Gasket, Fuel Suction
  17. May 10, 2021 at 8:52 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Fuel pump is installed and everything is working as it should be. No more codes or hesitation.
  18. May 10, 2021 at 9:07 AM
    RaptorBronco
    Drew
    2015 Platinum
    Sweet!!!
  19. May 12, 2021 at 7:43 AM
    #49
    xround
    xround New Member
    2015 CM Limited OR
    Got the tank dropped and discovered I have a Flexfuel Tundra. Epic!
    Also the check engine light has been off for about 100 miles now. After reassembly, I did some more research and some have had the same P0171/P0174 codes resolved with a Techstream reset of the fuel computer on the FFV engines. Guess I'm going to try that next. Will post results.
  20. May 14, 2021 at 12:24 PM
    #50
    Scutterborn
    Ben
    '14 Tundra Platinum
    Any good news yet?
  21. May 14, 2021 at 12:31 PM
    #51
    xround
    xround New Member
    2015 CM Limited OR
    Haven’t made it to Toyota yet. CEL still isn’t on. After getting the fuel tank on I also swapped the throttle body gasket from the factory mesh to a new supple OEM non-mesh one. I did it to eliminate the high pitch whistle issue, but I guess it could have something to do with creating a Lean condition if the old one wasn’t providing a good seal.
    I’ll be sure to update the thread once I have Toyota take a look at it.
  22. Jun 11, 2021 at 6:22 AM
    #52
    xround
    xround New Member
    2015 CM Limited OR
    Quick update, I decided to take the truck to Toyota after towing a light boat & getting very bad throttle hesitation & CEL came back on. According to them my fuel pump was junk, the fuel trim was going wild because of this, and it also impacted my transmission learning. They installed new fuel pump, updated my transmission program, and I went ahead and had them install new spark plugs & tune up while they had it. $1400 later it drives like a different truck, very epic.
    Thanks to members here for help diagnosing the issue, it made me feel better to hear from them that the problem was what I was expecting.
    A note on the fuel pump: I asked if I could just buy myself a fuel pump and put it in, and he said due to the ongoing fuel pump recall, any aftermarket or OEM fuel pump I would buy outside of a Toyota dealership would be the older failure-prone fuel pump design. I don't know how much truth there is to this, but it is something to consider for the DIY-oriented. I generally always do this type of vehicle work myself but decided to play it safe here.
  23. Nov 16, 2021 at 9:13 PM
    #53
    Jmrey01
    Jmrey01 New Member
    Jared
    2014 Tundra
    Looks like I need to start down this road! I made it to 183K though. My gas mileage has taken a dump and I get the P0171 code. Clear it and it magically appears again.
    I'll have to check it after lines 1 through 9678 get checked off the ole to do list.
  24. Apr 7, 2022 at 9:01 PM
    #54
    300k_mile_Tundra
    300k_mile_Tundra New Member
    Just throwing this out there as it was my problem to the P0171/P0174. My brake booster had a vacuum leak causing my truck to run lean
    RJVA and Pete75 like this.
  25. Apr 7, 2022 at 10:11 PM
    #55
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    Got em
  26. Oct 18, 2022 at 6:22 PM
    #56
    Pete75
    Pete75 New Member
    Pierre
    BC, Canada
    2008 Tundra SR5
    Originally became a member because my '08 had the same symptoms as Broken_Taco: CEL for lean codes banks 1 (P0171) and 2 (P0174), Lo 4 light, Traction Control, sputtering and loss of power (especially uphill on highways), and difficulty idling upon restarting a warm engine (more sputtering for like 10 minutes). I'd been to two dealerships and neither could diagnose the problem...smoke test and new MAF sensor and air intake, testing ignition coils and changing spark plugs. All to no avail. So that led me to this forum, which I wish I'd discovered sooner. It's been a year now since I finally swapped out the fuel pump myself and so far no issues. Now, this is the first place I check for troubleshooting stuff and mod suggestions. This is a great community and certainly invaluable. Thanks to all who contribute and help others like myself get a handle on the problem.
  27. Oct 18, 2022 at 6:29 PM
    #57
    Pete75
    Pete75 New Member
    Pierre
    BC, Canada
    2008 Tundra SR5
    Might come in handy for future diagnosing. Thanks
    RJVA likes this.
