P&P Engineering Tundra Front Low Pro Winch Bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by mac11, Jan 8, 2017.
  1. Jan 8, 2017 at 8:46 PM
    mac11
    mac11 [OP] New Member
    Warsaw, Indiana
    A couple months ago we met Cody - @MidwestOverlanders - and made some sliders for his Tundra TRDPRO, Brutus. Since then we've seen a very strong interest in our sliders and Cody has trusted us with his truck to take on front & rear bumpers, full front to rear skid plates (pics coming soon) and now a low pro front bumper. We're very close to having them production ready and thought we would throw up some pictures now that we've roughed in the low pro bumper.
    This is our low pro winch bumper. It was designed around a smittybuild X20 12k winch. Will fit almost any remote solenoid winch up to this size as the winch bucket is the full width of the frame rails of the truck. It is about 1.5" tighter to the truck than our plate bumper so depth of the winch should be paid attention to.
    This Low Pro bumper is fully bolt on with no cutting, or modification of any kind necessary to the stock bumper. The Tundra bumper fully disassembles and the center section simply unbolts and is set aside. It can be reinstalled at any time.
    The mounting plates are 1/4" thick and the bumper side bracket has been laminated to 1/2" thick where it connects to the mounting brackets on the truck. You can tug on that with any winch and it will not pull through. The mounting brackets are fully adjustable in every direction. Including at the trucks frame mount and the connection between the brackets and the bumper. Aligning the gap wide for off rood purposes or narrow for street style is a matter of adjusting it to your preference. The stock plastic bumper corners are also independantly adjustable from the center section to compensate for manufacturing tolerances at Toyota and our shop. It can all be adjusted to your preferred gap alignment. A 1"+ gap to the fenders and grille is recommended for off road use. the body mounts on this truck are very soft. Anything smaller could result in contact with and damage to the fenders as the body moves around on the frame.
  2. Jan 8, 2017 at 10:00 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I like it. Simple addition of a winch without major change in appearance from stock on the front end. Full bolt on and and ability to go back to stock if you ever sell the truck.
  3. Jan 10, 2017 at 10:02 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    This is a pretty cool concept. :thumbsup:
  4. Jan 10, 2017 at 8:35 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Great concept.
  5. Jan 10, 2017 at 9:09 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Gotta hand it to you P&P designers, you come up with some pretty cool stuff. Keep it coming !
    mac11[OP] likes this.
  6. Jan 10, 2017 at 10:10 PM
    Morgan51
    Morgan51 New Member
    2016 Inferno CM Tundra TRD
    Interesting design! Can't wait to see the final product :thumbsup:
  7. Mar 22, 2017 at 9:15 AM
    mac11
    Warsaw, Indiana
    Assembled pics should be available later today. Installed pics will be available as soon as we get it ask back to the customer
  8. Mar 22, 2017 at 9:27 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Think that mounting is going to hold up without any gussets? Also curious why you're keeping the intermediate aluminum standoffs and not just bolting straight to frame?
  9. Mar 22, 2017 at 9:56 AM
    mac11
    Warsaw, Indiana
    The mounting brackets aren't shown in these pictures. And from that question you don't see whats going on here.
  10. Mar 22, 2017 at 9:58 AM
    mac11
    Warsaw, Indiana
    My mounting brackets are directly to the frame and I do think they will hold up as they have been holding up on the full plate bumper with a 12k winch. They are also reinforced and fully adjustable so the bumper can be setup with a large gap for the guys off roading that will be flexing the body mOunts quite a bit or a small to no gap for the guys who stay on the road and want a tighter look.
    I'm also not keeping the aluminum crash bar.
  11. Mar 22, 2017 at 10:19 AM
    mac11
    Warsaw, Indiana
    The outer pads only mount the factory cross bar that holds the bumper end caps on. This Is also adjustable so the end caps can be aligned to the new center bumper section to the customers taste without running into factory tolerances.
    J4RR3N4 and Relentless like this.
  12. Mar 22, 2017 at 10:26 AM
    mac11
    Warsaw, Indiana
    Factory bumper end caps then bolt right back on the toyota sheet metal like they did from the factory.
    Smoofers and J4RR3N4 like this.
