Overheat only in 4 high
Discussion in 'New Member Introductions' started by Trocchio, Aug 4, 2022.
  1. Aug 4, 2022 at 4:03 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  2. Aug 4, 2022 at 7:05 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I can't contribute to the help, but I am learning a lot myself. Welcome!
  3. Aug 5, 2022 at 3:05 PM
    Trocchio
    Trocchio [OP] New Member
    2006 Toyota Tundra TRD
    No modifications factory
    THANK YOU FOR THE INFO IT SURE CANT HURT A THING DO DO THE FLUID CHANGE
  4. Aug 5, 2022 at 10:36 PM
    Trocchio
    Well fellas I wish I could tell you it was just a fan clutch but I went to put it in and ended up having to pay a stupid tax for those of you that don't know what a stupid tax is that's when you take a shortcut and it ends up costing you more money for not doing it the correct way the first time so after installing the new radiator (because I punctured the old one with the new fan clutch hence the stupid tax) the new fan clutch, thermostat and radiator cap I no longer have an overheating problem I cannot tell you which one was the problem but thank you all for every little bit of help that you gave me I sure do appreciate it
    frichco228, Bakershack, MS22 and 2 others like this.
  5. Aug 6, 2022 at 12:29 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If it was the original rad it was probably a good time to go ahead and get it knocked out anyway. At least your problem is solved.
    Trocchio[QUOTED][OP] and des2mtn like this.
  6. Aug 6, 2022 at 12:35 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Glad to hear that you're no longer experiencing any problems. Truck should be good to go for many more years. As far as I'm concerned, you ended up doing things the correct way with the parts you listed - unless that radiator you damaged was brand spanking new.
    Trocchio[OP] likes this.
  7. Aug 6, 2022 at 7:57 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I hate that stupid tax almost as much as I hate federal taxes!
    Trocchio[QUOTED][OP] likes this.
