P&P Engineering Sliders Production Run Pre-buy
Discussion in 'Deals & Group Buys' started by mac11, Jan 13, 2017.
Thread Status:
Not open for further replies.
  1. Dec 8, 2017 at 2:05 PM
    #151
    mac11
    mac11 [OP] New Member
    Warsaw, Indiana
    I didn't. It's "some". Just enough for the bolts to clear. Now it looks more or less the same as the '15 we have here.
    He said he clipped in all but the one that's covered.
    With the multiple clips that come in from the top vertically add and the hard mounts front and rear of the frame section in question even if you left all 3 out of the outer face of the frame they would be plenty secure. That's 4 mount points in ~ 4-5 feet of frame even if you dont push any of the clips back in horizontally.
    If you need more than that you'll need to get with a local fabricator to come up with a new mounting system for those lines.
    Sunnier likes this.
  2. Dec 8, 2017 at 10:43 PM
    #152
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I got the driver's side on.
    Dropping the gas tank skid provided just enough room to get the backing plates in.
    I unscrewed the ebrake bracket to get it out of the way during installation. There is no way that it can be screwed back in without bending it or flipping it over.
    dcsleeper408 likes this.
  3. Dec 11, 2017 at 9:29 PM
    #153
    mac11
    Warsaw, Indiana
    Were made this part of our holiday sale. Now through the 7th of January the new type 4 is being discounted $150 using offer code "1Christmasday" at check out.
  4. Dec 11, 2017 at 9:57 PM
    #154
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    yes, but it took a minute to figure them out
  5. Dec 11, 2017 at 10:11 PM
    #155
    Eclipsed & Floating
    Voluptuous Whitey
    Did you get yours installed?
    My recommendation would be to re-route the lines like i did and replace the clamps that hold the lines. You can push them out of the way, even though you shouldn't have to. As for the last bolt on the driver side....it was a bitch. i had to use a little force to get that last plate back there, but i did install them before my skids went on and that BS gas tank skid was pointless anyway. it went away pretty quickly
    @mac11 just for reference, can you please show how the back plates are supposed to be attached properly? The pic you posted earlier just shows one side of the frame
  6. Dec 12, 2017 at 6:48 AM
    #156
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    @Almaboy I did not. Forgot we had to head out of town this past weekend so definitely attacking them this coming weekend. Hopefully with everything we've put together here I can work through it with minimal issues. What did you replace the clamps with? I'd like to get everything together so I don't have to make trips to the hardware store and back several times. @GodlessPro already gave me a heads up on that one....
  7. Dec 12, 2017 at 7:01 AM
    #157
    Eclipsed & Floating
    Voluptuous Whitey
    Just drilled holes and used the same clamps but I also zip tied where I could to make it easier. It was almost a year ago I installed mine so I can’t remember all of the struggles but definitely get someone to help or something to prop the ends up because they are heavy to handle by yourself without a little assistance
    JRPro[QUOTED] likes this.
  8. Dec 12, 2017 at 8:43 AM
    #158
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    yup those things sure are heavy you will need some help
  9. Dec 12, 2017 at 9:18 AM
    #159
    mac11
    Warsaw, Indiana
    We throw jack stands under the slider to hold them up. works great.
    Once you look at the backing plates you'll see they can only go together 1 way. There is a pin sticking off one side. That goes through the frame and is a pilot into the hole in the slider bracket.
    UTTundra likes this.
  10. Dec 13, 2017 at 1:27 PM
    #160
    zkauss
    zkauss New Member
    Mine are installed. You need a couple of guys to help hold in place even with a jack stand. Looks good
  11. Dec 13, 2017 at 2:25 PM
    #161
    SuperSilverTundra
    Nick
    they look really good what finish did you go with?
  12. Dec 13, 2017 at 2:35 PM
    #162
    zkauss
    zkauss New Member
    it was a silver powder coating. I can get the actual mfg #
  13. Dec 13, 2017 at 2:39 PM
    #163
    SuperSilverTundra
    Nick
    its looks awesome I was just curious as to what you went with I had my p&p sliders sprayed with Line-X I thought about powder coating them but was worried they might end up being slippery I like how they match your wheels :thumbsup:
  14. Dec 13, 2017 at 3:13 PM
    #164
    wh4x4
    wh4x4 New Member
    I may be late to the party, sounds like everyone got there's installed. If it helps at all i have a 2015 CM standard gas tank. Passenger side I just unclipped 3 of the brake line plastic hold-downs from frame to make room for backing plate. After installed, I put in a couple zip ties, just to reduce potential for flopping, but pretty secure as brake lines are rigid. Driver side, I just had the one bracket holding the fuel hose (i think it is) in the way, I was able to just leave that in place, bending the bracket up to make a bit of room for the angle support for the slider. Feel free to PM me if you need any additional pics or input on install, happy to share. cheers!