  13. Mar 22, 2017 at 10:27 AM
    Paulskie
    Paulskie New Member
    Paul
    Thats one great looking bumper
  14. Mar 22, 2017 at 10:30 AM
    mac11
    Warsaw, Indiana
    Thanks.
    The only changes from the pics in the OP to those today are that we welded the seams and sanded them smooth. So the pics in the OP are how the bumper will look on the truck. Making arrangements now to get the finished bumper mounted on the truck when we can get together.
  15. Mar 22, 2017 at 10:38 AM
    mac11
    Warsaw, Indiana
    Fully assembled.
    Akaklutz and J4RR3N4 like this.
  16. Mar 22, 2017 at 12:57 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Piece of art right there.
    The more I see from you guys the quicker I become a fan.
    I think the future may bring us together.
  17. Mar 22, 2017 at 5:58 PM
    CM-LENNY
    San Diego, CA
    Nice looking addition to the already great line of products you fab. You folks are artists !
  18. Mar 22, 2017 at 6:43 PM
    Relentless
    Eric
    Got it, understand the mounting now. :thumbsup:
  19. Mar 22, 2017 at 8:42 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Pretty nifty!
  20. Mar 22, 2017 at 8:43 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Awesome job. Looks nice AND it works!
  21. Mar 23, 2017 at 1:16 PM
    Polack100
    Polack100 New Member
    Don
    Prescott, Az
    ''08 Tacoma SR5 Off Road
  22. Mar 23, 2017 at 1:17 PM
    mac11
    Warsaw, Indiana
    Right on.
  23. Mar 23, 2017 at 1:33 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    How heavy are you expecting this to be when all is said and done?
  24. Mar 23, 2017 at 1:43 PM
    mac11
    Warsaw, Indiana
    This steel one is ~85lbs. An AL version would be ~40ish% lighter.
  25. Mar 23, 2017 at 2:16 PM
    sdhq_offroad
    GILBERT, AZ
    Would you really trust an all aluminum version? I feel it would bend at the frame mounting points. Our hidden winch mount only weights in at 55lbs, but we also designed ours for a clean stock look while keeping the weight as close to the front suspension as possible to decrease how far the front end is pulled down by weight. Looks to be as yours is also catered to the more common cheaper Smittybilt winches as we designed ours around the Warn.
    Y0TA PR0 likes this.
  26. Mar 23, 2017 at 2:32 PM
    mac11
    Warsaw, Indiana
    We built with the new smitybuilt winch because that's what the customer brought in. From what research I've done the Warns without integrated solenoids are roughly the same size and should fit. I would be interested in seeing how many of each brand winch people are buying to know if we should tailor things one way or another?
    Material thickness would change for an AL version - hence ~40% lighter and not the 55%+ that going straight over to same thickness AL would yield. I don't want to make it sound like I would ignore the real world but with a well setup FEA I can run a through simulation and determine appropriate changes before building in the real world and have a pretty good confidence before burning through a bunch of material.
    Less from the mechanical engineering stand point and more from the practical side of things this is what I see. At the end of the day every winch is bolted down with 4 ~3/8" bolts in single shear and the attachment to the truck frame is a handful of 10mm studs that are grade 5 at best. Those OEM bumper mount studs are all tugging on the threads not even using the shear strength of the bolts. Once make everything around that stronger than those connections with a reasonable factory of safety theres not much more you can do. You'll pull the threads off the factory Toyota bolts before You bend 3/8" 6xxx series AL thats laminated with another piece of 1/4" or 3/8" AL.
    And there are a lot of all AL winch bumpers on the market from various companies already. Some of which - from an engineering standpoint - look pretty sketchy, but are very visually appealing. And they have been used, abused and been through car crashes.
    texasrho83 likes this.
  27. Jul 26, 2018 at 10:52 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Sorry for the old thread bump, but is anyone running this bumper? Was considering this or the slimline
    jewsNbrews likes this.
  28. Jul 26, 2018 at 2:04 PM
    mac11
    Warsaw, Indiana
    There are a couple forum members with them.
    This guy is on the forum but I forget his screen name.
  29. Jul 26, 2018 at 5:56 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Damn that’s just hotness...
    jewsNbrews and mac11[QUOTED][OP] like this.
  30. Jul 26, 2018 at 7:41 PM
    Js18tundra
    I don’t know why more people don’t rock it, it’s so clean!
    mac11[OP] and texasrho83 like this.
