On the 5.7 , is it recommended to flush the transmission? Any issues after that?
Discussion in '2nd Gen Tundras (2007-2013)' started by Unique Black Beast, May 19, 2019.
  1. May 19, 2019 at 7:23 PM
    Unique Black Beast
    Unique Black Beast [OP] New Member
    2011 5.7 Black Crewmax Platinum 4x4
    Leveling kit. 3" front, 1" rear.
    Have anyone have any issues after flushing the transmission? I have 105000 miles ...not sure if I neeed to flush it.
    Any advice.?
    yoshi82 likes this.
  2. May 19, 2019 at 7:24 PM
    Dag3
    Dag3 New Member
    David
    Vail, Colorado
    2012 crew max limited
    Following, I’m about to hit 90k and was wondering the same thing.
    yoshi82 likes this.
  3. May 19, 2019 at 7:27 PM
    Unique Black Beast
    I have zero issues with my beast...but.
    I just need to know if some folks have done the flushing with no issues after....
  4. May 19, 2019 at 7:37 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Their are a few threads on here that talk about this same topic. From what I have gathered it is best not to flush and just do a drain and fill. A trusted mechanic near me said he would recommend dropping the pan. Said he did this on his wife Lexus which also has a sealed transmission. I'm sure others will chime in
  5. May 19, 2019 at 7:38 PM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    I have been told for years not to flush but to drain and fill. Reason explained is that when they flush the trans. they are forcing fluid through it very quickly which knocks off particles from the clutch bands causing them to slip more than usual. That's the short explanation I was told. Carmax service tech also said the same to me one time.
    15whtrd likes this.
  6. May 19, 2019 at 7:44 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It all depends on what you mean by "flushing".
    If you mean allowing a service shop to flush your transmission using their "machine", there is no way in heck I would do that. If you mean a complete replacement of the transmission fluid yourself using the method shown in the YouTube video, then yeah, I would do that around 100K miles, less if you're towing. See the link, modify the procedure if needed.
    https://www.youtube.com/watch?v=fLVZSoKbyZ0
    Alaska, Sas, stomachbuzz and 3 others like this.
  7. May 19, 2019 at 7:47 PM
    Unique Black Beast
    I appreciate the info folks..
    Please keep the good advice coming.
  8. May 19, 2019 at 10:16 PM
    Rica25
    Ricardo
    Tulare
    I did the fluid exchange at dealer with my buddy but with no additives to clean just the oil pushing oil and have not had no issues since I'm at 140k
  9. May 19, 2019 at 11:28 PM
    trdprobped17
    trdprobped17 New Member
    No issues whatsoever. But, it has to be done correctly.
    Rica25 likes this.
  10. May 20, 2019 at 4:14 AM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    Adding to that I now have my fluid replaced "drain and fill" every 60k since I do tow at times.
    Rica25 likes this.
  11. May 20, 2019 at 4:34 AM
    Professional Hand Model
    Hand Protectors
    Great vid. Fresh fluid is the key. Best way to keep it fresh is a drain and fill (partial as a drain is not a full flush like the vid) that replaces about a 1/3 of the contents every 5-10k miles. I do mine every 3k. Cheap insurance. Easier than an oil change!
    Rica25 likes this.
  12. May 20, 2019 at 5:07 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I had the dealer do this @ 270k... I have traveled 15k since then, time to do it again.
    Rica25 likes this.
  13. May 20, 2019 at 1:12 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    interested to see any additional responses.
  14. May 20, 2019 at 1:29 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m at 70k miles, but about to hit her 10 year birthday so I want to start changing the trans fluid as well. Any of the yota tech experts have an opinion of the best method for diy guys?
  15. May 20, 2019 at 1:32 PM
    Hand Protectors
    We have a member in the 1st Gen. Section who works as a Toyota Tech. He says to just do ‘drain and fills’ on a very regular basis versus waiting max intervals and doing ‘flushes’.
  16. May 20, 2019 at 2:08 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thank you. I definitely see the merit of not disturbing everything with pressure.
