OVRLND Camper/Tundra Thread
Discussion in 'General Tundra Discussion' started by sea_weathered, Dec 10, 2024.
  1. Jan 26, 2025 at 8:04 AM
    #61
    Kinetix
    Kinetix New Member
    2018 Toyota Tundra TRD Off Road, Limited
    Thanks! This is exactly what I was looking for. How did you access the underside of the front bolts to secure the nut and plate?
  2. Jan 26, 2025 at 8:05 AM
    #62
    Fergie
    Fergie New Member
    To access all the bolts, the factory bed rails have to come out, thats about it. I drilled from the bottom so I knew I could get a socket in there w where I placed the bolt. For the rear one, you just pull the taillight housing and drill up from there.
    Kinetix likes this.
  3. Feb 3, 2025 at 9:05 AM
    #63
    DavidinPhx
    DavidinPhx New Member
    Phoenix
    2021 DC Tundra SR5
    Icons, Deavers, 34s, 4.88s, F&R e-lockers, Ovrlnd Camper, & other stuff
    Bolting the camper to the rails is a great idea for a permanent mount, though FWIW, after 3 years my clamps haven’t loosened or shifted after the first 6 months and couple of re-tightenings, and I do some rough stuff with lots of side to side movement of the camper/bed.
    Either way, on our trucks the plastic bed rail cap is the weak link. In @Fergie ’s first picture, you can see the camper sill pate flexing at the bolt. Mine does this too, and you can see the plastic cap on the outside (not the camper itself) gap slightly to the bedside steel in some places. (Edit: I’m not sure the clamps/bolts cause this or just the camper weight) Even with obsessive sealing of all the voids in the sheet metal bed rail under the plastic cap (I counted 30 of them, seriously, in the sealing process from underneath), and with the PPV I still got a little bit dust coming under the plastic cap in the area of one of the ripples in the plastic cap. I have carefully sealed with some black flexible caulk from the outside now.
    This is all caused by the way Toyota reinforces the underside of the plastic caps, which is not enough. This is a well known problem with Tacomas that I learned about with my previous two. So much so that KBVoodoo makes really nice solid aluminum replacement bed rail caps for Tacomas that are great under toppers/campers. Sadly, they have steadfastly refused to make them for Tundras — I asked a couple times. Not enough volume they said.
    I thought about removing mine pre-camper, but didn’t have anything better to replace them with, so settled for sealing well. Long story short, not long after finishing my camper build out in ’21, I learned about these for this exact problem, but with a heavy tonneau system:
    https://diamondbackcovers.com/products/bed-rail-cap-shims Click on the Tundra link and you can see the install illustration and where the weaknesses are in the caps.
    I can’t vouch for them, not having used them, but if I was putting a camper on now, I sure would buy a set of these and pull the plastic caps, seal the voids from the top (there’s a lot on this on Tacomaworld), and shim them. If I ever pull the camper off, I’ll do it for sure.
    If I was going to use bolts, knowing about this now, and I didn’t pull the caps for shimming, I think I’d want to use even longer backing and top plates to spread the load out. Not sure how much that would help, but worth trying, I think. YMMV!
    Wallygator and Kinetix like this.
  4. Feb 3, 2025 at 10:53 AM
    #64
    Fergie
    Fergie New Member
    I pulled the rail caps and sealed the top w foil backed tape at the recommendation of Jay, prior to the install of the camper itself. I need to seal the doors and tailgate better, as that is where most of the dust is coming in.
  5. Feb 3, 2025 at 11:22 AM
    #65
    frankdux
    frankdux New Member
    Fantastic-looking setup! Which brand flatbed/tray is your OVRLND Camper mounted on?
    STravis[QUOTED] likes this.
  6. Feb 3, 2025 at 11:51 AM
    #66
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    It's a bed that we built here at my shop. I own SOB Fabrication here in NM and it was a project I had been wanting to do for a while.
  7. Feb 3, 2025 at 12:02 PM
    #67
    frankdux
    frankdux New Member
    Bravo -- very well done. Has a very minimalist look yet offers some nice storage niches underneath the tray area.
