Overfilled Engine Oil Fix
Discussion in '3rd Gen Tundras (2022+)' started by iancw, Jan 5, 2024.
  1. Jan 7, 2024 at 8:16 PM
    Tom976
    Tom976 New Member
    Tom
    It does make it cleaner. First, if you even changed oil on a windy day.... well that gets 75% oil in the oil drain pan and the rest will be on the floor or something else... happens with wind gusts and near the end when its the thinnest oil that takes 20 minutes to wrap up. Keep that ratchet and socket nearby to get a nice coaling of fresh oil to wipe off. They'll look like new.
    Put a hose on it in and a hurricaine wont get it to splatter all over.
    Secondly, if you have a plate protecting it like my RCI. There's a hole in the plate under the oil drain. When draining oil its guaranteed to get to the underside of the plate.
    Enough extra oil and its drip itself down your driveway making a nice new oily mess. I dont speak from experience.
    Again, using a clear hose on it.... No mess.
    Woocawachie[QUOTED] likes this.
  2. Jan 7, 2024 at 8:27 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    The only problem with the Fumoto is it takes an absurd amount of time to drain especially when its cold like 30-45 minutes, otherwise this is your best bet.
  3. Jan 7, 2024 at 8:33 PM
    Tom976
    Tom976 New Member
    Tom
    Thats very true. Cold oil drains slow. But one of the primary benefits is to get that oil circulated nice and hot so more things are in suspension then drain.
    Roborob70[QUOTED] likes this.
  4. Jan 8, 2024 at 7:15 AM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    true it does drain slow. I just start the drain process first and take my time with the rest. As noted the best part is no mess and not having to remove and retorque the pan bolt every time, and you can get the oil up to operating temp for draining and not burn the shit out of yourself draining it.
    4genRunner and AZBoatHauler like this.