    Eclipsed & Floating and JRPro like this.
  15. Dec 14, 2017 at 5:46 AM
    #165
    Daze823
    Daze823 New Member
    Donnie
    Fayetteville, NC
    2015 White TRD Pro
    Toyo all weather mats
    I haven't installed mine yet, haven't even opened the box of parts yet, not going to be have time to attempt install until at least next week. I recently moved to NC, so don't have any local friends to call upon, so i'll be attempting solo install. Is the basic concept that the bracket on the skid needs to be lined up with the hole and then the backing plate on the otherside and run a bolt through?
    Eclipsed & Floating likes this.
  16. Dec 14, 2017 at 7:04 AM
    #166
    Eclipsed & Floating
    Voluptuous Whitey
    Yes. That’s the exact concept. The backing plate has a nipple the inserts into the holes in the frame and run the bolt through
    Daze823[QUOTED] likes this.
  17. Dec 16, 2017 at 10:43 AM
    #167
    JRPro
    Rich
    Austin, TX
    They’re on! Thanks to @GodlessPro and @Almaboy and @mac11 for the heads up on changes to a 17. Took about 3.5 hours total with a short lunch break.
  18. Feb 21, 2018 at 7:59 AM
    #168
    mac11
    Warsaw, Indiana
    Just had a customer cancel an order on tubular type 4, front dimple plate with monster liner. They are hanging in the booth sprayed, curing and 1 day away from being ready to ship if anyone is interested in near zero lead time. Can ship these out this week still.
  19. Feb 21, 2018 at 8:34 AM
    #169
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    email sent to your address on site
  20. Feb 21, 2018 at 8:36 AM
    #170
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Any pictures?
  21. Feb 21, 2018 at 8:42 AM
    #171
    mac11
    Warsaw, Indiana
    Same ones as jrpro posted up there but with raptor liner.
    JRPro likes this.
  22. Feb 21, 2018 at 5:43 PM
    #172
    iHacker
    iHacker SW TRD PRO
    Mario
    Thank you :thumbsup:
  23. Mar 4, 2018 at 4:38 PM
    #173
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    Finished and installed P&P Type 4 Tundra Sliders this weekend (their new design). Cleaned really well, sanded down with 120 (and some 60 for a few tough spots), then three light coats of self etching primer followed by three coats of paint. Ended up deciding to go with Rustoleum Textured in flat black. Enough texture so your foot doesn't slip, but not as deep as bed liner. Am hoping this will be easy to clean while still non-slip. Will see how it holds up.
    Install wasn't too bad. Took under 2 hours with a friend helping. Had to drop the gas tank protection on drivers side, but after that wasn't bad. Lines got in the way on the passenger side, but was able to move them enough to get the work done. Used jack stands in the back and a jack in front to position, which made it much easier. So far so good. They're nice a solid, look nice and the kids already like having a step. Now just need to get out onto some trails.
    Sunnier, 1rufftrdpro and UTTundra like this.
  24. Mar 4, 2018 at 4:54 PM
    #174
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    nice, i like these, i ordered some last week.
  25. Mar 4, 2018 at 7:20 PM
    #175
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    still have these?
  26. Mar 5, 2018 at 1:45 PM
    #176
    mac11
    Warsaw, Indiana
    :thumbsup:
    Yes we do. Shoot us an email to sales@engineeringpp.com
  27. Mar 5, 2018 at 7:32 PM
    #177
    r4z0r51o
    Dave
  28. Apr 4, 2018 at 9:48 AM
    #178
    mac11
    Warsaw, Indiana
    Have a set of tubular type 4 with front dimple plates raptor lined ready to go. Same as JRPro. Crewmax or Double Cab.
  29. Apr 19, 2018 at 9:51 AM
    #179
    mac11
    Warsaw, Indiana
    Tubular kickout sliders are back in a single piece design.
    dcsleeper408 and r4z0r51o like this.
  30. Apr 19, 2018 at 9:55 AM
    #180
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    How much do these hauses weight?
Thread Status:
