Opinion Needed - Frame Condition
Discussion in '1st Gen Tundras (2000-2006)' started by Ludakrishna, Apr 3, 2020.
  1. Apr 3, 2020 at 4:55 AM
    Ludakrishna
    Ludakrishna [OP] New Member
    Hi team, I've been in search for a 1G Tundra and found one with an immaculate service record performed by the local Toyota Dealership. 150K miles for $11K. The seller sent me the following undercarriage pictures upon request. The Car has been in the DMV (DC, Maryland, Virginia) area all its life. Does the frame look good? image_4617f704-071c-4be4-a126-8bf2710d31f7_2048x.jpg image_687e7900-bafe-4fc0-b125-6b02d241ff1d_2048x.jpg image_0a9b5659-bbb1-40bc-b161-c5b9050f4bb2_2048x.jpg
  2. Apr 3, 2020 at 5:32 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Hard to tell from those pics. Need to get under there and poke around with a screwdriver and hammer.
    MS22 and BTBAKER like this.
  3. Apr 3, 2020 at 5:40 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Agree with above poster. The frame looks pretty good from those pics. No obvious major rust spots but if it were me I would want to poke around and really look at it.
  4. Apr 3, 2020 at 6:23 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Agree with other posters, Before you agree to buy, get underneath and poke around with a scewdriver.
    Now, based on what we can't see (surface rust Everywhere), I would propose the previous owners at least weekly Rinsed the undersides given where it lived, I've never seen a vehicle from upper north east without surface rust and usually far, far uglier.
    If I were you, I'd get to going to see it, looks Good to me!
    MS22 and speedtre like this.
  5. Apr 5, 2020 at 9:58 AM
    TCMiTundra
    TCMiTundra New Member
    Dave
    2006 Tundra DC SR5
    None, really. Just tires and wheels.
    Dang, even the wheel on the spare looks good.
  6. Apr 5, 2020 at 10:00 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Need better pictures, if the axle is a sign of anything it may be under coated. Or the frames been replaced. If it’s under coated it’s likely hiding some nasty rust
    imDementeD likes this.
  7. Apr 5, 2020 at 10:07 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I agree with empty_lord, looks coated.
    If you look at the 3rd pic, left side by the lift point you can see rust/ bubbling in that area.
    I'm sure on close inspection there will be significant rust.
  8. Apr 5, 2020 at 11:49 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Like others said, looks like it could have issues, and really requires you to do a good inspection yourself. Aside from the frame, be sure to check the differential (there are some posts around here about them rusting through and leaking).
    That doesn’t mean it’s a write off, if it just needs to be properly stripped, treated, painted and recoated it might be worthwhile, assuming you can talk down the price enough.
    I don’t know what the rust situation is in your part of the world, but it may be that you won’t find anything better locally. That being said, I wouldn’t pay anything like that if I had to do that kind of work to the frame.
