Other seats compatible with a 2000 Tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by Justinholke, Oct 19, 2018.
  1. Oct 19, 2018 at 8:39 PM
    Justinholke
    Justinholke [OP] New Member
    Justin
    2000 Toyota Tundra TRD
    None
    Does anyone know if there anyone other seats that are compatible with a 2000 Tundra ie. Bolt in.
  2. Oct 20, 2018 at 6:49 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Tundra seats.
    I’m so funny. :lalala:
    ThatSR5Tundra, SeanL and Darkness like this.
  3. Oct 20, 2018 at 7:34 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's true actually lol. You can swap from bench to captain's chairs if you stay with tundra seats. There is no direct bolt on that I am aware of, maybe sequoia. A lot of guys here have swapped for seats from other makes but there is some modification involved. I've seen Escalade, subaru wrx and mini cooper seats used in here.
    I know Corbeau makes cool looking seats and bracket adapters to fit the early Tundra but I have read horror stories about them. Recliners snapping while driving and leaving people looking at their ceilings.
  4. Oct 20, 2018 at 9:51 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I saw a build on here where a guy used Mini Cooper seats I think on a first gen
  5. Oct 20, 2018 at 11:26 AM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    1st gen Sequoia seats will bolt in, most of them were leather too.
  6. Apr 23, 2020 at 4:23 PM
    noahtibbetts
    noahtibbetts New Member
    Noah
    ‘06 SR5 Access cab
    I have a 06 SR5 access cab. Can I remove the bench seats and bolt in captains/bucket seats from any othe 1st gen model? What about the center console? Does it bolt in as well?
  7. Apr 23, 2020 at 6:50 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Should. I put buckets in my reg cab, as for the console access cabs should have the holes. Mine didn’t, but it did have the nuts underneath so I just drilled the holes and all the brackets are where they should be.
  8. Apr 23, 2020 at 7:20 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    2005-2006 tundra access cab seats will bolt right up. I did just that in my 2002 tundra. You only need to plug in the seat belt wire. I really like it, just a better overall seat and it slides back further (I’m 6’4). Other make and model seats will need some fabricating.
  9. Apr 23, 2020 at 9:11 PM
    noahtibbetts
    Noah
    ‘06 SR5 Access cab
    Thanks. Now to find someone who wants Grey bench seats and try and trade with them .
  10. Apr 24, 2020 at 5:43 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    I have an 06 with gray captains chairs, I miss the bench I had in my 02. I'd be open to a swap assuming the bench was in same condition.
    noahtibbetts and revtune like this.
  11. Apr 24, 2020 at 6:10 PM
    noahtibbetts
    Noah
    ‘06 SR5 Access cab
    Man oh man! My seats are in great condition. Unfortunately I am in Hawaii
    3.4Tundra likes this.
  12. Apr 24, 2020 at 6:29 PM
    empty_lord
    05 rollover special
    the one issue you may run into is the 05 and newer trucks have seat position sensors and the belt buckles are different. it'll require some modification to get it all working right. I had to cut and weld new buckles onto my seats and jerry rig the seat position sensor so that the airbag light turned off
  13. Apr 24, 2020 at 6:57 PM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Oh, that's good to know..
    Being that I have an 06, If I found an 05-06 to do the swap with, it should be a straight swap id imagine?
    FrenchToasty likes this.
  14. Apr 24, 2020 at 8:21 PM
    empty_lord
    05 rollover special
    Close enough. May need to swap wires over (my bench has different seat belt switch plugs than the 05 buckets)
  15. Apr 24, 2020 at 9:38 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Did the sequoia seats have side airbags. I wanna upgrade my fabric captain seats but keep wondering if I’m gonna deal with airbag lights if i do
  16. Apr 24, 2020 at 9:38 PM
    empty_lord
    05 rollover special
    some
    CodyP[QUOTED] likes this.
