Orange instrument panel -dash
Discussion in '2nd Gen Tundras (2007-2013)' started by surffj62, Jul 27, 2021.
  1. Jul 27, 2021 at 12:52 PM
    surffj62
    surffj62 [OP] New Member
    2011 DBL RW
    I have a 2011 - it has the orange panel and I’m really not fond of it anymore (ever). I’ve seen some with blue dials. It this a later year 2012-13?
    IIRC there was a swap thread but can’t find it.
    Is it possible to switch these out?
    thanks
  2. Jul 27, 2021 at 3:07 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Jul 29, 2021 at 1:58 PM
    surffj62
    2011 DBL RW
    Thanks!
    That looks way more than I can handle.
    worktruckwhite likes this.
  4. Jul 31, 2021 at 6:03 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    The Limited trim models had the blue cluster. Sometimes called an optitron cluster which toyota has used for years on other models.
    I found one on ebay for a reasonable price. You can easily tell the difference because the optitron is tinted black. You cant see the gauges when it's off whereas the regular orange cluster is clear. I just searched tons of tundra clusters until I found a black one.
    I think there may have been some wiring changes between 07-09 and 10-13, but I can not confirm. I would be looking for a 2010-2013 cluster to fit a 2011.
    When it's off
    Filthyphil likes this.
  5. Jul 31, 2021 at 6:05 PM
    Half Assed
    Heartland Florida
    Reg Cab Gang
    It's a good upgrade IMO. The orange cluster is horrible.
  6. Jul 31, 2021 at 6:13 PM
    MrYOTA
    MrYOTA LSU Fan'alyst
    Greg
    Bossier City, Louisiana
    2012 Tundra CrewMax SR5 T-Force
    I have a 2012 and the cluster is orange/red or whatever. I actually like it but the blue looks to be a little easier on the eyes.
  7. Jul 31, 2021 at 6:23 PM
  8. Aug 2, 2021 at 7:33 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I ended up swapping the entire dash and cluster from a 2015 into my 2007. The newer look is much better than the old orange style.
    The limited edition trucks have the optitron cluster that has the white/blue look and the smaller digital LCD display. For the most part it is a direct plug and play swap as far as wiring.(You might have a small issue with sonar sensor inputs or something but the best I can remember right now 90% of the wiring is the exact same. I have all the diagrams to verify this.) The biggest issues is the odometer correction. The mileage data for your truck is stored in a computer chip inside the instrument cluster. If you swap clusters your truck will now show the incorrect mileage. I think you can buy an optrion here and they will program the mileage for you. It would then be a simple plug and play once you get it. https://www.taninautoelectronix.com...a-tundra-limited-optitron-instrument-cluster/
    The other option is to unsolder and resolder on new surface mount LEDs into your current cluster. I can tell you the LEDs a very small and this is a job that would take alot of time and patience I am pretty good with electronics/soldering and I would be hesitant to try to swap out every LED in an older cluster.
    These guys offer the service maybe? https://www.taninautoelectronix.com/product/2007-2013-toyota-tundra-instrument-cluster-led-upgrade/
    I think you could also potentially look at Sequoia clusters. For the most part the Sequoia is a Tundra with a 3rd row seat and cargo hatch instead of a bed.
  9. Aug 3, 2021 at 10:13 PM
    surffj62
    2011 DBL RW
    YES! Tanin was the one is was looking for!
    Thanks
  10. Oct 22, 2021 at 8:45 AM
    Kramegroeg2021
    Kramegroeg2021 New Member
    Mark
    2013 Tundra
    Tanin????
  11. Oct 23, 2021 at 10:55 AM
    surffj62
    2011 DBL RW
    “That”
