Oxygen sensor replacement 2003 AC
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Feb 12, 2022.
  1. Feb 13, 2022 at 4:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If your scanner will read the code #, that number can help determine which side the issue exists. Your bad or unplugged AF sensor will most definitely cause an engine to shutdown.
    Symptoms of a Bad or Failing Air Fuel Ratio Sensor | YourMechanic Advice
    Correct me if wrong but you were dealing with rear sensors ?
    Rear sensors only monitor the cats efficiency and the ECM does not use it's readings in making any adjustments.
    Voss[OP] likes this.
  2. Feb 13, 2022 at 4:27 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    True. I replaced all 4 but it was a rear sensor that went "bad".
  3. Feb 13, 2022 at 6:41 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Unhook the problem sensor completely and see if the truck will start. Also do battery reset as others have suggested
  4. Feb 13, 2022 at 7:10 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Thanks, scanner said Bank 2 sensor 1 which I believe is passenger side front sensor.
  5. Feb 13, 2022 at 7:15 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Will do thanks for the tip
  6. Feb 13, 2022 at 7:17 PM
    Voss
    Valod
    2003 AC TRD 4x4
    And here I almost forgot my long lost brother goes through the same weird stuff I do lol.
    FirstGenVol[QUOTED] likes this.
  7. Feb 13, 2022 at 7:18 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Put one of the old ones in where the bad sensor is and see what happens.
  8. Feb 13, 2022 at 8:10 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    If it wasn't a poor connection, swap it with the sensor you replaced to see if the truck will start up and run as @bfunke recommended. Also, there should be a spec on the expected resistance of these sensors you can measure.
  9. Feb 13, 2022 at 8:17 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ya I saved the old ones for just this occasion.
    Jack McCarthy likes this.
  10. Feb 13, 2022 at 8:19 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I’ll report back once I check but I’m positive the connections are good.
  11. Feb 13, 2022 at 8:39 PM
    Jack McCarthy
    Bill
    North of Boston
    If it's definitely looking like the new sensor is bad, you should be able to swap it with another new one from Toyota since their OEM parts warranty is typically 12 months.
  12. Feb 13, 2022 at 8:47 PM
    Voss
    Valod
    2003 AC TRD 4x4
    That’s some relief. I took so long to install these, thought maybe McGeorge wouldn’t cover them. Hopefully all works out for the best.
  13. Feb 14, 2022 at 2:16 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Well it’s was completely disconnected. Could’ve sworn it clicked in. All is well for now.
    appreciate the input all
  14. Feb 14, 2022 at 2:39 PM
    "Oops"
    But hey, those are the best mistakes, the ones that can be resolved in less than a minute or two, and didn't cause any obvious damage.
    Jack McCarthy and Voss[OP] like this.
  15. Feb 14, 2022 at 4:08 PM
    Jack McCarthy
    Bill
    North of Boston
    Mystery solved!
    Voss[QUOTED][OP] likes this.
  16. Feb 14, 2022 at 5:25 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Do you recall what the PXXX # was. Just curious what an unplugged AF sensor would record.
  17. Feb 14, 2022 at 5:27 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I don’t