  17. Sep 29, 2020 at 10:36 AM
    goodclipper
    goodclipper New Member
    2000 Tundra 4WD Limited
    so got a 2003 Sequoia as well and thinking about switching to 05,06 Seats but mine are heated with airbags. So my question is it just bolt and click or am I gonna have to modify something? Thanks
  18. Jan 15, 2022 at 9:15 AM
    ivbyiv
    ivbyiv New Member
    Rust
    Sorry to resurrect an old thread but I finally just got a tundra. 2001 Access cab with the split front bench, and the drivers portion is really thrashed. Can anyone definitively say if the bottom cushion off a tundra/sequoia front captain chair would be a direct fit? appreciate it
  19. Jan 15, 2022 at 11:18 AM
    florida Stepside owner
    florida Stepside owner New Member
    2004 Tundra SR5
    This is a very serious problem that many of us have been trying to deal with. I have a 04 SR5 that had the original buckets overhauled by an upholstery ($1900.000 including replacing lower seat w/new OEM and they still were back/leg killers after 2 hours. I have 2 brand new Schell Mann seats and a set of Wedge industry brackets just sitting there while I find a solution for Passenger side Occupancy sensor. I have scoured the Planet looking for a Passenger seat occupancy emulator (plug in) so the air bag will work. Looked as far away as Poland (HDK) who makes high quality ones for most European cars (and I am sure they have much stricter regulations). Told these manufacturers that there is a good demand for these on the Tundra/Tacoma/Landcruiser/FJ forum. The Euro ones run around 45-95 dollars and are plug & Play. Hell, I would pay two hundred just to get it solved. I`ve even tried to find used Metaltech to no avail. May just have to change out Driver's seat which is terrible solution. The factory seats are just terrible (have heard that from late model owners). Do the new TRD models have a Recaro option? Also tried to price remanufactured trans as mine is slipping going into 3rd gear (scheduled for dealer diagnostic 1/24) went to Olathe Toyota parts and list was around $2850 with a good discount off that. Called three dealers and two were same list. The one nearest me was 3550 no explanation why!! Understand why their making list of Add on pricing on new trucks.
  20. Jan 20, 2022 at 7:19 AM
    ivbyiv
    ivbyiv New Member
    Rust
    Thanks for your reply- sorry for my delay, i'm still not in the rythym of being on here daily- im used to being on ih8mud.
    I will likely go with the local reupholstry route, see if I can't find new seat foam from toyota or find a junkyard passenger seat from a bucket seat, if that;ll work. this would give me the option of having the seats changed to heavy vinyl from cloth.
  21. Jan 26, 2023 at 6:45 AM
    Matix363
    Matix363 New Member
    Ryan
    2000 4.7 AC Tundra
    Weapon-R custom Ram air intake, Jet Performance MAF Sensor, Denso 1.25” MAF Flange, Bosch Platinum IR spark plugs, MSD Blaster coils, 220A High Output Alternator, 05-06 modified Intake Manifold w/12 hole 330cc fuel injectors, AEM 320 LPH fuel pump, Mishimoto Aluminum radiator, Flex-A-Lite Electric Fan 13 1/2", 170 degree thermostat, HPS Red Silicon radiator & heater hose kit, DirtyDeeds JBA long tube w/high flow cats & aggressive muffler full exhaust system, UniChip Performance Chip, 2004 Tundra Tranny and more to come soon: Long Travel front&back, 37”w/Methods, Fiberglass
    Yo, so I have a 2000 Tundra SR5 4WD 4.7 with gray driver&passenger front bench seats. They’re in excellent condition.
    So my question is, does anyone have a gray driver&passenger front captain chairs that they would want to trade with me?? Obviously it would be really nice if your seats are in good condition as well. Please let me know even if they aren’t gray, because I can always put new seat covers on them.
    Thanks, Ryan
  22. Feb 4, 2023 at 6:11 AM
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    So has anyone been able to find out if Sequoia Seats are compatible with the tundra? I found a salvage yard near me with a set of leather buckets and a center console for $400 for all of it, but I'm hesitant to buy unless I know they'll fit.
  23. Mar 1, 2023 at 1:03 PM
    Kilgore Trout
    Kilgore Trout New Member
    Oregon
    2002 AC Toyota Tundra SR5 4.7L V8
    Airaid Cold Air Intake, Magnaflow Dual Catback Exhaust, 2017 18” 4Runner Wheels
    I have an ‘02 with gray bench seat. I would be down to swap with you if you’re still interested. I’m located in Portland though, it looks like you’re in southern California somewhere? Lmk if you’re still interested, feel free to email me @ smudges_muggier_0p@icloud.com
