Outboard Air - ViAir 400P automatic
Discussion in 'General Tundra Discussion' started by BlueBottle, Dec 25, 2017.
  1. Dec 26, 2017 at 11:37 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I should have ordered 2. I'm going to do it on my current compressor and will probably want to do it when I upgrade to the 400 or 440.
    joonbug[QUOTED] likes this.
  2. Dec 26, 2017 at 11:42 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I meant one for me!
    GodlessPro[QUOTED] likes this.
  3. Dec 26, 2017 at 11:46 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I might have an extra one for ya.
  4. Dec 26, 2017 at 11:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’m gonna wait til Matt uses it at least 5 times to make sure his compressor doesn’t blow up or something. ;)
  5. Dec 26, 2017 at 1:06 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Red clip to +
    Black clip to -
    I can send you the diagram when I get home if you like.
    B9FCB7FA-9923-47C6-8698-E8D95EE38DDE.jpg 76B0FA72-2C0F-4651-957A-12F67A7597FF.jpg
    Berdine, 831Tun, GodlessPro and 6 others like this.
  6. Dec 26, 2017 at 2:15 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    KWC, Ely010606, GodlessPro and 3 others like this.
  7. Dec 26, 2017 at 2:17 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    [QUOTE="BlueBottle, post: 453302,
    Here are the pinouts [/QUOTE]
    Thanks!
    BlueBottle[OP] likes this.
  8. Dec 26, 2017 at 2:38 PM
    GodlessPro
    Matthew
    NorCal
    I knew what you meant, but I figured you would do this before the next time I see you.
    I'll bring my bike pump for backup :p
    joonbug[QUOTED] and ccdawnpatrol like this.
  9. Dec 26, 2017 at 3:01 PM
    boloson
    boloson New Member
    Never understood why installing in the engine bay is the best location asides from its close proximity to the power source. Wouldnt the heat & dust/ dirt drastically affect the compressor's performance & durability?
    ccdawnpatrol likes this.
  10. Dec 26, 2017 at 3:21 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    Good question. I don't know but I think since it is close to the power source is good reasoning. I have seen people mount them under the rear of the truck. Seems like it would get dirty there too from rain, dirt, snow etc. Also you have to get down low to see the hook-up location turn on etc. But I like under the seat location as an option even though it would take away from the ESP storage options, something I do not have but looking into. This is a good post: https://www.tundras.com/threads/new...v-soon-to-be-released.8869/page-3#post-452317
    Side note, the Tacoma has a cutout in the bed, has anyone looked into cutting their bed to have a small cubby and install the air compressor there?
    joonbug and 831Tun like this.
  11. Dec 26, 2017 at 3:44 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Like @ccdawnpatrol stated. It’s the best location. Some have put it in their bed but you have to jump in there for each use. Inside the cab and it will be noisy and you have to keep a door open to use it. If you want inside the cab look into that nsv. Only thing I don’t like with it is it’s specs are pretty low for how much they charge. It’s nice though. I think for Me it’s either portable lie I have now or hardwired under the hood.
    831Tun and ccdawnpatrol like this.
  12. Dec 26, 2017 at 3:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Under the hood keeps it away from the elements. When and what would you use the compressor for?
    Air horns
    Lockers
    Air bags
    Tires
    Utilities/ air mattress etc. when camping.
    For the first 3, you'd need to run an air hose out of the cab. That's a pretty big hole but possible. Most areas you'd be routing the hose through 2 walls from what I've seen while running wires.
    For the last 2 you've gotta have the door open. Rain and it's coming in the cab. With the addition of a pressure switch you can sit in the cab while airing up something outside. You're really not losing any storage putting it under the hood and, as mentioned, you're closer to the electrical source and well as air horns or front a locker.
    As far as under the truck, for me that means it'll be under water sooner of later.
    Those are my reasons for mounting under the hood.
    ccdawnpatrol and BlueBottle[OP] like this.
  13. Dec 26, 2017 at 4:18 PM
    ccdawnpatrol
    Salt Lake City, UT
    Boom, nailed it.
    This was the post I was referring to regarding putting it in the bed of the truck. https://www.tacomaworld.com/threads/closed-arb-compressors-2-0-group-buy.515197/
    Obviously the Tundra does not have cutouts for this but have you heard/seen anyone who has done this before? The Tacoma already has them and this is just a mount to make it sit secure in that bed. But there in lies the problem of having it be super far away form the battery, unless you can hook it up to another power source back there. (something I obviously have no clue if is available and would work) Also I bet this would be loud since there's nothing else surrounding it, might require some sound deadening material to help.
  14. Dec 26, 2017 at 4:19 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’ve never had a permanent mount compressor. Have seen lots of custom rigs with em and I like admiring the installs. I’ve probably had at least 8 portable compressors, a couple were threaded into the spark plug hole to use the engine. I’m content to get it out of my toolbox when it’s needed and it’s always clean and safe. Two were set up to use plugs upfront that also would connect jumper cables without lifting the hood. @BlueBottle has an idea that suits me just fine, using the rear trailer plug!