    A follow up question too: the guys doing to the drain and fill every so often, are you doing the fluid level checking procedure every time or just replacing the same amount of fluid each time?
  17. May 20, 2019 at 2:44 PM
    Hand Protectors
    I drain cold and fill cold the same amount. I’m still wrapping my brain around the overly complicated procedures of pins in fuse boxes and shifting gears erratically till certain lights stop/start blinking (I do not do this).
    Drain it cold and put the new in cold. The new goes right down into the pan location that the old was drained out.
    Check your dip stick after driving and make the necessary adjustments if needed.
  18. May 20, 2019 at 2:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    No dip stick on 5.7 trans :(
    stomachbuzz likes this.
  19. May 20, 2019 at 2:54 PM
    Hand Protectors
    The overflow fill hole is your checking device per that vid. Main thing is put in what you drained out. Measure it.
    chugs likes this.
  20. May 20, 2019 at 2:57 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    I always have done drain and fills on vehicles. A tip if you do.. keep empty gallon jug and measure 1 qt increments by adding water to it and marking the jug. I do in 1/4 qt increments for the last qt. (Of course then empty the water) I use the jug to measure out how much actually drained to have a better idea how much to add back. Double check w dipstick but this gets me right on. It always seemed less clear reading a tranny dipstick to me so this got me real close real quick.
  21. May 20, 2019 at 3:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I get that. Maybe I’m overthinking the hell out of this. The complicated procedure kinda sounds like the computer can calculate the fluid level. It is either gonna spill out the fill hole or it won’t. On my older trucks I remember just shifting through all the gears while idling got the fluid through the trans
  22. May 20, 2019 at 3:46 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Had my transmission serviced at the dealer around 114k. No problems and honestly feels like it shifts a lot smoother.
  23. May 22, 2019 at 8:15 AM
    Murrahj2012
    Murrahj2012 New Member
    Hayden
    2012 Tundra
    None
  24. May 22, 2019 at 10:34 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    For What its worth. The complicated procedure for checking the 5.7 liter is the computer getting the temperature correct for overflow hole level. The fluid is sensitive (how senstive I don't know) but the oil must be at a set temp to be check as it must flow differently when its warm (Makes sense).
    the 5.7 does not have a open system (dipstick), it does have a drain pan and plug and you can reasonably change it out one drain pan amount at a time. But this is only part of the system not all the fluid.
    the transmission fluid filter is mesh (metal) and the pan gasket is silicone (re-usable). The bolts however are small and straight up Carbon Steel Grade III (or lower) If you live in New England you might consider a plan of attack before removing the pan to replace the filter. (which may not be needed but I did at 80k on my truck (as it was new to me).
    My local deal reported that LIFETIME (WS) toyota Fluid was good for 100,000 miles.
    I did the solenoid open, and just let the transmission heat up to a just off cold level on my 2010 (which has a tranmission temp gauge).
  25. May 24, 2019 at 10:32 AM
    Unique Black Beast
    Guess what guys?!!!
    I contacted a long time mechanic at the dealer, trusted guy. But to my surprise he said no to change the transmission oil but spark plugs and water pump.
    He is like, "leave the transmission alone until it gives"...I didn't see that one coming.
    Now I'm more confused....lol
    Bo-Hunter likes this.
  26. May 24, 2019 at 2:43 PM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    I tried that method with a 2000 Chev Silverado and ended up with a 1800.00 Trans rebuild. They said the fluid was black as diesel oil. LOL
  27. May 24, 2019 at 2:49 PM
    Unique Black Beast
  28. May 24, 2019 at 3:09 PM
    pro2amendment
    Indiana
    Bullet liner
    Trannys are always voodoo it seems.
  29. May 24, 2019 at 3:34 PM
    JohnLakeman
    Can't say if that was a good strategy without knowing how many miles it made. :D
  30. May 24, 2019 at 3:39 PM
    JohnLakeman
    The recommendation to change the water pump seems bogus to me. It's probably overdue for a water pump, but I wouldn't change it until it started to leak. You should have plenty of warning.
