P&S brake buster + IronX
Discussion in 'Detailing' started by Pudge, Nov 6, 2019.
  1. Nov 6, 2019 at 4:27 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I decided to make up my own concoction to clean my plasti dipped wheels. Its about 75% brake buster and 25% gyeon iron remover. This worked out really well. It is by far the best cleaning solution I have used on my dipped wheels. The brake dust really embeds itself into the textured areas of dip and looks terrible. I recommend it for sure. The ratios could be altered for your needs and I'm sure I'll play around with it another time.
  2. Nov 6, 2019 at 4:35 PM
    War Machine
    War Machine SSEM # 5 3MW
    You didn’t even give Brake Buster a chance!
    Pudge[OP] likes this.
  3. Nov 6, 2019 at 4:42 PM
    Pudge
    CT
    Lol I didn't even think of that. I suppose I should try it on it's own and see how it does. Good point Jason.
    War Machine[QUOTED] likes this.
  4. Nov 6, 2019 at 4:52 PM
    War Machine
    No doubt the iron remover made it a stronger cleaner.
    Pudge[QUOTED][OP] likes this.
  5. Nov 7, 2019 at 8:31 AM
    Tmank87
    Tmank87 New Member
    I may need to give this a try. I have a gallon of Megs Iron Remover because I got it cheap. Any thoughts on how that compares to Iron X?
  6. Nov 7, 2019 at 8:36 AM
    Pudge
    CT
    I used gyeon iron for this mix and it worked well.
    For a stand alone iron remover I have not found anything as powerful and effective as the Original CarPro IronX, but they are all pretty good. If you got a deal on something I say this mixture is the perfect use for it
  7. Nov 7, 2019 at 8:40 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I tried griots wheel cleaner and wasn't impressed. I'll give brake buster a try.
    Ive been trying to find something that was a good as that German stuff (can't remember the name), that I bought along with waxaddict. That stuff worked really well. Spray on and power wash off.
  8. Nov 7, 2019 at 8:51 AM
    Pudge
    CT
    Next time I will try the brake buster on its own, I really should have done a split of 2 tires vs 2 tires with and without the IronX. Oh well something to try next time
  9. Nov 7, 2019 at 8:52 AM
    Pudge
    CT
    Maybe Sonax? That stuff gets great reviews and I think they now make an extra strong version with iron remover.
  10. Nov 7, 2019 at 9:37 AM
    Danimal86
    Daniel
    Sacramento, CA
  11. Nov 7, 2019 at 9:49 AM
    Pudge
    CT
  12. Nov 7, 2019 at 10:11 AM
    Danimal86
    Daniel
    Sacramento, CA
    Its on my list of things to watch for on BF. Probably will get the big hug as you use a decent amount each time.
  13. Nov 7, 2019 at 11:09 AM
    War Machine
    It is by a long shot, but a lot more expensive and a much harsher chemical. It’s not necessary to use something that strong most of the time. I keep it in reserve for really nasty wheels. Brake Buster does the job unless it’s a really filthy wheel.
    owb2gp and Pudge[OP] like this.
  14. Nov 7, 2019 at 1:39 PM
    Danimal86
    Daniel
    Sacramento, CA
    I didn't know it was so harsh. Maybe it shouldn't be my go to
  15. Nov 7, 2019 at 2:29 PM
    Pudge
    CT
    If anyone comes across a deal on IronX let me know. I realized my stock is low, I have plenty of time to shop around though, which is good that I could maybe find some cheap
  16. Nov 7, 2019 at 4:02 PM
    War Machine
    Not like it’ll damage your wheel, just may not be the best thing to use on coated ones.
  17. Nov 7, 2019 at 5:50 PM
    Danimal86
    Daniel
    Sacramento, CA
    I saw that it said "acid free" so I figured it would be gtg.
    Any idea what chemicals are in the stuff?
