Over-sized Spare Tire Woes....
Discussion in '2.5 Gen Tundras (2014-2021)' started by deedubb, Mar 11, 2019.
  1. Mar 11, 2019 at 11:50 AM
    That's freaking schweeeet!
    Erichudgins[QUOTED] likes this.
  2. Mar 11, 2019 at 11:51 AM
    Notachickmagnet
    Notachickmagnet New Member
    15whtrd[QUOTED] likes this.
  3. Mar 11, 2019 at 11:52 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    the functionality of it was top notch. this is the new design. so smooth. no sagging. really a solid setup.
  4. Mar 11, 2019 at 11:53 AM
    I'm trying to remember as well, either you or someone else had there's like a winch to lower n raise tire????
  5. Mar 11, 2019 at 11:56 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    wasn't me lol. but it not bad. sets right up on a threaded rod :) and then just thread the stop on and lock it. set.
  6. Mar 11, 2019 at 2:27 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I'm in the same boat - 37s w/o spare and don't really want to bed-mount or tailgate-mount. I know many have trimmed the tabs and fit a 35 under the bed in the spare mount location. I'm wondering if a deflated 37 would fit under there? I plan on attempting that when I get around to it. Maybe throw a ratchet strap around the tire & crank it a little more narrow to fit between the shackles, too.
  7. Mar 11, 2019 at 2:32 PM
    15whtrd
    15whtrd Mr. Blonde
    Deflate it with a ratchet strap wrapped around it. I guarantee it will fit LOL. Carry a nice compressor.
  8. Aug 21, 2023 at 2:05 PM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    I know this is an old post but were you able to make a 37” fit this way?
  9. Aug 21, 2023 at 2:11 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've never heard of anyone getting a 37 under the truck.
  10. Aug 21, 2023 at 2:17 PM
    gabex35
    San Diego
    I’ve seen a couple references of people using a ratchet strap but haven’t seen anyone confirming they were able to do it.
  11. Aug 21, 2023 at 2:28 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Run no spare and get a tire repair kit, and carry an air compressor
  12. Aug 26, 2023 at 6:48 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    Sorry for the late reply. No, it didn’t even come close to fitting. Airing down & ratchet strap didn’t help at all.
    I ended up just mounting it in the bed, on the side, which doesn’t obstruct rearview mirror. I only install it for long trips. Driving around home I keep it in the garage.
    It’s not a perfect solution, but it’s pretty darn close for me anyway. I like it. It doesn’t take up all that much room in the bed (not nearly the amount as if it was laying flat), and it’s a decently clean mount.
    It’s solid as a rock. Doesn’t budge. The only crappy part is it required me drilling holes in the bed to install the anchors, which I really did not want to do. I’m over it now though. It’s very functional and works really well.
    This is the “H” tie-down I used. I’m sure you can get it from other places, I think I had a coupon from Zoro and it was the cheapest:
    https://www.zoro.com/bulldog-winch-vertical-tire-ratcheting-h-tie-down-strap-20362/i/G100972228
    Anchors from Amazon:
    https://www.amazon.com/gp/aw/d/B07H9ZKRH6?ref=ppx_pop_mob_b_asin_title
    Picked up some grade 8 (I think 1/2”) nuts/bolts. (As you can see in the last picture from underneath, clearly I have to replace them as they’re getting a bit corroded.) Had to drill out the hole in the anchors to fit it. Last pic from underneath - that’s a piece of 1-4” aluminum I used to distribute the pressure when I crank down on the ratchet strap so the bed doesn’t crack.
    I added the strap going across the face of the tire just to minimize any movement when turning. It’s probably not needed & does make it look worse, but it’s solid.
    Thickest chain/lock I could find in Home Depot to deter theft (with cloth sleeve over chain so it doesn’t scratch up the wheel).
    gabex35[QUOTED] and B.Ross like this.