    831Tun and BlueBottle[OP] like this.
  15. Dec 26, 2017 at 4:28 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So what’s your fav portable unit to date? I’m wondering if the 400p was a good deal overall. Some cost more some less. So hard to buy stuff.
  16. Dec 26, 2017 at 4:45 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks, ordered mine earlier, cant wait. I think this is the most convenient and logical for my needs. I can go riding with my buddys, and i can just bring it with me and use there hitch if I ever need to use it , cause sometime i just put my bike in there trailer if there is room. Thanks again.
  17. Dec 26, 2017 at 5:13 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's a slick set up. I would think it'd be pretty easy to mod into a Tundra. Once you've cut through the inner bed wall you'd have easy access for wires and a hose. You've gotta run fairly big wires as the ARB has a 40 amp fuse.
    There sure are some advantages to portable unit and @BlueBottle 's plug is slick! I've never heard of one that works off an engine cylinder, cool concept. I have heard of using the exhaust but I can't imagine developing much pressure from the exhaust.
    ccdawnpatrol[QUOTED] likes this.
  18. Dec 26, 2017 at 5:21 PM
    ccdawnpatrol
    Salt Lake City, UT
    Maybe you want to be the guinea pig/trailblazer and show everyone how it's done by cutting into your bed...then we can all know what not to do! Ha. But I would highly consider doing this mod if I knew what I was doing in regards to cutting it and mounting. Maybe it is possible to hook up the compressor to the trailer plug every time. Saves wiring all the way up to the battery and could make it a more portable rig if you wanted to take somewhere with a buddy that did not have one, right?
  19. Dec 26, 2017 at 5:21 PM
    #49
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This is the one that I carry now.
  20. Dec 26, 2017 at 5:25 PM
    #50
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The ones I had that used the spark plug hole were back in the ‘70s and ‘80s. With engines as sensitive as we have today, I wouldn’t want to do it. Probably start throwing codes and have to get towed to a dealership, lol.
    831Tun[QUOTED] likes this.
  21. Dec 26, 2017 at 5:33 PM
    #51
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  22. Dec 26, 2017 at 5:40 PM
    #52
    BlueBottle
    '16 Platinum 4x4
    See fine print
  23. Dec 26, 2017 at 5:43 PM
    #53
    Berdine
    Binghamton, NY
    PRO: Your method is $200 cheaper, glad you posted this! I've been looking for something like this for kids stuff, atv, beach and such.
  24. Dec 26, 2017 at 5:44 PM
    #54
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    ^^^^^ Agreed, very clean. One thing to keep in mind is the heat generated by theses compressors. Joon's was hot enough to burn the crap out of you after a couple of tires.
    dcsleeper408 and BlueBottle[OP] like this.
  25. Dec 26, 2017 at 5:45 PM
    #55
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @16tunterd stated the problem with this pretty well (post 42). Lots of drawbacks to having to leave the door open and to having all that noise in the cabin. Quite a few custom set ups have a permanent mount in the bed with air lines routed to each side of the truck with quick connects. It does look cool under the seat, but I’m sticking to the tool box!
    BlueBottle[OP] and 831Tun like this.
  26. Dec 26, 2017 at 6:18 PM
    #56
    BlueBottle
    '16 Platinum 4x4
    See fine print
    That’s odd. Mine was only warm after doing 6 tires from 20-40psi In a row. Things the 400 runs cooler than the 450? It’s 33% duty cycle compared to the 450’s 100%
  27. Dec 26, 2017 at 6:32 PM
    #57
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That is interesting. I didn't try burning myself. I just chickened out and took his for it. Maybe @joonbug can confirm if we can get him away from the roulette wheel :D.
  28. Dec 26, 2017 at 6:35 PM
    #58
    BlueBottle
    '16 Platinum 4x4
    See fine print
    He oro
    He probably lost all his money by now lol. So maybe he’s at the penny slots getting free drinks!
  29. Dec 26, 2017 at 6:35 PM
    #59
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Getting ready to zip line down Fremont St.
  30. Dec 26, 2017 at 6:41 PM
    #60
    BayRunner
    2017 Tundra Platinum
    I'm definitively interested in the NSV unit, but up to now have been using the newer Kobalt unit.
    (edited and replaced video with Lowes link)
    https://www.lowes.com/pd/Kobalt-12-Volt-Car-Air-Inflator/1000092575
    Definitely not intended for heavy duty use, but for $45 has served me well the several times I've used it. Both 12 volt and AC with a built in cutoff. Key in the desired pressure, press the start button and it cuts off automatically at the selected PSI.
    831Tun likes this.