  8. Feb 3, 2025 at 3:56 PM
    #68
    DavidinPhx
    Phoenix
    2021 DC Tundra SR5
    Yeah, that’s the right way to do it. Do you have the gap/warpage in the of the plastic cap on the outside? I only got a slight amount of dust over a pretty long time, but I could tell it was coming under the cap and over the steel bed rail.
    Definitely agree the TG and barn doors are the place to focus for the most effect. I put a second line of bulb seal where the barn doors hit the TG cap, and then a big TG type of bulb seal on top of the tailgate cap that really made a difference (along with a lot of seal around the TG and even inside it). The downside is I have to open the barn doors to drop the TG, but I don’t mind.
    Wallygator and Fergie[QUOTED] like this.
  9. Feb 3, 2025 at 4:00 PM
    #69
    STravis
    Travis
    Ruidoso, NM
    Thanks! I really love the setup and it works really well for our family.
  10. Feb 15, 2025 at 4:40 PM
    #70
    Fergie
    Fergie New Member
    Alright all....coming back to the [hank hill voice]Propex and propex accessories[/hank hill voice]...
    I've got the propex test fitted in the actual truck, and my original plan had been to have a project box that I could attach the hoses too, and unfurl the hose, stored in the project box, when I need to camp. After thinking about it, and wriggling around under the truck, this isn't the way.
    I'm now using a Harbor Freight Apache box to keep the 2-stage regulator clean, but need to figure out how/where to mount the regulator and apache box.
    Looking at a QD connect, but my main goal is to keep the number of connections to a minimum inside the cabin of the camper.
    I mounted the regulator to a piece of 90* aluminum that Jay provided a while back for the awning install.
    And in the Apache box:
    What is the collective thought of mounting the box here, clearing the door, and having the hoses run through the camper shell itself.
    Please post your pics/thoughts.
    Thanks
    Florida AF likes this.
  11. Feb 24, 2025 at 10:21 AM
    #71
    Fergie
    Fergie New Member
    Decided to go for an underbody mount; really dont like stuff hanging off the side of the camper.
    I installed some rivnuts to the bed, and I'll be able to access the regulator and connection if I need to replace any of them. All off the shelf stuff, so should be able to source parts from any ol hardware store.
    Florida AF and sea_weathered[OP] like this.
  12. Feb 24, 2025 at 1:59 PM
    #72
    Kinetix
    Kinetix New Member
    This was super informational! I think I will order the shims and add them at some point. I did end up bolting through the bed rail. I'm pleased with the result as far as the alignment of the camper and the assurance that it isn't going anywhere. I plan to add a larger top plate to my 4 corner bolts as there is noted deformity in the aluminum, and I'd like to distribute the pressure of the bolt a bit more.
    DavidinPhx[QUOTED] likes this.
  13. Feb 26, 2025 at 6:14 AM
    #73
    sea_weathered
    sea_weathered [OP] New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Put my truck on the scale yesterday.
    1/2 tank of gas, 1/2 full of water, and my 210lbs in the driver seat.
    The 10ply 37” Falken Wildpeaks are heavy too
    IEsurfer and Wallygator like this.
  14. Apr 11, 2025 at 11:10 AM
    #74
    sea_weathered
    Pacific Ocean
    Making some changes to the rig. I swapped out the 0mm offset wheels for a +25 set of those new Nomad Convoys, and ordered a custom leaf pack from Alcan springs to carry an additional 1400# of my fully loaded camper. Once the springs are mounted, I’ll take a good measurement of shock mounting points, and have Accutune custom valve a set of Fox 2.0 resi shocks to match. That should pretty well dial in my rear suspension IMG_6625.jpg IMG_6622.jpg IMG_5984.jpg
  15. Apr 11, 2025 at 11:37 AM
    #75
    Fergie
    Fergie New Member
    Would you mind sharing some detailed specs on the spring packs? My OME packs are about 5 years old and starting to sag.
    sea_weathered[OP] likes this.
