On board air compressor location?
Discussion in 'General Tundra Discussion' started by Bannock452, Oct 10, 2016.
  1. May 23, 2017 at 4:48 PM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    thats why i want mine in the box, to be secure... along with my ginormous battery and spod.. dont want a rats nest of wires in the engine bay this time around.
    dcsleeper408 likes this.
  2. Sep 3, 2017 at 11:54 PM
    zackbremer
    zackbremer New Member
    Da Z
  3. Sep 4, 2017 at 7:42 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Hmm. I need to take this into consideration. Is that the twin compressor? If not, do you think the twin would fit in the same spot? Do you have to worry about any additional heat from the engine or are you always raising the hood when you run it? Trying to figure this out and whether I want to jump into the compressor now or use a Powertank until I put the locker in.
  4. Oct 12, 2017 at 8:11 AM
    Stevenboise
    Stevenboise New Member
    Old Man Emu suspension. Brute Force Fab front bumper, rear dual high clearance rear bumper, sliders and headache rack.
    Following this thread.....lots of good options and ideas in here.
    I too am looking at a twin ARB mount, but not in my cab. I need it to air up and air down and run lockers, so access for the tires is important. I'm focusing on mounting it in the engine bay somewhere/somehow and lots of good ideas in here.
    Thanks everyone for sharing your builds on this. It's really tough (ok, impossible) to find a commercially available mount for a Tundra.
    dannysmith604 and zcarpenter92 like this.
  5. Oct 12, 2017 at 8:51 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Paid 377$ for a 100% duty cycle Viair kit w/2.5 gal res. I plan having the compressor installed under the hood to keep dry and to mount the reservoir on the inside driver side frame.
  6. Oct 12, 2017 at 10:19 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have mine tucked into the frame on my 03. I still need to sun air lines to the front and back of the truck.20171005_164949.jpg
  7. Oct 12, 2017 at 12:37 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I WANT ONE TOO! Nice work on the installs, it would be so nice to deflate and re-inflate the tires on rocky trails here. I too have told my wife I wanted one and a year later and no compressor as a gift??? LOL
    Darkness and 040Tundra like this.
  8. Dec 15, 2017 at 11:43 AM
    Sunnier
    Sunny
    San Diego, CA
  9. Dec 17, 2017 at 8:55 AM
    ZPMAN
    Minnesota
  10. Jul 25, 2018 at 5:17 PM
    hokiruu
    hokiruu New Member
    Truckee, CA
    07 Tundra
    Kings, LR UCAs, Coachbuilder shackles, 35x12.5 Ridge Grapplers, Demello front bumper, Comeup Seal 12.5 RS winch, LED ditch and fog lights, some hacked stock parts for clearance
    I am currently installing an Air Zenith OB2 4.25 CFM compressor under the rear passenger side seat of my 07 DC.
    I had to cut/grind out my bottle jack bracket to fit it this way (which is fine because it hasn’t been in my truck since ‘14 and it’s not bery useful with 35’s), fabricate a cystom bracket to mount it sideways, and will be installing a 5 gallon tank under the oassenger side frame rail. Here’s a teaser pic
    Ragnarkov and dannysmith604 like this.
  11. Jul 25, 2018 at 5:34 PM
    Professional Hand Model
    Hand Protectors
    I have a cheapy Black and Decker that was a freebee from someones garage. New and still in the box with long extension wires. Plugs into cigarette lighter or 12v adaptors or my 3 prong adaptor. Stores in my side work box until needed. Does the job!
  12. Jul 25, 2018 at 6:10 PM
    ZPMAN
    Minnesota
    Be careful mounting inside or you might go up in smoke.
    https://youtu.be/FAaTp_WCREw
