VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Mar 12, 2021 at 6:49 AM
    #5431
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    I got an email a week ago saying YWF34 would be in update 1.2.9.8, and I just downloaded 1.2.9.9 and still don't see that available in the supercharged calibrations. Am I looking in the wrong place?
  2. Mar 12, 2021 at 6:57 AM
    #5432
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Not in it yet, but will be this weekend with another big update for the Tundra. We had to release 1.2.9.9 because some older Tundras had an issue where they couldn't flash.
    Edit * it will also include YWF99 and flex fuel table control support\
    Edit ** to be clear YWF99 and YWF34 Def support is already in the software, the stock files just aren't in the installer
    snivilous[QUOTED] likes this.
  3. Mar 12, 2021 at 7:23 AM
    #5433
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    2021 support in the new update?
  4. Mar 12, 2021 at 7:23 AM
    #5434
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Not yet.
  5. Mar 12, 2021 at 7:28 AM
    #5435
    Kung
    KG, VA
    Mallcrl likes this.
  6. Mar 12, 2021 at 7:41 AM
    #5436
    Ghillie93
    Ghillie93 New Member
    James
    09' 4x4
    Intake, Headers, Exhaust.
    Ok, thanks for the quick reply.
  7. Mar 13, 2021 at 5:44 PM
    #5437
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    vF Tuner 1.2.9.9.2 release
    -YWF34 full support
    - Flex fuel control tables (on select ECUs)
    - fixes all communications errors / flashing errors for V1/V2 992kb ECUs
    - ECU Read support (select ECUs) - Read your ECU and save directly as a vF tunable file
    other useful fixes
  8. Mar 13, 2021 at 7:28 PM
    #5438
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    CM052 in there yet?
  9. Mar 13, 2021 at 7:58 PM
    #5439
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    If you update, you can just look in the folder...:p
    So I updated this morning. I don't see any calibrations like the one you listed. All the supercharged calibrations begin YWF... All the N/A calibrations are 89663-0xxxx, ignoring the 89663. 0CM52 is in there and has been for a while, are you transposing your numbers? There's also 0CM52 Upgrade that's been there for a week or so...
  10. Mar 15, 2021 at 5:42 AM
    #5440
    4firemandan
    SWFL
    Yep I was trasnposign them :D
    I havent updated in a while and have been chomping at the bit to open the 0CM51 file just to start playing with the tuner, but Matt said if I did that I would need to use credits to open the CM52(updated) one when it was available.... so I just tried to stay away until it was here. :)
  11. Mar 15, 2021 at 6:57 AM
    #5441
    4firemandan
    SWFL
    OVTune,
    I havent opened anything yet... should I open "0CM52" or "0CM52 Upgrade"? Current file is a CM51 custom from you.
    Also, will either of those CM52 files be able to flash the previous custom 0CM51 on top if I want to?
    apbreaux likes this.
  12. Mar 15, 2021 at 12:07 PM
    #5442
    4firemandan
    SWFL
    Can someone with the Tuner Confirm this?
    I certainly understand for tunes sent OUT to flash, but does the VFTuner not allow us the option to disable DTCs? Even HPT has this option. I definetly want (need) OVT for the ethanol and awesome trans tables.. but I definitely have some DTC's I need to address too.
    TX210Tundra likes this.
  13. Mar 15, 2021 at 5:29 PM
    #5443
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    PM'ed
    @OVTune
    Looking to install a TRD SC on my non FFV 2019..
    Can you assist?
  14. Mar 15, 2021 at 5:58 PM
    #5444
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    If you unlock 0CM52, you can access either regular 0CM52, or 0CM52 Upgrade.
    The 0CM52 upgrade calibration is for 0CM51 trucks so they can upgrade to 0CM52.
    It is fully backwards compatible, which means you can flash BACK to 0CM51 if you want.
    vF Tuner does not have DTC access yet.
