OVERSIZED spare: Let's see how/where you carry when wheeling
Discussion in 'General Tundra Discussion' started by Eclipsed & Floating, Apr 3, 2017.
  1. Apr 3, 2017 at 5:38 PM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    For those of you that carry an oversized spare when wheelin', where do you "hide" it since it doesn't fit underneath?
    OR, if you have modified to make it fit underneath then show that too. I'm on 35's and would love some ideas without going the TOO terribly expensive route.
    Also, for those of you that dropped more than few dimes, let's see that set up too.
  2. Apr 3, 2017 at 5:42 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    @jberry813 has some pics in his build thread I believe.
  3. Apr 3, 2017 at 5:47 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    295/70/18
    DVYota, Lilly, darkknight2014 and 4 others like this.
  4. Apr 3, 2017 at 5:52 PM
    Pvarela07
    Pvarela07 New Member
    2014 Silver Tundra SR5 TRD Off-road 4x4
    Just getting started
    Wow that's supper close to the shackles, is it that tight on the other side as well?
    I was thinking about getting a full size (same as yours) but don't think it will fit with CB shackles.
  5. Apr 3, 2017 at 5:52 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Did you have to make it fit?
    Found it. Thank you sir.
    I'd really like a 5th 35 to do a 5 tire rotation but don't want to fork over the extra $$ on a 5th rim. I'm probably gonna do the smaller tire. Shit, it's just a spare, right?
  6. Apr 3, 2017 at 5:54 PM
    Eclipsed & Floating
    Voluptuous Whitey
    It looks like you've got less than 1/2 inch to the shackle. At least in the picture it looks like that. Any chance that shackle would hit the tire if the back end twists on some rocks?
  7. Apr 3, 2017 at 6:01 PM
    Eclipsed & Floating
    Voluptuous Whitey
    What mode are you Goin in?
  8. Apr 3, 2017 at 6:08 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    There's a little more space on the other side. Definitely a tight fit but it does clear everything. CB shackles would definitely rub in this size. That was one of the reasons I got the Toytec shackles.
  9. Apr 3, 2017 at 6:15 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Since I don't have my truck and can't look, help me remember...with the standard BOSS 2.0 setup, shackles don't come with, right? If not, what would factory setup look like on a '17 DC (not a PRO)?
  10. Apr 3, 2017 at 6:15 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    2 questions
    1: will a 35 fit in the space of out spare..
    2: all of you guys that have a 6 inch lift or more, do you have a spare for that casie we can't use our stock ??????
  11. Apr 3, 2017 at 6:17 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Why not get a rack and mount it up on there? I'm thinking of doing that.....doc ain't gonna be happy...
  12. Apr 3, 2017 at 6:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You should either have the shackles or blocks on the rear.
    040Tundra likes this.
  13. Apr 3, 2017 at 6:19 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I sound like an amateur (because I am) but I can't remember what's under there at this moment. Pretty sure it's shackles.
  14. Apr 3, 2017 at 6:20 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When you ordered, you had an option to replace the rear blocks with shackles for additional $40 or something like that.
  15. Apr 3, 2017 at 6:21 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I do have a rack coming that will be last resort if I don't come up with something else. My rack is going to be used to tie down my kids. I'll have gear in the front I don't want muddy!!
  16. Apr 3, 2017 at 6:22 PM
    Lmao I asked bout this thread....if u use stock spare put it up front you'll mess up rear end ...think u can fit 35 with some trimming hopefully someone who has will chime in
  17. Apr 3, 2017 at 6:22 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I know but that was a couple months ago and I went back and forth so many times because I was really ignorant and didn't know what I was doing. I can't remember what I did now. I'll get my truck back tomorrow and confirm
  18. Apr 3, 2017 at 6:25 PM
    Eclipsed & Floating
    Voluptuous Whitey
    We can strap her down with my kids on the rack
    Law323[QUOTED] likes this.
  19. Apr 3, 2017 at 6:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My tires are 34.5". Most 35's are about the same size. Should fit the same. There's also a bracket that holds the tire in. If you remove it, you can move it forward just a bit. That should be enough to fit any 35.
    040Tundra and Jsena like this.
  20. Apr 3, 2017 at 6:27 PM
    What about with 20*9 wheel?
  21. Apr 3, 2017 at 6:29 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wheel size doesn't matter. Mines 9" wide too so won't make a difference.
  22. Apr 3, 2017 at 6:35 PM
    Gotta find me used steel wheel n buy a spare
  23. Apr 3, 2017 at 6:39 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    It's gonna suck to buy a $900 spare tire ¯\_(ツ)_/¯
  24. Apr 3, 2017 at 6:39 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Could also go with a full size 34
  25. Apr 3, 2017 at 6:40 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Perfect. Just get some fists and straps em down!! Won't go anywhere!
  26. Apr 3, 2017 at 6:43 PM
    Checking Craigslist offerup letgo find good used one gonna check local fix flat tire shops
    Jsena[QUOTED] likes this.
  27. Apr 3, 2017 at 6:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Well, if you have a matching spare, you can do a 5 tire rotation... so at least your tires will last longer. Only thing you're really paying more for is the wheel and TPMS. My wheel and TPMS was an extra $200.
    J4RR3N4 and Jsena[QUOTED] like this.
  28. Apr 3, 2017 at 6:47 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Very true.. never thought of that.. haven't bought the sets yet but was looking at toyo which will be $400 plus and the rim is $350 for the 2 I'm looking at.. but @aramirez73 good idea too. Thanx guys ᕙ(ツ)ᕗ
  29. Apr 3, 2017 at 6:49 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Pl
    I'm gonna leave my kids unlocked so hopefully they'll run off at the first truck stop
  30. Apr 3, 2017 at 7:27 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    37" I have in the bed with tie-downs and locking system. Can move out of the way if needed and tied down tight enough for off-road use to. Placed it in the front passenger side of the bed for best weight distribution.
