Outboard Air - ViAir 400P automatic
Discussion in 'General Tundra Discussion' started by BlueBottle, Dec 25, 2017.
  1. Dec 26, 2017 at 6:45 PM
    #61
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Wow it is fully automatic badass!
    I tried to watch the video but every other word he said was fa}>. So anyone trying to watch this with kids don’t watch it when they are around!!!!!
    831Tun likes this.
  2. Dec 26, 2017 at 6:50 PM
    #62
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That thing is pretty cool. Will it inflate a 35" tire?
  3. Dec 26, 2017 at 10:51 PM
    #63
    BayRunner
    2017 Tundra Platinum
    Sorry about that. I found the video and had the volume turned all the way down.
  4. Dec 26, 2017 at 10:55 PM
    #64
    BayRunner
    I would assume so. Handled my 33's well on several occasions. On one occasion I put 60 psi in all four for a heavy load.
    831Tun[QUOTED] likes this.
  5. Dec 29, 2017 at 6:31 PM
    #65
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Spent most of the day fiddling with this:IMG_20171229_153210_203 (1).jpg ARB.jpg
  6. Dec 29, 2017 at 6:32 PM
    #66
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Looks good Warren!
  7. Dec 29, 2017 at 6:34 PM
    #67
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Origami in aluminum.
  8. Dec 29, 2017 at 6:51 PM
    #68
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    @joonbug @GodlessPro @BlueBottle If one of you guys has a chance to measure the height of your Viair I'd appreciate it. I wanna be sure this mount will work the Viair as well as the ARB single and double.
  9. Dec 29, 2017 at 9:29 PM
    #69
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Dimensions: 10.87″L x 5.83″W x 7.48″H
    dcsleeper408 likes this.
  10. Dec 29, 2017 at 11:23 PM
    #70
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks @BlueBottle . I made the mount from one piece of diamond plate cut and bent,,,,, full on Origami. When I take it to @renosauce he'll be able to make adjustments to the "platform." The prototype is close.
  11. Dec 29, 2017 at 11:26 PM
    #71
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Sweet!
  12. Dec 30, 2017 at 5:11 PM
    #72
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Done! That was so easy and satisfying. Thanks @BlueBottle for sharing this hack.
  13. Jan 2, 2018 at 9:25 AM
    #73
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Glad you like it! Did you make one for Joon?
    Has anyone used this inflator? The one that comes with ARB is just ok. I don’t like the chuck they use as it requires two hands.
    ARB ARB605 Blue Inflator with Gauge and Braided Hose https://www.amazon.com/dp/B0036ULEV0/ref=cm_sw_r_cp_api_tb8sAb3PZXG2J
    joonbug likes this.
  14. Jan 2, 2018 at 9:42 AM
    #74
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I think the ARB inflator is pretty much the same as your Viair just with a deflator button.
    BlueBottle[OP] likes this.
  15. Jan 2, 2018 at 11:00 AM
    #75
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I ordered one of the Blue Inflators that you referenced and will let you know. It's supposed to be the clip on type (straight on clip).
  16. Jan 2, 2018 at 11:24 AM
    #76
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have a button deflator on my viair. It’s the clip on that I like. On the viair it’s a lever and on the arb it looks like you press is down and it clips on. Hard to swallow the price though just for that.
    Keep us updated! Also let us know if the reading is different and does it keep a reading while inflating?
    ccdawnpatrol and joonbug like this.
  17. Jan 2, 2018 at 11:27 AM
    #77
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, having to hold the lever for 10 minutes straight is not fun.
    ccdawnpatrol likes this.
  18. Jan 2, 2018 at 11:31 AM
    #78
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You do yours yet? Come over and I’ll wire yours up. I’m fee today.
    joonbug[QUOTED] likes this.
  19. Jan 2, 2018 at 11:35 AM
    #79
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    oh ok. I get what you mean now. Never mind my post then..
    I've seen some one on instagram with a auto no need to hold..I'll look around for it later.
    But my Harbor Freight Air comp doesn't need to hold ;)
    joonbug and BlueBottle[OP] like this.
  20. Jan 2, 2018 at 11:39 AM
    #80
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    For everyone doing this mod. Just be mindful that you would have to use it only with a vehicle with the trailer harness.
    I swap my Air comp from car to car depending on the travel.. The wife's Acura RL doesn't have a trailer harness what so ever. An option would be a quick disconnect butts to the clamps, but that's another mod Mike will have to write up! ;)
    Still a great mod!! Just be mindful if you guys carry it on other vehicles.
    BlueBottle[OP] and 831Tun like this.
  21. Jan 2, 2018 at 11:57 AM
    #81
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I’m actually going to do this. Just been lazy and haven’t ordered my quick disconnectros. I’m going to use the same connector that the battery tender uses so you can actaually use the battery tender alligator leads!
    dcsleeper408[QUOTED] likes this.
  22. Jan 2, 2018 at 11:58 AM
    #82
    BlueBottle
    '16 Platinum 4x4
    See fine print
  23. Jan 2, 2018 at 12:35 PM
    #83
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What does that mean? You charging a fee today? Will it be free tomorrow?
  24. Jan 2, 2018 at 12:44 PM
    #84
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Free! Typo. Free today only! You should be able to find that plug at autozone.
  25. Jan 27, 2018 at 8:18 PM
    #85
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Finally got a chance to test the ARB.
    The clip on is much easier to use. The air release seems to be slower than the viair. The gauge is more accurate and has better detail than the viair. I like it.
    2B4ABE8E-BD1D-4735-8DEF-D0BC46337C53.jpg B7F676E8-BDED-4E5D-8673-FA18DC2DEF52.jpg AC4900CD-0657-4250-902C-CF101EF1DD0A.jpg 87538D7F-50F4-47BA-BD7D-134865A7C0FA.jpg 79103F9B-812D-4C53-8DC9-570ED2263DC8.jpg
    froggy78, blue16, ChucklesToy and 2 others like this.
  26. Jan 27, 2018 at 8:21 PM
    #86
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Dude!!! You have skills AND gadgets that would make Mr Wizard cream his shorts
  27. Jan 27, 2018 at 8:29 PM
    #87
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Thanks for the update. I haven't had a chance to test the ARB, so it's good to see your results.
  28. Oct 18, 2020 at 7:22 PM
    #88
    JRP
    JRP New Member
    Thanks for sharing this idea, @BlueBottle. I appreciate you for doing this and I'm planning to have this setup on my Tundra. How is it holding up? Did it blow up anything from connecting to 7-Pin trailer plug? How's your air compressor holding up? I'm thinking of getting the Viair 45043 due to its 100% duty cycle. I'm actually debating between the Viair 40045 and the Viair 45043. The price difference is $39.95. Is the Viair 40045 enough for our Tundra?