  16. Apr 11, 2025 at 12:30 PM
    #76
    Wallygator
    Subbed!:thumbsup:
  17. Apr 11, 2025 at 2:18 PM
    #77
    sea_weathered
    Pacific Ocean
    I started by weighing my truck and estimating the additional weight of the camper when fully loaded, you can see my post above with the final results. This calculated out to around 1400# for my fully loaded camper. Then I just called Alcan springs and told them what I had and that I wanted 2” of lift in the back. They did the rest. I opted for a U-Bolt flip kit, upgraded bump stops, and a longer set of shackles. They suggested calling Accutune suspension to get a set of shocks that would compliment the new springs. I won’t have them on for a couple of weeks, but supposedly this is going to dramatically improve the ride quality, both on and off road. With everything done, I’ll be around $2500 in for the rear suspension to be dialed
    Fergie[QUOTED] and Wallygator like this.
  18. Apr 11, 2025 at 2:27 PM
    #78
    Tundra family
    Tundra family New Member
    Hot dang, that's nice! What's your total weight lookin like?
  19. Apr 12, 2025 at 1:49 AM
    #79
    sea_weathered
    Pacific Ocean
    7680# with me sitting in the truck
    Tundra family[QUOTED] likes this.
  20. Apr 12, 2025 at 5:45 AM
    #80
    Tundra family
    I didn't realize yours was a double, are you over max GVWR? I'm sitting at 7140 with a max of 7k. How are you liking the alcans so far? I desperately need to replace my W shaped springs.
  21. Apr 12, 2025 at 8:53 AM
    #81
    sea_weathered
    Pacific Ocean
    I’m definitely over GVWR. According to a quick google search, my truck had a 7200# rating. I plan to install the springs next week and will post about my initial impressions. Alcan has a solid reputation, so I’d imagine it will be good
  22. May 5, 2025 at 8:58 PM
    #82
    sea_weathered
    Pacific Ocean
    Okay, 1400# over leaf pack from Alcan suspension, and a custom tuned set of Fox 2.5 Performance Elite shock from Accutune. The ride is incredible!
  23. May 6, 2025 at 6:51 AM
    #83
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    What does putting the leafs on top of axel accomplish
  24. May 6, 2025 at 6:54 AM
    #84
    sea_weathered
    Pacific Ocean
    ?? That’s the way Tundra’s are built. Some people convert to spring under axle, for more up-travel I think. But that’s out of my wheelhouse
  25. May 6, 2025 at 7:30 AM
    #85
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My rear shocks get a lot of abrasive wear in the lower half, especially the driver side one. This shock was installed 6-7 months ago, did 4k miles, have seen log roads twice only.
    With shock mounted up side down, a polished shaft gets pitted quickly and tears the seal. I'm not sure how long yours will survive. My MTB FOX shocks manual say keep the shaft clear of grime and avoid damaging its coating. FOX shocks on wife's TRD PRO Sequoia are mounted the regular way and have rubber boots covering the shaft.
  26. May 6, 2025 at 8:51 AM
    #86
    coveyrise12
    coveyrise12 New Member
    2012 Tundra Crew Max
  27. May 6, 2025 at 1:45 PM
    #87
    sea_weathered
    Pacific Ocean
    Wow! The road conditions where you live must be much harsher than where I live. I mounted these shocks in accordance with the manufacturer’s guidelines. I have never experienced the accelerated wear you are describing.
  28. May 6, 2025 at 1:46 PM
    #88
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No gravel roads where you live?
  29. May 6, 2025 at 8:56 PM
    #89
    sea_weathered
    Pacific Ocean
    Tons of gravel roads here, but I’m not seeing the kind of accelerated wear you are describing. The 2.0 Fox shock on the left of this photo has 70k miles on them, and with a little wipe down would look nearly new. They were mounted shaft down, without rubber boots. IMG_6926.jpg
  30. May 7, 2025 at 3:47 AM
    #90
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Interesting. All my rear shocks were damaged like that, even with the stock AT imitation by Michelin. I'm even thinking of welding a pair of bolt-on shock shields.
