On Board Air Suggestions
Discussion in 'General Tundra Discussion' started by BlueRibbon4x4, Nov 1, 2020.
  1. Nov 21, 2020 at 4:59 PM
    #61
    BayRunner
    2017 Tundra Platinum
    It's a multi purpose setup. It will come in handy while trailing with the guys. Also i've recently had to change multiple tires on other vehicles out on the road. This will give me the air to run an impact wrench on the lugs. I also Do a lot of manual wrenching on never ending projects I seem to come up with so this will be my go to making them easier. It will also come in very handy working on the boat when docked. There's always something that needs fixed on the boat :). Overall in my scenario, I think it was a solid investment.
  2. Dec 3, 2020 at 3:38 PM
    #62
    pug master
    pug master New Member
    kris
    2020 Tundra
    sweet great idea
  3. Dec 21, 2020 at 8:45 AM
    #63
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Gotta give @Bannock452 a shout out. I pretty much copied (to the best of my ability) his idea. I made my own mount to specifically hold my compressor. It sits a little lower than his, and mine is much more difficult to install. My Smittybilt 2871 compressor barely fits. Thanks for all the info, everyone. :thumbsup:
  4. Dec 21, 2020 at 9:27 AM
    #64
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I've got the ARB twin on a Rago mount. When airing up your tires and your friends tires the air compressor can get extremely hot. With a laser thermometer I simulated airing up my 37s twice (15psi to 35psi: deflated, inflated, deflated, inflated) and recorded the compressor temperature to average out at 265 degrees with the hottest reaching 288 degrees. Heat will eventually damage the air compressor so I installed a fan to cool it down. Keeps temperature steady at ~150 degrees. The fan turns on whenever the compressor is powered on.
    upload_2020-12-21_9-22-23.jpg upload_2020-12-21_9-24-6.jpg upload_2020-12-21_9-24-44.jpg
    Bob_Wiley, Jimes, Saltyhero13 and 3 others like this.
  5. Jan 23, 2021 at 7:57 PM
    #65
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Do you have any pics of the tray you built? I have the same Smitty compressor and have recently considered mounting it in that location. Thanks!
  6. Jan 23, 2021 at 8:22 PM
    #66
    BlueRibbon4x4
    Geno
    Yep. Uses all existing mounting locations. I recently added another mount to the upper inner fender to reduce vibration. Still working on a solution to omit more of the vibration. Everything is tight and holding up after some pretty violent off-road runs, but seems like it could be better. D09793F4-2874-412F-9875-B8565F1EA298.jpg
    Hoologan[QUOTED] likes this.
  7. Jan 25, 2021 at 10:11 AM
    #67
    Mulligan1305
    Mulligan1305 New Member
    NC
    2011 Tundra SR5 DC, 4WD
    How hot does that thing get tucked up in there? Do you lift the hood for air circulation when you use it? I have the Viair version of that one and it gets hot as hell when I air up all four tires in summer. I can see it getting really hot when it's 95 degrees outside.
  8. Jan 25, 2021 at 10:39 AM
    #68
    2mchfun
  9. Jan 25, 2021 at 12:25 PM
    #69
    BlueRibbon4x4
    Geno
    I raise the hood also. My goal was to not have to do that, but this compressor gets crazy hot too. I’ll need to air all four tires this coming summer too, Where I live it gets up to 110F. So the hood will go up.
    Mulligan1305[QUOTED] likes this.
  10. Feb 4, 2021 at 5:52 PM
    #70
    NFARIDI
    NFARIDI New Member
    To the guys with ARB dual compressor, once you're done airing up, do you leave the hood open and let it cool off for a while (if so, how long?) before closing the hood and driving off?
  11. Feb 20, 2021 at 7:47 AM
    #71
    JDavis.hondatech
    JDavis.hondatech New Member
    Jake
    2019 Red TSS
    TSS package, pro grill and headlights
    I just installed the Rago mount yesterday, still waiting on the rest of the system to come. Did you notice a big improvement with the air tank you added next to the compressor? I’m trying to decide if I should add this or not. I too am installing the wifey air system aswell.
  12. Feb 20, 2021 at 8:37 AM
    #72
    SR5camper
    SR5camper New Member
    AZ / TX
    2015 SR5
    After a couple years of using a viair 440p I was finding myself reluctant to air down because of how time consuming it was to air down/up. I got some Staun tire deflators and an ARB twin and I couldn't be happier. I air down every chance I get now.
    SDHQ mount and my own 8AWG harness run the long way up front behind the grill instead of visible on the firewall.20210107_153008.jpg
  13. Feb 20, 2021 at 9:44 AM
    #73
    BayRunner
    If your goal is simply to air up/down your tires then you do not need the tank. My goal was to also drive air tools as well. I have the one gallon tank beside the compressor and also a two gallon tank under the truck. This gives me enough air to break and remove the logs with an impact wrench. I am very happy with the setup and have used it numerous working on things.
    300BLK likes this.
  14. Aug 8, 2021 at 11:03 AM
    #74
    Jwrose4
    Jwrose4 New Member
    Jonny
    Verona Va
    2020 Tundra SR 4x4
    Leveling kit, katskin seats, matched bumpers
    Do you need the gauges after the compressor if running a tank? Doesnt the ARB have an internal shutoff once full? The reason Im asking is because I had the ARB and 1 gallon tank mounted on my Tacoma and it would shutoff once full. I am now mounting the same compressor but going to do larger tank for air tools if I find myself in that situation and mainly train horns. Was just curious if the guages are needed before I start the install. Thanks
  15. Aug 8, 2021 at 1:14 PM
    #75
    BayRunner
    The ARB twin compressor does have an auto shut off at about 150 psi so you technically do not need a gauge. However, I always plan for the worst and included 2 gauges in case the auto shut off fails. One gauge is 0 to 60 for tire fill ups and the other is 0 to 160 for air tools. I also j closed an in-line shut off valve and pressure release valve.
    Jwrose4[QUOTED] likes this.
  16. Nov 21, 2021 at 11:22 PM
    #76
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
  17. Apr 15, 2022 at 7:23 AM
    #77
    matthaias
    matthaias New Member
    I have run a Puma 12v for the last 10+ years problem free. I have used it in its stock configuration, divorced mounted to the frame with a larger tank and air fittings at both bumpers on a switch in the cab, and divorced with no tank. I run a homemade 4 tire inflation setup. That Napa compressor looks intriguing because the Puma is large and heavy. If you are not familiar with the Puma look them up on IH8Mud.
