One step ahead AR build… help me.
Discussion in 'Guns & Hunting' started by Dalandshark, Feb 27, 2022.
  1. Feb 27, 2022 at 10:52 AM
    Dalandshark
    Dalandshark [OP] Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Well I started my budget build about 4 years ago. My plan was to stay one step ahead of the bans. So I bought an Anderson lower receiver. Pre-Russian invasion a couple weeks ago I bought some Pmag 30 round 556 mags. So now I have two parts that are always on the chopping block in my state. I figure this Russian invasion is a good excuse to get the show on the road and bump up my completion timeline to sometime this century. The problem is I have forgotten all the research I did on what to buy next! So please help me with the next step. I believe I had been looking at a 16” barrel and some sweet trigger group, likely from PSA. So what recommendations for the lower parts? This will purely be used for target practice/just to have to exercise my rights/just in case. A quick google search says to buy an Aero Precision LPG which will likely be my next step. What say you?
  2. Feb 27, 2022 at 10:56 AM
    Dalandshark
    Northwest
    Eibach Level LIft
    Wait, should I change my title to The Zelensky Project?
  3. Feb 27, 2022 at 11:21 AM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    I see where you are in one of those states:(. I’ve recently completed some builds and I went with the Rise Armament LPK since I was using drop-in triggers. I’m no gun smith but when I bought the parts I just started with the stock and worked forward. Make sure all you’re parts are consistent (i.e. mil-spec) to ensure they fit.
  4. Feb 27, 2022 at 11:37 AM
    Dalandshark
    Northwest
    Eibach Level LIft
    Thanks and this makes perfect sense.
  5. Feb 27, 2022 at 4:29 PM
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    B5 systems furniture, Midwest Industries handguard
    buy a quality bolt carrier group, barrel, and trigger
    all of my guns run Larue triggers. I also stick with Larue, BCM, Ballistic Advantage and SOLGW for my barrels, but there are many, many other quality options out there…hard to beat an FN CHF for a multi purpose barrel
  6. Feb 27, 2022 at 5:54 PM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Reminder:
    “mil-spec” is *a* specification- not necessarily a good one.
    DeesCrewMax and Dalandshark[OP] like this.
  7. Feb 27, 2022 at 7:49 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    Look at Primary Arms in Houston thru alway have sales on a bunch of parts.
    Aero Precision for lower parts are always good and the trigger is not bad either. I have never had any failures from Aero.
    Dalandshark[OP] likes this.
  8. Feb 28, 2022 at 5:42 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Thanks for replies. I ordered a PSA MOE EPT lower build kit. It has the slightly upgraded trigger and guard and the MOE Grip and Stalk. I’ll look into the suggestions for barrel and upper parts.
  9. Feb 28, 2022 at 6:45 PM
    Black@Blue19
    Ken
    SE Texas
    To much to list:)
    Look at Faxon Barrels also
