One headlight keeps turning off
Discussion in 'Lighting' started by vtran19, Nov 11, 2017.
  1. Nov 11, 2017 at 8:28 PM
    vtran19
    vtran19 [OP] New Member
    kevin
    2016 White Tundra CrewMax
    Hello,
    I was wondering if anyone can give me some guidance. I had my HIDs professionally installed and it was fine for a few months. However, about 2-3 months ago, my left headlight keeps shutting down while my lights are turned on. I have to manually turn it off and turn it back on and it will last for about 10-15 mins before shutting down again. It's starting to be really annoying as I have to turn on /off my headlights like 5-6 times for a 30 mins trip. Any thought?
  2. Nov 11, 2017 at 8:38 PM
    HIDs... ballast bad?
  3. Nov 11, 2017 at 8:44 PM
    vtran19
    kevin
    I think if it was bad then it would just not turned on completely right? It turnds on and off so I'm not sure.
  4. Nov 11, 2017 at 8:46 PM
    Bad wire connection??
  5. Nov 11, 2017 at 8:54 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Couldn't resist.
    slide187, T-Rex266 and iHacker like this.
  6. Nov 11, 2017 at 9:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Have you tried going back to the installer?
  7. Nov 11, 2017 at 10:26 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Probably ground in the side isn’t making a good contact, also check the 9006 connectors I had bad experiences with them sometimes the motocontrol terminals are loose and wiggle maybe a broken locking tab in the connector that happened to me when had retros in my truck
    Sent from my iPhone
    SouthBoundSteve likes this.
  8. Nov 12, 2017 at 1:37 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I had something similar... Turned out to be the igniter. Swap the igniters over between sides, see if the bad light changes sides. If not, swap the ballast. If after that it's still the same side that's faulty, it's probably a bad ground
  9. Nov 12, 2017 at 2:32 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Bad igniter, swap them as suggested to test.
  10. Nov 12, 2017 at 4:15 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I would contact the actual manufacturer of the lights. Sounds like a bad ballast possibly. Something heating up and causing shut down ? Keep us posted what you find out. Good luck.......
  11. Nov 12, 2017 at 4:35 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm not sure, but swapping parts over can help you narrow it down. Like previously mentioned, the manufacturer may he able to help.
    Good luck, keep us updated.
  12. Nov 12, 2017 at 6:14 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Check your ground. My retrofits started doing this a few months ago. Just one side. After swapping bulbs and ballasts side to side I noticed the ground wire was stripped in the sleeve
  13. Nov 12, 2017 at 8:46 PM
    vtran19
    kevin
    Yea I have and they tested for 30 mins and the light was fine so they just put everything back together and sent me home. I think this time I'm going to record it and show them a clip in addition to testing the lights again.
    joonbug[QUOTED] likes this.
  14. Nov 12, 2017 at 8:47 PM
    vtran19
    kevin
    Thanks , let me check it out and try it. I think that might be it or I'm hoping it is.
  15. Nov 13, 2017 at 7:36 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Kevin,
    I had HID system before and I used the factory grounding points.
    The one by the air box and the other one by the fuse box under the hood.
    Can’t go wrong with factory grounds.
    tomsinamerica likes this.
