OMFG! 8mpg...please help!
Discussion in 'General Tundra Discussion' started by Thee_Oddball, Jun 24, 2018.
  1. Dec 17, 2022 at 3:21 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I'm going to jump in here and state the obvious just because. Change the oil, air filter, plugs, diff trans and trans case fluids and run a can of sea foam in it.
  2. Dec 17, 2022 at 3:42 AM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Proof that necromancers or necrophiliacs are real. Depending on which he wants to claim.
  3. Dec 17, 2022 at 4:18 AM
    Welcome from NY.
  4. Dec 17, 2022 at 4:18 AM
    :rofl::rofl:
    That's funny.
  5. Dec 17, 2022 at 6:10 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Holy necro thread batman
    ACDC2ZZTop likes this.
  6. Dec 17, 2022 at 6:39 AM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    My 2012 5.7 runs in the 13 mpg range all city driving. Waiting for a plug-in mod to show up and try for some improvement. Very skeptical
  7. Dec 17, 2022 at 7:12 AM
    ToolCat
    ToolCat New Member
    Greg
    A 4.7 would have to be running rich to only get 8-10mpg! Or something else is going on: torque converter not locking up, drag in the drivetrain somewhere...?
    Sounds like you have invested in the truck and got it in shape for years of continuing service. With the quality record of the newest Tundra, just keep your trusty V8, and even if you can't solve the MPG dilemma, rest assured you have a reliable truck capable of one-million miles of service.
    Tip: don't forget your transmission. Do 3 or 4 spill-and-fills using Valvoline Max-Life or Castrol Transmax ATF. Both are full synthetics (unlike the Toyota fluid), and are fantastic transmission fluids that work well. You can get either in the gallon jugs at WalMart for about $25. (It takes about 3-1/2 quarts for one spill-and-fill on the A750 transmission mated to the 4.0 and 4.7. Be sure to drive some miles in between!)
    And everybody freaks out about the transmission temperature thing, but TBH you can estimate the temp and get the transmission oil level perfectly within tolerance.
    With outside temps in the 55-85 F range, and your truck cool from being parked, on level ground just idle for about 10 minutes or so, slowly change through the gears a couple times, SET your parking brake and CHOCK a wheel. With the engine idling, use a good condition 5mm hex "Allen" wrench to remove the overflow plug, when it slows to a trickle, re-install the overflow plug.
    (Ideal to use new gasket/crush washer with any engine/transmission maintenance...)
    ToolCat
  8. Dec 17, 2022 at 10:24 AM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I’m a mechanic by trade and I’m certified on you tube . You need to have some one with a scan tool look at your MAF and oxygen sensors . A Dirty MAF could be your culprit . A scan tool that reads fuel trim and oxygen sensor values can help reveal problems such as a bad ECT and so on .
    A dirty MAF will act as insulation and throw off the fuel mixture since the computer is reading wrong values . This may all sound like gibberish but if you can find a trained mechanic he can analyze the info and find your problem
    k0diak8o8 and Medic343 like this.
  9. Dec 17, 2022 at 10:24 AM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    Dammit I fell for it