  15. Mar 15, 2021 at 7:59 PM
    #5445
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    So we won't get an error message saying that the "current ECU software does not match selected file" when updating from OCM51 to OCM52/OCM52 Upgrade?
  16. Mar 15, 2021 at 8:05 PM
    #5446
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    What’s improved or changes on the 0CM52 upgrade?
    I’m 0CM51 right now with your older style flash tuner.
  17. Mar 16, 2021 at 5:37 AM
    #5447
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    With our new flasher, no.
    Toyota changed the code, improved tables, improved the logic, etc
    apbreaux[QUOTED] likes this.
  18. Mar 16, 2021 at 6:38 AM
    #5448
    4firemandan
    SWFL
    @OVTune
    Are you planning DTC ability for those who do off road stuff and have the mods that throw codes? (Ie: Maf out of limits from larger intake, high flow cats throwing p0230/p0240 etc)
  19. Mar 16, 2021 at 12:48 PM
    #5449
    4firemandan
    SWFL
    Getting unable to save file with the latest download 1.9.9.2
    Any ideas?
  20. Mar 16, 2021 at 12:51 PM
    #5450
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    issues, errors, troubleshooting needs to be sent to zendesk.
    But this specific error is because you're trying to save in the installation folder. Save it somewhere else.
    Wynnded, Challenger1 and HulkSmurf14 like this.
  21. Mar 16, 2021 at 2:14 PM
    #5451
    4firemandan
    SWFL
    Thanks. Zendesk hasn’t responded to several emails in months. I’ve given up on zendesk to be honest.
    osidepunker, realprotundra and Tyger like this.
  22. Mar 16, 2021 at 2:16 PM
    #5452
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    ok well for future reference this is not the place to put troubleshooting errors.
    We have a section for that on our forum
    forum.vftuner.com
    please use it if you don't want to use zendesk.
  23. Mar 16, 2021 at 2:42 PM
    #5453
    4firemandan
    SWFL
    Will do. Thanks
  24. Mar 16, 2021 at 2:55 PM
    #5454
    4firemandan
    SWFL
    @OVTune
    i sent you a reply to zendesk about what you said. It’s a bit of a rant but I think you’ll know where I’m coming from.
    nothing personal just a vent
  25. Mar 17, 2021 at 4:58 AM
    #5455
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Adding in support for 0CL43,
  26. Mar 17, 2021 at 2:17 PM
    #5456
    Challenger1
    Andy
    So.. question..
    For a BASE TRD SC tune for my 2019nnon FFV..
    I need to purchase a VF tune software and cable?
    The Kit for $350 will come with a Base TRD SC tune?
    I can make adjustments to the TUNE as I go as well?
    Am I understanding this correctly?
    wanted to make sure before I make the purchase.
    Thank you in advance
  27. Mar 17, 2021 at 2:30 PM
    #5457
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    You will need to purchase the $350 kit which comes with a Tactrix cable: https://vftuner.com/collections/vf/products/vforest-tuner-software-flash-cable and also purchase the "tune pack": https://vftuner.com/collections/tune-packs/products/tundra-5-7l-2018-vf-tune-pack to get access to the supercharger base calibration. If you just purchase the $350 kit, you'll have access to the "base tune" which is what is stock on the truck, and will have a lot more work to do (and will most definitely need to find a dyno).
  28. Mar 17, 2021 at 2:41 PM
    #5458
    Challenger1
    Andy
    Thank you for the response!
    The BASE tune would be the TRD SC base tune.. Correct?
  29. Mar 17, 2021 at 2:43 PM
    #5459
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    There is no TRD supercharger tune for a 2019 Tundra. TRD stopped providing calibrations for Tundras after 2015, when the program was discontinued.
    You are looking for a base calibration for a supercharged engine, which that tune pack will get you.
    Challenger1[QUOTED] likes this.
  30. Mar 17, 2021 at 2:44 PM
    #5460
    Challenger1
    Andy
    Copy.
    Thank you for the clarification!
Thread Status:
