Overheating for a second, then returning to normal temp quickly???
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Dec 23, 2020.
  1. Feb 21, 2024 at 3:20 AM
    bflooks
    bflooks New Member
    Metrowest MA
    The only times I've had this happen was with a bad t-stat. First showed while towing (240'ish), then was able to watch 10-20* (200-210'ish) warmer temps during daily commutes.
    $27 part, 30 minutes, and a few gallons of coolant. Hardest part is getting to the back bolt. This was around 27k miles.
    Good luck and report back. The broken cap thread was a big help in troubleshooting, and if the intermittent spikes in temps is proving to consistently be a t-stat, that could help others.
    cdavi060 likes this.
  2. Apr 25, 2024 at 4:06 PM
    Chucksmith07
    Chucksmith07 New Member
    Chuck
    Mine did this same thing. Not towing driving kids to school twice in two days. Then none today. Its spikes then goes right back down. I ordered new cap and temp sensor. My truck is a 2014 with 114k miles. We shall see.
  3. Oct 10, 2024 at 4:52 AM
    NolaTundraGuy
    NolaTundraGuy New Member
    2015 Tundra Crew Limited 5.7L just started having the same issue. It happened 2 times, about 2-3 weeks apart. Same story, driving on interstate...suddenly the overheat light comes on the dash, as I attempt pull over I see the temp falling and goes back to normal with no light. Not hauling or pulling anything, just 70mph on interstate. I have 195k miles. If anyone found a fix, please post your experience! Thanks!
  4. Oct 10, 2024 at 5:05 AM
    Chucksmith07
    Chuck
    I installed new temp sensor and actually had to add some fluid. Mine was doing the same exact thing. Did that and has not happened since.
    NolaTundraGuy and Tunrod like this.
  5. Nov 20, 2024 at 1:26 PM
    NolaTundraGuy
    FOLLOW UP - Problem Fixed!
    Changed the coolant temperature sensor! $26.99 at AutoZone and took about 5 minutes to swap! I didn't do anything else. No fluid exchange, no radiator cap swap. I did check my fluid level and radiator cap, both was all good. Thanks so much for all the info here!
    I meant to respond sooner but life got me sidetracked!
    Wynnded and Tundra family like this.
