Oops... Help?
Discussion in 'Wheels & Tires' started by TexasTurd, May 22, 2023.
  1. May 22, 2023 at 12:52 PM
    TexasTurd
    TexasTurd [OP] New Member
    '19 TRD Pro
    Some lights
    So I used the pinned thread to figure out the tires size I could run, I also searched other posts just to be sure. I ended up going with 285/60 R20, unfortunately I made the mistake of not taking aftermarket wheels into account. Fits rear, doesn't touch UCA, however it clearly rubs the front. I removed the mudflaps and am wondering if removing/tucking the plastic behind it will fix the issue.
  2. May 22, 2023 at 1:14 PM
    Use a heat gun on low and a screwdriver handle. Heat the plastic up where it rubs and roll the screwdriver handle (or anything like that) back and forth pushing it forward to mold it until it cools down.
  3. May 22, 2023 at 1:23 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    You can also just remove the liner in that area too (temporarily if needed). It’s very quick to add/remove.
  4. May 22, 2023 at 1:34 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This..^
    If you do remove it, pry the holes like pictured.
    Those long pieces it clips to break fairly easily if forced.
    Don't ask me how I know that..:eek:
    TexasTurd[OP] likes this.
  5. May 22, 2023 at 1:56 PM
    TexasTurd
    '19 TRD Pro
    Some lights
    Thanks!, i will try a heat gun this evening. If it doesn't work how I want I will remove the liners.
    For a more permanent fix, is there any issue with running bumper shims?
    NewImprovedRon likes this.
  6. May 22, 2023 at 1:57 PM
    Not at all. There are alot of us that have them.
  7. May 22, 2023 at 2:08 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Posts like these make me worry about going to 285 65 r20's. I almost bought some last week... I would just try and melt/mold the plastic back in your case. Although, I just removed the front part of the liner from my tacoma when I had 33's and I didnt have any issues long term.
  8. May 22, 2023 at 2:13 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    On stock 20” rims with 60 offset these should fit without any modification, possibly just the baby Mudflap removed. It’s when you go +25, +0, -20 etc you hit stuff more and more. Skinny 35s will fit with stock wheels/suspension.
  9. May 22, 2023 at 2:17 PM
    TundraMidwesterner
    Northern Illinois
    Well thats helpfull! I think the stock tss wheels are a +50 offset, im just worried about clearing the upper control arm but I think I will be ok. I've already removed the little mudflaps as one lost a screw and was hanging off maybe a month after I got the truck.
  10. Jun 23, 2023 at 3:19 PM
    Amish Tundra
    Amish Tundra New Member
    2020 TSS Off Road...............we call him "Bob"
    Well Heck......I'm stumped. I've read, I've studied and now fischmeckled. Is yours lifted to go 285/60/20? I'm reading I can't do it on my TSS 2wd off-road (2020), but I also read that I can with trimming. Should I just stick with 275/60/20? stock wheels +50. I'll just lurk here for a minute and see what I learn. Pics or it didn't happen.
  11. Jun 23, 2023 at 3:26 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Bottom of the bumper have 2 screws, could move the liner forward and re drill holes for extra ½ inches of clearance
  12. Jul 10, 2023 at 2:12 PM
    TexasTurd
    '19 TRD Pro
    Some lights
    Sorry for the late response to this, mine is a TRD Pro so it is lifted from factory. Still didn't fit with my wheels but works fine with the bumper shims.
    I don't have a pic with it full turn but it no longer rubs at all.
