P0101 Trouble Code/Engine Code
Discussion in 'General Tundra Discussion' started by csuviper, Jan 24, 2015.
  1. Apr 27, 2016 at 10:11 AM
    #61
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Have had the hypertec interceptor off for about 2 weeks now and have not had the code come up at all.
    T-Rex266 likes this.
  2. Sep 19, 2016 at 8:27 PM
    #62
    Tkmartindill
    Tkmartindill New Member
    Tk
    07Tundra TRD
    Thorley long tube headers K&N air Afe throttle body spacer True duals 6" procomp lift Electric engine fans Engine swap at 278,000 Bunch of other stuff I already forgot
    Just installed new exaust and I'm having the same code problem.
    Weird thing is this is week three of the exaust system being on and the 0101 code started just 48hrs ago.
    Since then it's tripped almost every drive cycle.
    Has anyone found a way to get the ecu to recognize more air flow and exaust flow?
  3. Sep 20, 2016 at 12:13 AM
    #63
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    P0101 is, more often than not, remedied by cleaning your MAF sensor. I had the code pop up a few weeks ago and cleaning the sensor fixed it. I'm TRD supercharged with the TRD exhaust.
  4. Sep 21, 2016 at 5:50 AM
    #64
    Tkmartindill
    Tk
    07Tundra TRD
    I thought so too.
    My maf is a jet performance so I bought a new denzo from Toyota, cleared the codes and tried it. Took about 20 minutes before it threw the same codes.
    I'm leaning on the exaust flow combined with the air flow on the front side being outside of what the ecu is willing to accept as good data and it's causing the ecu to code out exaust inefficiency and maf error codes
  5. Oct 20, 2016 at 9:41 PM
    #65
    csuviper
    Broomfield, CO
    So I had the hypertec interceptor off from April to late September. No codes during that time. Added at the end of septemember and got the code within a week. Grrr. Didn't change anything except uninstall and reinastall. Still have the drop in filter in. Only get the code when getting on it hard or pulling a hill. Still annoying.
    Will put the paper filter on for a little while again to see what happens.
  6. Oct 21, 2016 at 8:33 PM
    #66
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Huh... it's obviously doing something. I have gone all summer without the code.. . I bet it comes back in the winter
  7. Nov 21, 2016 at 12:40 PM
    #67
    csuviper
    Broomfield, CO
    CEL after CEL after CEL with the hypertec interceptor and AFE high flow filter.
    Still need to put the paper one back in to see if anything changes.
  8. Jun 24, 2018 at 6:35 PM
    #68
    GBudd
    GBudd New Member
    G
    11 Tundra DC
    K&N CAI, g
    I have a 2011 DC, with about 55k on the clock, with a K&N CAI, stock exhaust and no other mods. After about 7 months with the CAI, my CEL came on and my code reader revealed P0101 (MAF error). I drove the truck for a while with the light on and it eventually turned off on its own. Then it came back on. Interestingly, every time it came on, I was going uphill, and accelerating. I cleared it about a year ago and it hasn't reappeared since. Until today that is... Today after turning onto an uphill street on wet pavement, I spun my rear wheels for a good distance with the traction control light flashing and the system working to regain traction. The traction control stopped when I took my foot off the accelerator. A few seconds later the truck seemed to bog down as it seemed starved for power and the. The CEL illuminated. Note: I drive this hill very regularly, and it has been the location of previous illuminations, but so have other areas...
    I will clean my MAF sensor on the next nice day I have to ensure good drying...
  9. Jun 26, 2018 at 6:12 PM
    #69
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Likely just the cai
  10. Aug 19, 2018 at 7:48 PM
    #70
    Rhino
    Rhino New Member
    Alex
    2010 Toyota Tundra Rock Warrior
    Sorry to dig this one back up. Ive got a P0101 code on my supercharged with TRD intake, JBA long tubes, Dirty Deeds mid pipes with cats and TRD mufflers. It has OME suspension and 35s. I have two MAF sensors that both test good. I have cleaned them both thoroughly as well. The code comes up immediately after clearing it, key on engine off. Because it comes up so quick I wonder if theres a fault in the wiring. Anyone else have any other issues besides whats listed in this post? Ive read about the sensor being at a different angle and it cleared. The TRD air box has a fixed spot for the sensor so I stuck a roll of electrical tape under the rear of the box and the code came straight back. Thanks!
  11. Jan 13, 2019 at 3:14 PM
    #71
    Bigdog
    Bigdog New Member
    2014 sr5 tundra 4x4
    7 inch pro comp lift 37 12.5 nitro ridge grapplers 639 k&n cai hyperforce interceptor tuner
    You know I have had problems with this code for about year sna half have k&n 63 cai an hyperforce interceptor had Toyota do a system check plus did a bunch myself 3 mags burnt up final took hypertech interceptor of an no shit not one code sense but was wondering if could use acelarator control on truck still with no tuner an in near future will be doing DAP tune
  12. Feb 15, 2021 at 6:18 PM
    #72
    Tundraguy707
    Tundraguy707 New Member
    07 crewmax 5.7 tundra
    07 crewmax 5.7 tundra here...k&n cold air intake like everyone else having issues...had a drastic drop in mpg...finally code tripped with p0101...cleaned mass airflow sensor, cleaned and oiled air filter, cleaned throttle body and realized airraid throttle body spacer was also part of my setup...noticed small barely visible crack in gasket of spacer...of course gasket cannot be ordered individually so I purchased a sheet of fiber/ gasket material...drew a template, cut to size and now performance is back and mpg is on the rise...hope this helps at least one person out there with similar setup scratching their head
